New angle grinder, noob with one though - JeepForum.com
post #1 of 46 Old 10-06-2013, 08:32 PM Thread Starter
Tyler980
Hi, I'm a newb when it comes to this thing, but I Picked one up since I see everyone always saying they used it for this and that... So I just had a few questions... It's a 4 1/2" angle grinder, 7.5 amp. Now, my question is, what type of attachment would I need to cut a section of the tub out on my jeep? I'm getting the diamond plate rockers, and I'm looking to just cut the rust spot out entirely to eliminate it, and prime it so it won't rust again. Do I use a metal grinder, or is there a cut wheel or something? Last question, would this grinder work to cut a section of the frame out thats rusted through as well, and if so what attachment for that? Thank you guys a lot and sorry if I sound like an idiot. Lol
Tyler980 is offline
post #2 of 46 Old 10-06-2013, 08:35 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Just get some good metal cutting disk. Wear a face shield. Long sleeves and gloves with boots and long pants. You'll be good. Or get a sawzall
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #3 of 46 Old 10-06-2013, 08:36 PM
timatoe
timatoe's Avatar
Grinding wheel is exactly that for grinding, get a cutting disc for cutting. If you decide to get a wire brush wheel, get the knotted wheel, unless you like pulling wire out of your pants, shirts, arms, legs, etc.....
X's 2 btw on the sawzall.
timatoe is offline
post #4 of 46 Old 10-06-2013, 08:42 PM Thread Starter
Tyler980
Thanks guys, and I plan to get a sawzall as well at some point, I just figured a grinder would be easier for cutting the tub, and would my grinder be strong enough for cutting the frame?
Tyler980 is offline
post #5 of 46 Old 10-06-2013, 08:54 PM
Tom95YJ
Tom95YJ's Avatar
I would use a sawzall or OXY ACE torch on the frame you'll chew through disk. With a cutoff wheel.
5 essential tools for Jeeps
1. Cut off wheel
2. Sawzall
3. B.F.H.
4. Welder
5. Oxy/ace Torch or Plasma Cutter.
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #6 of 46 Old 10-06-2013, 08:59 PM Thread Starter
Tyler980
Alright thanks.
Tyler980 is offline
post #7 of 46 Old 10-06-2013, 09:35 PM
jred
1. Cut off wheel
2. Sawzall
3. B.F.H.
4. Welder
You forgot goggle/face shield! You can replace jeeps, but not eyes!
For the OP, you *can* use a cutoff wheel (cutoff wheels will be thinner & look kind of like fiberglass/carbon fiber-ish). How much fun it will be depends on how much you're cutting. I got a big package of wheels at Harbor Freight for a few bucks. Depending on the thickness of the sheet metal, you should be able to get anywhere from 2"-12" cuts out of each wheel. When the wheel is ground down to where it's hard to get in the cut, it's time to replace it.
Try to keep the wheel at right angles to the surface. Try not to twist it too much or create a sharp bend in your cut. If you do, the wheel can shatter. Did you catch the comment above about eye protection?
What I usually do is rough cut with the cutoff wheel, then use the grinding wheel to final shape & smooth finish.
jred is offline
post #8 of 46 Old 10-06-2013, 09:45 PM Thread Starter
Tyler980
Thanks! I plan to get a face shield/goggles and finally pick up some gloves. Its just small sections I am looking to cut, on the frame its about 6" long, and 3" wide max maybe... and on the tub its about 4"x4"
Tyler980 is offline
post #9 of 46 Old 10-06-2013, 10:16 PM
Tom95YJ
Tom95YJ's Avatar
You forgot goggle/face shield! You can replace jeeps, but not eyes! For the OP, you *can* use a cutoff wheel (cutoff wheels will be thinner & look kind of like fiberglass/carbon fiber-ish). How much fun it will be depends on how much you're cutting. I got a big package of wheels at Harbor Freight for a few bucks. Depending on the thickness of the sheet metal, you should be able to get anywhere from 2"-12" cuts out of each wheel. When the wheel is ground down to where it's hard to get in the cut, it's time to replace it. Try to keep the wheel at right angles to the surface. Try not to twist it too much or create a sharp bend in your cut. If you do, the wheel can shatter. Did you catch the comment above about eye protection? What I usually do is rough cut with the cutoff wheel, then use the grinding wheel to final shape & smooth finish.
