New and Improved Rear Setup! - JeepForum.com
post #1 of 13 Old 03-03-2011, 05:33 PM Thread Starter
dirtbike7992
Over the last 2 months of cold winter I made it my personal project to spice up my interior a bit along with re-arrange some stuff. I decided to bedliner my whole interior, install 4 point belts, build a rear shelf, mount my full size inside my rig, re-wire....everything... , and make my own rocker gaurds. But that is what I have done so far. I have 2 Black YJ seats and black roll bar padding to install just yet. Let me know what you think! As of now I only have a couple pictures sorry.
1990 YJ 4.2 AMC weekend warrior
dirtbike7992 is offline
post #2 of 13 Old 03-03-2011, 05:42 PM Thread Starter
dirtbike7992
I apologize for the ridiculously large photos....
post #3 of 13 Old 03-03-2011, 05:58 PM
91YJRockCrawler
the way you mounted your shoulder harnesses you need a harness bar going across the b pillar about shoulder hight and slots in your seats for the harnesses
The P.O.S: 91 wrangler locked on 33s
Daily Driver/tow rig: 01 F150
its mind over matter.. I donít mind and the sheet metal donít matter
Originally Posted by JeepnBlake View Post
It's JF's very own little slice of Pirate :rofl:
91YJRockCrawler is offline
post #4 of 13 Old 03-03-2011, 10:07 PM
hallway94yj
Unless of course you have money to blow on a chiropractor!
hallway94yj is offline
post #5 of 13 Old 03-04-2011, 05:23 AM
dodger889
Here is something you need to check. Is your belts DOT rated if not they are not legal for the on road use. Now most cops will not give you a ticket but still if they want to be a pain in the arse then yes.
The other is that your shoulder mounting is to high. You defeated the reason for them. Shoulder and lap belts are suppose to keep you from coming out of the seat.and work together.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #6 of 13 Old 03-04-2011, 07:36 AM
TSEJEEPERS
Yep the way you have those mounted is more dangerous than the original seat belts.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #7 of 13 Old 03-04-2011, 11:03 AM Thread Starter
dirtbike7992
They are DOT approved. I am working on the harness bar I am 18 and cant afford it at this point. for now it will work.
post #8 of 13 Old 03-04-2011, 12:57 PM
rlockwood
They'll work great right up until the crash. But of course, you probably aren't planning on getting in an accident any time soon, right?
rlockwood is offline
post #9 of 13 Old 03-04-2011, 04:06 PM
CJ258
1974 CJ5
Four point harnesses are a PITA if in a daily driver.
CJ258 is offline
post #10 of 13 Old 03-05-2011, 12:54 AM
'92 vegas YJ
just because you're 18 and cant afford a harness bar doesnt mean you should do things that arent safe. you are better off with the stock seat belt system until you can afford the correct setup
we arent trying to be rude. we're looking out for your safety.
-chris
'92 vegas YJ is offline
post #11 of 13 Old 03-05-2011, 07:32 AM
jatepper
Yep, the way you currently have your harness configured is DANGEROUS. As already stated, you should go back to your 3-point belts until you can afford to do it correctly...just sayin.
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #12 of 13 Old 03-06-2011, 07:32 AM
onlyinayj89
onlyinayj89 is offline
post #13 of 13 Old 03-14-2011, 02:42 PM Thread Starter
dirtbike7992
I was just going to ask for a link to the belt bar... I plan on buying that soon. I don't drive the Jeep a whole lot as it is. But hey thanks for looking out!
Improved Antenna? nbf6165 Audio, CB & Ham Radios, GPS, & Electrical 8 05-29-2008 01:09 PM
Amp Help-Setup tmfrench Audio, CB & Ham Radios, GPS, & Electrical 11 05-10-2007 10:06 AM
Wilderness Vs. Tomken Rear Setup ssikrup General Jeep & Off-Road Equipment 11 11-29-2004 09:31 PM
I improved my XJ's engine, but there is no result! Why?? saleem Engines & Drivetrain 8 07-01-2003 09:24 AM
Rusty's Flowmaster exhaust setup or custom exhaust setup? 4x4 XJ General Jeep & Off-Road Equipment 2 01-22-2003 02:45 AM
