Need help finding the right welder - JeepForum.com
post #1 of 9 Old 06-11-2004, 09:58 PM Thread Starter
cfkingfish
cfkingfish's Avatar
I am moving into our new house soon, and I really would like to get a welder to work on some stuff for the Jeep and other things around the house. I want to mostly use it for exhaust, roof rack, and a few other things, and I think a MIG welder will work best. I would like to get a Hobart. The thickest metal I would work with would probably be 3/16", for a bumper. The welders range from $400 to $1600 at Northern Tools, and I dont want to buy a bigger welder than I need. Any advice on what to get?
Thanks.
Christian
89 XJ 4.0 AW4
K&N 6x9 cone filter setup
Converted to TJ axles - 5-297 U-joints
Optima Red Top
Custom exhaust
www.ishopfaulkner.com
cfkingfish is offline
post #2 of 9 Old 06-13-2004, 07:11 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I would take the bite and pickup a 220 volt welder (probably Hobart's 175 amp model). It'll cost ya between $500-$600 but it'll do anything you'll ever need to do on a Jeep. If you start off with one of the 110 volt jobs (like a 100 or 135 amp) they are limited to around 3/16" maybe 1/4". With the bigger welder, you'll be able to do all the stuff you mentioned plus a whole lot more. I first picked up a 110 welder. After awhile I needed more penetration so I picked up a 220 volt stick welder. Finally, I moved on to a Lincoln 175 wirefeed. It's like a Cadillac compared to the other two.
BESRK is offline
post #3 of 9 Old 06-20-2004, 01:35 AM
Chris_L
Always buy more welder than you think you will need. Get a 220 unit. Cyberweld.com has the best prices with no tax {unless you live in Jersey} and free shipping.
Buggy on 40's
Chris_L is offline
post #4 of 9 Old 06-21-2004, 11:40 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
What he said...
Going bigger also allows you to run the welder longer at lower amperage ratings. (Longer Duty Cycles)
From the talk I have heard, the 175 Hobart is a good Welder and most don't need more.
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #5 of 9 Old 06-25-2004, 02:37 PM
XJ99
XJ99's Avatar
2006 XK Commander
I'm fairly new to welding. I bought a Lincoln Electric 100HD wire feed. I also bought the accessories to hook up the argon gas bottle. (I guess to weld aluminum) It's suppose to be a good all round welder. It can weld up to 1/4 steel. (More then I'll ever need) I think I paid about $425.00 for everything. Also get an auto-darkening helmet, they rock.
Good luck with your choice.
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is offline
post #6 of 9 Old 07-01-2004, 07:45 AM
Scrambler82
1982 CJ8
Should work...
The gas is also used to weld steel with a solid wire instead of using Flux Core Wire.
Usually make a better weld.
Luck with the new machine,
Scrambler82
post #7 of 9 Old 07-01-2004, 08:51 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I like flux core.. can use it outside under breezy conditions. Deeper penetration. If you set the heat/wire speed right it doesn't splatter too bad. Plus, it's one less thing to worry about (gas) while welding. This is what I did with flux core (I did use a scraper to remove splatter and slag).
BESRK is offline
post #8 of 9 Old 07-15-2004, 10:45 PM
TellyDSP
Poland and PPV!!!!
I'm currently doing research on welders, and was looking at a 220v(like MM175). I was curious if this would be able to do frame and suspension work(spring hangers, shock mounts, skids). Seems many stick with Lincoln or Miller. Any suggestions for brand? Anyone in MD want to teach me how to weld?
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #9 of 9 Old 07-16-2004, 09:57 AM
Chris_L
I would go with a miller 210 or 250 more welder than you will ever need. check out www.cyberweld.com They have the best prices with no tax [except for jersey] and free shipping. I bought the 210 for around $1100 bucks the 250 was closer to $1400 when I last checked. You will still need to spend close to an additional $300 bucks or so by the time you buy a bottle, fill it and buy wire, gloves etc. And that's not including a nice helmet.
Go to your local metel supply and just buy from their scrap/cut off pile. Usually a buck or two a pound and just start practicing.
Here is the 210 under my plasma cutter. not the best picture. Welder ways about 200 lbs just to let you know up front.
Buggy on 40's
Chris_L is offline
My new welder NORxjCAL Fabrication Shop 8 11-30-2006 12:52 AM
Mig welder franco802 Fabrication Shop 20 02-14-2005 11:08 PM
Best New Welder CreightonRea07 Fabrication Shop 6 12-20-2004 10:17 PM
Which welder to buy? Lore Fabrication Shop 13 11-17-2004 11:28 AM
What welder? Lint Fabrication Shop 15 10-04-2004 07:09 PM
