My little 9" Press Brake Project - JeepForum.com
post #1 of 42 Old 11-28-2010, 04:44 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
A few months ago, I posted a thread about building a large pressbrake (okay.. not really big but something about 48"-60" or so).. I still intend to build a large brake but I wanted to test the waters with something small.
My short-term goal with this project is to be able to do small production runs of things like Frame Tie In Kits, Spring Perches, Winch Mounting Brackets.. etc.
I used steel laying around the shop and cut everything on my 4'x4' Plasma Table. The plate is 3/8" thick since that's what I had on hand. This project was as much for learning as anything else.
Cost so far...
25 Ton 6" Enerpac Ram.. $360 (used off eBay)
9" Punch/Die set with 3" opening (for 5/16".. off eBay) $180 Shipped
3/8" Plate.. (about 3/4 of a sheet.. about $200)
Nuts/bolts.. $50?.. still need to order
Yeah.. yeah.. I know a little 20ton manual bender setup can be made or mounted in a 20ton shop press for less than $100 and I fully intended to do this with an air/hydro 20ton bottle jack. However, as I browsed around on eBay looking at jacks, I found the Enerpac hydraulic ram for a little more.. and it will work with the power unit from my tube bender.. and it is much faster than air/hyrdo.
I didn't intend to document this so I ended up shooting cellphone pics... sorry.
Total time to draw this up was about an hour or so.. it's pretty simple.. I basically just "shot from the hip" while designing it. In retrospect, I should've done the center (main frame) plate out of 1/2" so it would've fit the dies. However, I was able to mill the "tang" down on the dies to work with the 3/8" plate. If the brake were larger, I would've used a 1/2" center plate. Also, I should've done a center eyelet up top to allow it to be easily picked up with the forklift.. or even cut forklift slots in the framework. This sucker is heavy..
Here's the punch and die that I picked up off eBay..
Here's the Enerpac 25Ton/6" Ram along with the punch holder. I made a small cup for the top of the holder for the ram to seat in and milled a smidgen off the ends
of the plate so it would slide freely between the framework.
Here's the other parts of the punch holder. Basically, a front and back plate will sandwich the punch between them. This particular punch has the "safety tang" on it so I milled a small ledge in the front holder plate to catch that tang and keep the punch from possibly falling out of the holder..
Here's the main frame... 3/8" plate with a pair of feet at the bottom. Also, a small round mounting pad up top for the ram..
These are the front and back "sandwich plates" for the main frame. When they are bolted together, their "windows" are slightly smaller than the main frame's window. That will sandwich the die holder (sort of like a Guillotine) and keep it on track. I milled a smidgen off each end of the center punch holder so it slides in its "groove" freely.
This is my JD2 Model 3 Tube Bender with the hydro conversion. The quick disco on the hose fits both the bender's ram and the press brake's ram.. I may pull the power unit off the bender and mount it on it's own little rolling cart to make it easier to position.
I did a few test bends already (you know I had to). This thing bent 9" of 1/4" plate like it was wet cardboard. I also shoved a piece of 3" wide 3/8" plate in it and it folded that over to a perfect 90deg too. I still need to order all the 1/2" bolts/nuts to bolt everything together. I also need to pick up a few heavy springs to pull the punch up against the ram. After that, I'll make a simple backstop so I can repeat bends.
I've got the pieces all torn apart and painted. I'll reassemble it tomorrow and shoot some pics/video..
BESRK is offline
post #2 of 42 Old 11-28-2010, 04:56 PM
Jim1611
Jim1611's Avatar
Looks good Eddie and it sounds like it's going to do a great job for what you intend. That 20 ton really is bending some pretty heavy material too. I'm looking forward to seeing more of this. Take plenty of pictures too.
I also like the way you got the bender turned on it's side too.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is online now
post #3 of 42 Old 11-29-2010, 07:03 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Any pics of it done?
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #4 of 42 Old 11-29-2010, 07:17 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I took it apart last night to paint everything.. I'll reassemble it this evening and shoot some pics and video of it at work.
BESRK is offline
post #5 of 42 Old 11-29-2010, 08:46 AM
yellow85cj
That is awesome Eddie. Can't wait to see it put together and in action.
Currently in pieces - all of them
yellow85cj is offline
post #6 of 42 Old 11-29-2010, 09:28 AM
jatepper
Clean up that messy shop!!!!!
But yeah, that looks awesome!!!
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #7 of 42 Old 11-29-2010, 11:46 AM
Jim1611
Jim1611's Avatar
Hey Eddie are you going to build a stop for it too? Looking forward to seeing this in action.
My build thread
post #8 of 42 Old 11-29-2010, 01:27 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I thought about using a travel limiter for the hydraulic system but not sure how it would work with the single acting ram. Since the dies are setup for air bending 5/16", they overbend 1/4" a little bit. I'll tinker around with it to come up with some way to attain consistent bends. I noticed with a 1/4" thick bracket, the gap between the material and the bottom radius of the "V" is right at .250" (with the material bent to a true 90deg). I may just drop a length of 1/4" rod down in the "V" to bottom the punch out.
Another option.. since my remote is electronic, I may just put some sort of switch in the system to break the electical contact on the down stroke. The "freespool" button would still work so I can retract the ram.
I also need to make a simple backgauge.
BESRK is offline
post #9 of 42 Old 11-29-2010, 07:34 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Okay.. shot a few more cell phone pics this evening before I closed shop. I shot video but I'm having problems uploading it via mobile connection..
Anyhow.. here's some more pics..
Some samples.. 8" of 1/4" and 3" of 3/8"
BESRK is offline
post #10 of 42 Old 11-29-2010, 07:50 PM
Jim1611
Jim1611's Avatar
Eddie that is going to be one useful tool. Makes nice bends too. Now you just need to come up with a handy place to mount the it. I like it.
My build thread
post #11 of 42 Old 11-29-2010, 08:00 PM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
For the time being, I'm going to put it on the "round table".. a 55 gallon drum..
BESRK is offline
post #12 of 42 Old 11-29-2010, 11:19 PM
Griff97
That's nice and portable compared to a shop press. We were actually playing around with some 3 in wide 1/2 plate on mine yesterday. A 20 ton will actually bend it. We weren't sure.
Griff97 is offline
post #13 of 42 Old 11-30-2010, 08:22 AM
Area.3.Fiftyone
Eddie: You suck.
I wish I had all the equipment that you have to make all of this nice stuff.....
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #14 of 42 Old 11-30-2010, 08:36 AM Thread Starter
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Originally Posted by IronMaiden View Post
Eddie: You Rock!
Hehe.. fixed it for you..
<--You... Me-->
BESRK is offline
post #15 of 42 Old 11-30-2010, 09:42 AM
Area.3.Fiftyone
I wish your shop was closer.
I'd come over and "hold" some of that equipment for you.
48" Press Brake Project BESRK Fabrication Shop 202 03-04-2016 09:20 PM
My DIY press brake JOExFROMxNY Fabrication Shop 8 12-10-2010 08:43 AM
metal shop/press brake help... theGiantPanda Fabrication Shop 9 08-25-2010 11:45 PM
Built a midget press brake flatlander757 Fabrication Shop 13 08-05-2010 11:20 AM
Home-made press brake ChiliPalmer Fabrication Shop 30 01-09-2010 03:16 PM
