Quantcast new rear bumper/tire carrier - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > new rear bumper/tire carrier
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 09-04-2005, 07:48 AM   #1
sbninja
Hey all, I am fabricating a new rear bumper/tire carrier .
Do you think the tire sits too low?
2004 Jeep Wrangler Sport - Black
WARN steering box skid,Nth degree Oil pan skid
RE 3.5" - M.O.R.E. 1" BL - M.O.R.E. 1" MML
15x8 Tech1 Rock Crawlers (4.5" BS)
35"x12.50x15 Dunlop Radial Mud Rovers
Aussie locked 30/ Ultimate 35 kit w/detroit
Black Jeep Club v2.0 Member #49
See Jeep Here
And here
sbninja is offline   Reply With Quote
Old 09-04-2005, 08:39 AM   #2
FrankZ
1997 XJ Cherokee
Maybe not too low, but I'd strongly recommend a better mounting method for the bumper itself.
Spec's
FrankZ is offline   Reply With Quote
Old 09-04-2005, 09:23 AM   #3
Gerg
Put a string under the rear tire on the ground. Then pull the string up until it hits the bumper. Is doesn't matter if you pull straight back or pull at an angle (like right under the spare tire). Which hits first the spare or the bumper?
I don't care how tough your carrier is, it only take a hard hit or two to start bending something on that carrier.
HTH
Greg
Bakersfield, Ca.
[SIZE=1][COLOR=Red]Red Jeep Club #321[/COLOR]
[/SIZE]
Gerg is offline   Reply With Quote
Old 09-04-2005, 09:41 AM   #4
copbait
it looks like a work in progress, so im sure there are some frame straps or the current mount is just temporary...?
copbait is offline   Reply With Quote
Old 09-04-2005, 01:37 PM   #5
sbninja
Yep , today I added the mounts that tie in under the frame ends. , I think I'll beef up the other mounts too.
See Jeep Here
And here
Old 09-04-2005, 06:25 PM   #6
hurleywranglerx
i think it'll look great when its finished.
nice work
2008 [B]Black [/B]Wrangler Unlimited Sahara
2004 [B][COLOR="Red"]Red [/COLOR][/B]Wrangler X RME (traded in on the 08)
2001 [COLOR="Silver"][B]Silver[/B] [/COLOR]Honda Prelude
hurleywranglerx is offline   Reply With Quote
Old 09-04-2005, 07:03 PM   #7
-RocknRoll-
Smell my finger
-RocknRoll-'s Avatar
i think it looks fine. Only thing to MAYBE consider when doing one in the future is this: If you make the 2x2 piece of metal that the tire swings on, more like 2x3(just a bit bigger), then you can hide any body lift nicely, and it seems to be much stronger.
I have a similar bumper to the one your building, metal is a bit thicker where it swings the tire away, and my tire does sit a bit higher. Good job!
2002 Sahara
D60/14b
Atlas, 42" Iroks
-RocknRoll- is offline   Reply With Quote
Old 09-04-2005, 10:12 PM   #8
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Looks great! I would do like Gerg said though, make sure your bumper is gonna be the limiting factor for your departure angle.. not the bottom of the tire..
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is online now   Reply With Quote
Old 09-06-2005, 11:50 AM   #9
97TJGUZZY
looks awsome man, nice work, looks similar to mine. what thickness 2x2 did you use for the bumper?
For info on outdoor adventures in South Carolina check out OffroadSC.com
97TJGUZZY is offline   Reply With Quote
Old 09-07-2005, 09:44 AM   #10
FunkSkunk
Sold my soul to JeepForum
FunkSkunk's Avatar
Looks decent man, i'd probably raise it an inch or so. Also think about if you go bigger with your tires down the road, it will need to be taller to fit the bigger meats, also the back spacing as well may need to be adjusted for larger tires. just my .02
lets see some updated pics!
I Hate Rainbow Trout
FunkSkunk is offline   Reply With Quote
Old 09-07-2005, 07:11 PM   #11
sbninja
Thank's The 2x2 is 1/4" thick.
See Jeep Here
And here
Old 09-07-2005, 08:07 PM   #12
sbninja
Well, it's done for the most part, I still will fab a frame tie-in.
I did raise the tire location. here are some pics.
See Jeep Here
And here
Glock Forum
