-   Fabrication Shop (http://www.jeepforum.com/forum/f37/)
-   -   Need to know the difference between PSC.............. (http://www.jeepforum.com/forum/f37/need-know-difference-between-psc-369543/)
OffCamberTJ 02-01-2007 06:28 PM
.......trail coners and PSC crusher corners. What I need to know is there a difference in the line they follow at the fender opening.
Here's my idea as also posted in the TJ section............
Has anyone ever thought about taking a PSC trail corner, adding the additional 3/16" plate to convert it to a Crusher type corner then ordering/adding the Crusher flares to the modified trail corners?
Doesn't seem like a hard thing to do if one buys trail corners to begin with then decides they want Crusher corners with tube flares. It would be a good way to save some coin if you already had 3/16" plate to modify your trail corners with.
Just a thought.....................opinions?
Bigbob 02-02-2007 10:02 AM
I think the corners are cut so they fit just a tad over the flare. But that should not be an issue for what you are doing. Call or email PSC and ask. Bob
gabemerrill 02-05-2007 09:30 AM
I used the Spyder crusher corners and welded flares to them. IMHO its worth the extra $ to have a single piece vs. 2 that are butted together. The crusher corners also extend all the way to teh edge of the tub, I actually trimmed mine to make more space. I know when I put my jeep on its side there isn't a weak spot where they meet.
Here is what they looked like with primer..
http://img.photobucket.com/albums/v4...d/DSCN2071.jpg
But then again I do drag mine across rocks ...
http://img.photobucket.com/albums/v4...06/dropoff.gif
:cheers2:
The time now is 02:36 AM.
