Need help connecting header to exhaust - JeepForum.com
post #1 of 2 Old 03-16-2011, 02:27 PM Thread Starter
2Xtreme
2Xtreme's Avatar
1979 CJ7
I am having some trouble figuring out how my header is to be connected to the supplied reducer.
The reducer supplied with my Hedman Hedder is similar to these http://www.summitracing.com/parts/HED-21110/?rtype=10
My question is, how do I use it attach the header to the rest of the exhaust system?
Are the reducer flange and fiber gasket sandwiched between the 3 bolt flange and header flange?
Is the three bolt flange supposed to be welded to the reducer? If so, should the reducer pass through the flange? And on which side is it welded- the gasket side (I wouldn’t think this would seal very well) or the outlet side?
Does this setup require an exhaust ‘donut’ (none was provided)?
Thanks in advance!
2Xtreme is offline
post #2 of 2 Old 03-16-2011, 03:08 PM
jpony645
1. Slip the reducer through the metal flange
2. Reducer is welded to the exhaust pipe
3. Slip fiber gasket fits between the header flange and exhaust flange
4. Bolt them together.
jpony645 is offline
best header/exhaust for 4.2 88Blackwrangler Engines & Drivetrain 5 03-01-2005 06:33 PM
New exhaust header for the 4.0l Jeep camperguy Engines & Drivetrain 5 01-28-2004 10:45 AM
exhaust header for 4.0 wildvan Engines & Drivetrain 7 01-03-2003 02:38 PM
exhaust header for 4.0 wildvan Engines & Drivetrain 2 01-03-2003 08:37 AM
Dent in exhaust pipe by header coupler jdfultonii Engines & Drivetrain 2 10-25-2002 08:44 AM
