need help welding shackle mounts - JeepForum.com
post #1 of 10 Old 10-14-2009, 05:11 PM Thread Starter
lakailimited06
whats up fellas still a beginner to welding but im making my bumper and im welding 3/4" shackle mount to my 3/16" rectangular box bumper...
i have a hobart handler 210 and i was curious should i be on the most powerful setting and concentrate mostly on the 3/4" and alittle on the 3/16"? i dont want to burn through the 3/16" so im not sure what setting to use i want to make sure i get plenty of penetration...
TIA
Jason
99WJ 4.0
IRO 3", SYE, D30 aussie/8.8 aussie, 4.10s, 33's, skids/bumpers
lakailimited06 is offline
post #2 of 10 Old 10-14-2009, 08:16 PM
RitterXJ
1990 XJ Cherokee
I'd say to just concentrate on both equal amounts. The key is to weld them on as many points as possible. Front, rear, top, bottom, whatever. But I have only built one bumper so far, and started on the second so dont take my word on it.
Just
Everybody
Elses
Parts
My Cherokee's very slow progress in pictures:
RitterXJ is offline
post #3 of 10 Old 10-14-2009, 08:23 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
I'm not real familiar with that welder and it depends on if you're using gas or flux core wire but you'll want it turned up pretty hot and put about 2/3rds of the heat on the mount and about 1/3 on the 3/16th.
Are you welding the mount to the surface of the bumper or is the mount going through the bumper so it can be welded front and back?
Similar to this. This is my receiver but the D-ring mounts are welded the same way.
My bumper build begins on post 33 of the build thread in my sig; there are more pictures of d-ring mounts.
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #4 of 10 Old 10-14-2009, 08:25 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
that is exactly how they should be welded in. Do not but weld them on. They should go thru the bumper.
As far as how to weld them, I would be close to highest setting but not all the way and start in the 3/4" and work into the 3/16" If you try and go 50/50 your chances of burning thru the 3/16 is greater.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 10 Old 10-14-2009, 09:06 PM
wushaw
Rockin jeep
wushaw's Avatar
I agree with most of your heat on the 3/4 and just wash it over to the 3/16. The 210 is a good welder. If you do butt weld the back side chamfer the D rings and reciever tube to get as much weld as possible.
wushaw is offline
post #6 of 10 Old 10-15-2009, 05:38 PM Thread Starter
lakailimited06
they are the shackle mounts from JCR which just weld onto the front of the bumper they dont go through..
99WJ 4.0
post #7 of 10 Old 10-15-2009, 05:56 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
Be careful what you put on them then if they are not welded through the whole bumper.
I know it "should" be strong, but no where near as strong as through welded.
They are only as strong as what they are welded too, meaning if they were even 2" thick, they would only be as strong as your 3/16 bumper they will be attached to.
i guess you didt get hurt on the price though huh?
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #8 of 10 Old 10-15-2009, 06:08 PM
rustywrangler
Might I suggest you hold off on those and order these from BESRK: 1" THICK WELD THRU SHACKLE CLEVIS MOUNTS JEEP BUMPER:eBay Motors (item 330366789234 end time Oct-16-09 09:05:50 PDT)
post #9 of 10 Old 10-15-2009, 06:22 PM
leftlanetruckin
XJ on 37's
Originally Posted by rustywrangler View Post
An excellent idea, as well as an excellent price!
Martin
post #10 of 10 Old 10-16-2009, 09:47 AM
ChiliPalmer
Martin
X's 3...
Forum!
Bolt on Shackle mounts? ClimbStuff General Jeep & Off-Road Equipment 4 09-15-2009 08:09 PM
Rokmen shackle mounts gmgreen General Jeep & Off-Road Equipment 2 08-21-2009 06:12 PM
Johnny Joint shackle mounts CTeunuch Fabrication Shop 7 07-09-2009 06:59 AM
Question about welding on D-ring mounts dexetr30 Fabrication Shop 3 01-30-2009 07:23 PM
D ring shackle mounts penguinland Fabrication Shop 8 05-24-2005 06:13 PM
