new to me welder - JeepForum.com
post #1 of 9 Old 01-23-2014, 01:28 PM Thread Starter
TKFireman
1980 CJ7
new to me welder
I was given a welder and have some questions. Its a Miller Thunderbolt 225v. From Miller's website it was made in mid 1979. I downloaded the manual and followed the maintenance procedures, cleaned it out and greased the slides the block rides on. I rigged up a temporary plug, plugged it in and laid down a bead. It worked great until I tripped the 30amp breaker. I figured it would happen, but just wanted to test it. I'll wire in a permanent 50amp circuit for it soon.
The leads are old and cracked, need to be replaced. What size cable would I need for 20-30 foot leads and where is the best place to get it?
I was also given a bunch of welding rods. I don't know much about stickwelding and was hoping y'all could tell the different uses of these rods
3/16" 6012 - have a bunch of these
3/16" & 1/8" 7018
3/16" 10016-02
1/8" x-ergon #103
3/32" 6011 just a couple of these
And an unlabeled box of unlabeled rods. These are all pretty old and probably incorrectly stored, but if nothing else I'll be able to practice with them. _________________
"If your gonna be dumb, you gotta be tough"
TKFireman is offline
post #2 of 9 Old 01-23-2014, 01:34 PM Thread Starter
TKFireman
1980 CJ7
post #3 of 9 Old 01-23-2014, 05:48 PM
Shaneo7
All I can really tell you about those rods is 7018 will work for pretty much any steel weld you will make and with a little practice they will look like butter as compared to the 60s which are easier to use but don't produce as nice of a weld no matter how much you practice also a 6010 or 6011 would be all position and I think but I'm not sure a 2 at the end means flat and horizontal position only. We use a lot of 6010 and 7018.
Shaneo7 is offline
post #4 of 9 Old 01-23-2014, 05:49 PM
Shaneo7
7018 is all position too but in over head and vertical it takes some practice.
Shaneo7 is offline
post #5 of 9 Old 01-23-2014, 09:21 PM
thantos858
1974 CJ5
You could try baking them. If they have a manufacture label on them they should have all info on the rods you need. Just for quick reference on rods http://www.lincolnelectric.com/en-us...ns-detail.aspx
As for the leads local welding supply shop would have or be able to make you the needed ones.
thantos858 is offline
post #6 of 9 Old 01-23-2014, 10:14 PM
Shaneo7
From what I've heard they can either only sit out so long and be baked again or their not as good of quality or they can only be rebaked so many times either way ive used rods that haven't been properly stored and they have worked very well still. The only reason you shouldn't is most of the rods are low hydrogen and when their not kept dry they soak up watervaper which gives off hydrogen when you weld.
Shaneo7 is offline
post #7 of 9 Old 01-23-2014, 11:02 PM
RenoF250
For leads you would probably want #2 for 20-30' but you would be better of putting it on wheels an making a longer 240VAC cord for it. That could be #6 and then you could get away with #4 leads.
My stick welder is on wheels and has ~25' cord. It is nice to have the welder close because then you do not have to walk 20' to make adjustments.
RenoF250 is offline
post #8 of 9 Old 01-24-2014, 10:23 PM
jaspepp
Those 3/16" rods are HUGE!!! As a whole, around the shop/jeep you will run a lot of 6011 and 7018ac in 3/32 and 1/8 sizes. 6013 isn't a bad one to have around either. 6011 will be great for tacking and is a fast freeze rod(solidifies quicker) a penetrates deep, but it is pretty difficult to make look pretty. It will burn over/out just about anything. 7018ac is the most common rod you will find people running. It's easy to run, makes a pretty weld, is not as brittle as 60 series rods. 6013 is similar to 6011 in that it will burn over lots of nasty stuff, but doesn't penetrate quite as deep. All these rods can be ran in any position. 7018 should be baked before welding (low hydrogen as stated above), while the 60 series rods you could probably stick in a bucked of water and they would still burn ok. Practice practice, stick welding isn't easy, But it will do most any jeep project you could think of. Enjoy the new toy!!!
"Idaho sucks!!!! Tell California"
jaspepp is offline
post #9 of 9 Old 01-25-2014, 06:51 PM Thread Starter
TKFireman
1980 CJ7
Thanks for the recommendations guys. When it warms up some and I can work with better ventilation, I'll do some practicing with it. I've had a 110v mig for a few years and was planning to upgrade to a larger unit, but I think with this stick welder to do the thicker stuff and the small mig, I can tackle most projects.
