my roofrack build - Page 2 - JeepForum.com
post #16 of 22 Old 06-25-2009, 10:26 AM Thread Starter
paulmatyn
paulmatyn's Avatar
1992 XJ Cherokee
For the tie down points I used these. I welded the rings themselves directly to the corners.
The engine that you are referring to is a Detroit Diesel 8V-92. It is an older two stroke diesel engine that is mounted to the stand for training purposes.its a really cool engine though because it is turbod and blown! I am going to Palomar Community College to become a diesel mechanic. I have a job in the diesel shop and my teacher/boss let me build the rack there.
Originally Posted by Beefstew View Post
brain guts all over the windshield!!!!!!!!!!!!!!!!
Originally Posted by WillysEdition04 View Post
After reading 7-8 of your posts I've come to the conclusion that you may be mentally retarded, which is why I won't ask what "brain guts" are.
Originally Posted by Duck Dodgers View Post
I'd rather take the chance and belive in God than take the chance and not.
Cuz ya got nothing to lose by believing, but ya sure might if ya don't.
White Jeep Club Member-2027
paulmatyn is offline
post #17 of 22 Old 06-25-2009, 11:06 AM
jgorm
jgorm's Avatar
Time to swap that sucker into the jeep!! nice job on the rack.
jgorm is offline
post #18 of 22 Old 06-25-2009, 10:40 PM
robojeep
1992 XJ Cherokee
what all did you have to do to use the existing roof rack holes for mounting? I've been trying to find info on exactly how the stock rack is secured, and info is hard to come by.
Is it just a simple "remove the rack and screw the new rack back on" or did you have to rip off the headliner to get access to the rack's bolts?
anyway, looks great!
robojeep is offline
post #19 of 22 Old 06-26-2009, 12:16 AM Thread Starter
paulmatyn
paulmatyn's Avatar
1992 XJ Cherokee
With how much power that beast puts out I wish!!! The size is the problem...
For removing the factory rack there are nutserts in the roof itself, and all you need to do is unbolt the factory rails, and use them for the guides for drilling the holes. You should not need to remove the headliner. I did because one of the nutserts was missing, so i had to in order to get the nut to the underside. I used this link on how to make the attachment rails. To achieve the proper curve of the attachment rails i bolted them to the roof, then welded the spacers to the attachment rails and to the rack. To get the right measurements and angles for the spacer i used an angle finder where i wanted to put the spacers since the roof is not level. I cut that angle into one side of the spacer, then cut the other side to the desired height.
If you have any more questions let me know and i will do my best to answer them.
Thanks for all the compliments guys!
post #20 of 22 Old 09-22-2010, 07:49 AM
IAmAmerican
where did ya get the mesh that u have on the bottom of the rack?
IAmAmerican is offline
post #21 of 22 Old 09-22-2010, 08:29 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
The correct term to a steel supplier is Expanded Metal. It usually comes in a 4 X 8 sheet and you choose the size of the gap. Usually 1/2", 3/4" and so on.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #22 of 22 Old 09-22-2010, 08:50 AM
IAmAmerican
Okay thanks man.
Who will build this for me? stunner Fabrication Shop 16 08-04-2009 11:39 PM
suggestion for mounting roofrack flyboy14295 Fabrication Shop 13 03-04-2009 07:36 PM
roofrack out of Galvanized pipe. TwistedcaB- Fabrication Shop 17 02-01-2009 11:01 PM
making a roofrack/light bar TwistedcaB- Fabrication Shop 18 01-02-2009 08:53 AM
Offroad Lights On Roofrack dkongkill General Jeep & Off-Road Equipment 1 11-18-2008 04:59 PM
