Need opinion on welders ASAP!!! - JeepForum.com
post #1 of 14 Old 03-04-2006, 04:06 PM Thread Starter
heavyhitter
heavyhitter's Avatar
I Have been tinkering with my YJ for a few months now and I realize I need a welder. I am going to build a couple of bumpers and do an 8.8 swap etc .. etc..
I decided for my application I will probably be best off with a wirefeeder flux core/mig setup.
The two welders I am deciding on are either the lincoln 3200hd or the lincoln 100hd What are the major differences???
Awesome flyfishing pics and vids here
93 YJ almighty 4banger, 31" bfg all terrains on 15x8 ar black steelies, 1.25" PA shackle lift, pioneer stereo system, herculined tub, TJ Flares, Rock Sliders, custom front & rear bumpers,
heavyhitter is offline
post #2 of 14 Old 03-04-2006, 09:06 PM
76CherokeeChief
I would buy a miller 210. I am a miller fan.
76CherokeeChief is offline
post #3 of 14 Old 03-04-2006, 09:25 PM
schmoken
schmoken's Avatar
I've had my Hobart Handler 130 for 10 years now. Only complaint is the low duty cycle, but AFAIK, that's common with the 110V rigs.
schmoken is offline
post #4 of 14 Old 03-04-2006, 10:01 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Seriously, there is at least a half dozen other threads on this subject already.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #5 of 14 Old 03-04-2006, 10:06 PM Thread Starter
heavyhitter
I'm not too concerned about the duty cycle. I am in no hurry. Schmoken how has the hobart performed for you?? That is pretty much the same setup as what I am thinking about buying. I am buying the welder tomorrow. Given your experience which one would you buy and why??? the specs on the two machines are here hd100 vs the hd3200
http://www.mylincolnelectric.com/Catalog/equipmentseries.asp?browse=114|2690|
they are the 9th ant 14th ones on the list. TIA any input is appreciated
post #6 of 14 Old 03-04-2006, 10:08 PM Thread Starter
heavyhitter
I understand how to use the search option. If you can find me the comparison ont these two welders post it please.
post #7 of 14 Old 03-04-2006, 11:38 PM
Blackjackbender
if your welding axle brackets and suspension items i wouldnt go lower then a 175. maybe a 135.
2000 TJ, flipped 300. HP60 w/3 link. 14 bolt leaf sprung. 107" wheelbase
Blackjackbender is offline
post #8 of 14 Old 03-05-2006, 08:18 AM
schmoken
schmoken's Avatar
Took a quick look at the setups. They seem to be very similar but with the 3200 you get a gas regulator too. That's a plus.
The 3200 is very close to my setup.
I did all my work with flux core wire. 90% of the time I was outside in the wind anyway.
My little 110V box was used on my old Jeep for perches in a spring over, a saginaw steering box mount, a bomebrew beefy ps pump mount/bracket, and bumpers. This was in '97/'98. No problems so far. That Jeep is still in the family going strong.
schmoken is offline
post #9 of 14 Old 03-05-2006, 10:19 AM Thread Starter
heavyhitter
Hey thanks I got the 3200 this morning someone else recomended it too. I appreciate the input it's nice to hear from personal experience. now I just have to figure out how to use it
post #10 of 14 Old 03-05-2006, 12:42 PM
Matt Gertsch
www.lp.org
I've been welding for a couple of years now. I weld everything from 18 ga. sheet metal with TIG to 1 1/2" plate with stick, running it up above 150 amps. I've done some MIG, both short arc and spray arc and flux core, but I'm not a very big fan. I haven't used the Hobarts, but they're essentially re-badged Miller machines. I've used both Lincolns and Millers in all 4 processes and I prefer the arc that the Miller machines produce. If I was to buy a MIG/FCAW machine, I'd probably get a Hobart. My 2 cents, sorry if I sounded like a dick earlier.
post #11 of 14 Old 03-05-2006, 04:30 PM Thread Starter
heavyhitter
No worries mgertsch I know I'm a nubie at welding but I learn quickly and am not going to be using my welder for all that much stuff......... Well... now that I think of it I probably will use it more than I expected to. Mainly I wanted a machine that is capable relatively affordable and easy to learn on after researching the processes I think the lincoln 3200hd is going to suit me fine. It says it'l do 5/16 steel one pass with fcaw and 3/16 gmaw. I think this'll do me fine. It sounds like you have a good bit of experience do you weld for a living???
post #12 of 14 Old 03-05-2006, 05:21 PM
Matt Gertsch
www.lp.org
I'm in a fairly extensive welding program. I've got a semester and a half left. This semester, I'm doing all of my structural stuff which concentrates on AWS, AMSE and API specs mostly. I certify in SMAW, GMAW, FCAW and GTAW next semester. I need to figure out what GTAW (TIG) certifications I'm going to get. I think I'm leaning towards Nuke or FAA certs.
post #13 of 14 Old 03-10-2006, 09:53 PM
redneckjeepman
i sell welding supplys for a living . hobart and miller are both made by miller .
buy a 220v imput machine like a challanger 175 or mm210 or equlivent in hobart
and buy from a true weldingsupply dist not walmart or lowes then when you have a problem you can take with some one who knowes what there talking about
also plan on using shielding gas [argon/co2] flux cored wires spatter bad
and if you count cleanup time and spatter they cost the same price
hope this info helps
email thetransamman@alltell.net
redneckjeepman is offline
post #14 of 14 Old 03-11-2006, 12:30 PM
Matt Gertsch
www.lp.org
A lot of people say that. Its my experience that if you hold a consistent stick out and run quality wire that the spatter isn't bad. I run a lot of E6010. That is my reference for something spattering a lot. A good general fab tubular wire is any high quality ER70T-GS. We run Hobart or Lincoln wire at school for the most part and the T-GS doesn't spatter at all. It has a nice light slag coat that generally just peels off as the weld cools. Even with hard wire, I wouldn't waste my money on argon for steel. 100% CO2 works well. Salesmen like mixes because they're more expensive. I prefer the feel of straight CO2 on steel.
Like I've told everyone else that asks about machines, go take a few classes. Find what you like and what works for you. I shake like crazy and have no patients but I absolutely love TIG.
Welders jmna Fabrication Shop 1 12-14-2008 05:01 PM
Welders TJSport01 Fabrication Shop 14 01-26-2008 01:02 PM
2 Welders CJ5911 Fabrication Shop 6 09-19-2007 08:02 PM
welders joe's_yj Fabrication Shop 21 05-23-2007 10:51 PM
Any welders in PA? toplessjeep General Jeep & Off-Road Equipment 3 01-29-2006 12:46 PM