Read my first post !
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #10 of 46 Old 10-06-2013, 10:29 PM
Old4X
1990 CJ7
Sawzall with "torch" blades for the frame
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #11 of 46 Old 10-06-2013, 10:41 PM
squarelite
I'd rather use a cutoff wheel. The chassis is only. 1/8" thick
squarelite is offline
post #12 of 46 Old 10-06-2013, 11:08 PM
jred
Ah, yes, I didn't notice the username. Still, a noob with a angle grinder needs extra reminders! :P
Oh yeah, Tyler, make a couple of practice cuts in the center of the area you're cutting out to get the feeling of the tool.
I remember the first time I took an angle grinder to a set of tins. The worry that I would screw it all up. It ended up being so much easier than I expected. Just remember this:
We all screwed it up the first couple times
jred is offline
post #13 of 46 Old 10-06-2013, 11:20 PM
fratis
fratis's Avatar
Not to harp on the eye pro but I use a face shield and glasses. I've had to have metal dug out of my eye twice. It really isn't fun. The trick to using a face shield is to keep it nice. Don't put it down on the ground face down. As soon as the plastic gets hard to see though you wont use it. I've also had to remove a 1" wire from my neck that was in for months.
RANDOM NOTES:
A cutoff wheel on a grinder will work fine for the frame.
I use Makita units. I've found them to last. I use 4 different ones, each with a different wheel. Saves a ton of time.
Note its rotation. This is especially important with a wire wheel. It will jump at you if catching an edge improperly.
Always wear a glove on the opposite hand. I dont use one on the hand that holds the grinder but I have a couple scars on the left hand.
Unplug when changing disks. The button that pins the shaft is close and similar to the on button.
A nick from a cuttoff wheel might be stitchable.
A nick from a wire wheel will create a big hole that will be unstichable.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #14 of 46 Old 10-06-2013, 11:34 PM
squarelite
Originally Posted by fratis
Not to harp on the eye pro but I use a face shield and glasses. I've had to have metal dug out of my eye twice. It really isn't fun. The trick to using a face shield is to keep it nice. Don't put it down on the ground face down. As soon as the plastic gets hard to see though you wont use it. I've also had to remove a 1" wire from my neck that was in for months. RANDOM NOTES: A cutoff wheel on a grinder will work fine for the frame. I use Makita units. I've found them to last. I use 4 different ones, each with a different wheel. Saves a ton of time. Note its rotation. This is especially important with a wire wheel. It will jump at you if catching an edge improperly. Always wear a glove on the opposite hand. I dont use one on the hand that holds the grinder but I have a couple scars on the left hand. Unplug when changing disks. The button that pins the shaft is close and similar to the on button. A nick from a cuttoff wheel might be stitchable. A nick from a wire wheel will create a big hole that will be unstichable.
This post is so important.
Face shields are just that, for your face. It still leaves room for something to get underneath it. Eye protection is mandatory. I always wear eye protection, even when wrenching under my jeep with hand tools.
The part about unplugging the grinder when changing discs is huge. It's something I do all the time. This also applies to changing drill bits, saw blades, etc...
post #15 of 46 Old 10-07-2013, 01:07 AM
mudsweatNgearz
1987 YJ Wrangler
Lots of valuable advice here. For what it's worth I have used a lot of different brands of cutting disks and nothing I have found yet compares to the Diablo brand disks that HD sells. Sure most other brands are a little cheaper but they will only last half as long or blow up easily.
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
