#1 | |
New Sliders Updated 2-7-07!
I've been thinking about this project for a while and I finally decided to get after it after purchasing may Kilby Air Boss kit. I used 2"x4"x3/16" steel tube and welded the ends shut. I welded in 1/4" NPT bungs to both side so I can tap in for air and pressure tested the tubes. I mounted them to the frame by using sandwich clamps like the jeepermans. I hope to get them painted next week some time.
![]() ![]() ![]() ![]() [SIZE="2"]Here are some pics after the base Clear paint job. I do custom paint work on the side so I had some extra to spray on and I also added some grip trape on top. Also here is a pic of my custom rear swing out that I made into a tank as well. Enjoy! http://i48.photobucket.com/albums/f219/powerwagon67/DSCN0060.jpg http://i48.photobucket.com/albums/f219/powerwagon67/DSCN0061.jpg
- MY WHIP / ZILLACON - 5.5" RE LA and 37" Nittos Quad Zilla TowRig 2001 F350 Powerstroke SuperCrew (AKA Clyde) GhostRidersJeepClub.ORG Last edited by powerwagon67; 02-07-2007 at 09:36 PM.. |
#2 |
Good looking sliders and even better looking welds! Keep up the good work!
DARK STONE 2005 6.0l v-8 PowerStroke F-350 BLACK 1992 YJ 383Stroker, TH350, looking for a np205, d44 front, 12bolt rear, SOA on 4" springs, 35" Baja Claws, m8000, Electric fan, sliders, bumpers, crossmembers, all made by myself. Black Jeep Club Member #167 |
#3 |
will the welds hold you think if your under presure and take a hard shot to the rockers?
looks great
[COLOR="Red"]Canadian[/COLOR] [COLOR="red"][COLOR="White"]jeep[/COLOR][/COLOR] [COLOR="white"][COLOR="Red"]club[/COLOR][/COLOR] [COLOR="White"]member[/COLOR] [COLOR="Red"]13[/COLOR] 2000 TJ Sport 30/35 3:07gearing. 31 bfg allterrains cobra cb. otherwise pretty stock for now ..... upgrades planned this year... spacer lift, shocks and new rock sliders |
#4 | |
- MY WHIP / ZILLACON - 5.5" RE LA and 37" Nittos Quad Zilla TowRig 2001 F350 Powerstroke SuperCrew (AKA Clyde) GhostRidersJeepClub.ORG |
#5 |
Great job! They look very sharp
What do you guess they weigh? |
#6 |
Very nice! I plan on making the same type of sliders.
Any pics of the frame brackets? |
#7 | |
[QUOTE=overdrive]Very nice! I plan on making the same type of sliders. Any pics of the frame brackets? Here you go! I need to clean up and shape the frame brackets a bit though. Also here is a pic of my steering skid. I welded a PSC gusset with a skull for a different twist. Enjoy! Frame Bracket- http://i48.photobucket.com/albums/f219/powerwagon67/DSCN0052.jpg Steering skid with skull- http://i48.photobucket.com/albums/f219/powerwagon67/DSCN0053.jpg
#8 | |||
99 Sport I6 Auto | 4" Currie/ProComp/Skyjacker| 35" BFG KM2's on black steel rims | LoD xtreme duty rear bumper/tire carrier | Rokmen Mercenary rockers | Quote:
#9 | |||
[QUOTE=powerwagon67]They weigh in at 96lbs together.
The rest of the pics. Looks good! I like that gusset for the skid.
#10 |
How tough are those skids like that? Will the mount arms hold up to the weight? I have some 4x2 square left from my bumper build and would entertain making some like that. Just wonder if the arms will bend and let it hit the body.
1989 YJ Islander TBI350 4L60E BDS lift. Wag axles, 38 TSL's, 4.56 gears 1995 ZJ Orvis Edition 5.2L 3" lift and 32's. |
#11 | |
#12 |
Cool. I like those and that will probably be my next project.
About how long are yours? I need to see if I have enough metal left over. Don't want to buy another 20' stick.
#13 |
I plan on doing this myself. I'm currently getting mesurements and checking my materials at work, I work in a fabrication shop
![]() . I'm going to build rocker guards into the sliders. I will still have the sliders like you currently do, to the frame, but I will weld my rockers on top of the slider rails. I will post pics when I'm done -Mike |
#14 |
WTF is that?
Are the frame brackets just 2x2 tube to 1/4 inch plate? - Great welding by the way, I hope to be there one day - just started!
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift. AMC 20 Write Up In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles Coming Soon - CV Shafts, Welded Tubes, trusses |
#15 |
Each side is 50" long and I used 3/8" plate for the frame brackets and 3/16" 2x2 for the braces to the frame. By the way thanks for all the kind words!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
