My Front Winch Bumper Build Thread - Page 6 - JeepForum.com
post #76 of 91 Old 04-14-2008, 07:18 AM
Darthteddy
1955 M-38
Reminds me alot of http://www.detoursusa.com/zjbackbone.php
Its what ill probably be going with, and one day building a full bumper off of it. Looks good bro.
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline
post #77 of 91 Old 07-07-2008, 09:33 AM
Shelbyzz
Nice Job!! I saw it sitting at the service station on 13 & Lynn when I was driving by and I really wanted to stop and look at your winch, but on the way home your truck was gone - I was so bummed out!! Well now I have pics !! thanks for the write-up!!!
Shelbyzz is offline
post #78 of 91 Old 07-07-2008, 09:37 AM Thread Starter
redhatman
redhatman's Avatar
NICE! Haha thats where I work. Thats why. I am usually there from noon to eight.
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline
post #79 of 91 Old 07-07-2008, 09:44 AM
Shelbyzz
oh cool, maybe I will see it again. Where did you get the welds done? And how did you get up enough balls to cut your bumper cover? I think that will be the hardest part of doing this! I hope to do this very soon!
Shelbyzz is offline
post #80 of 91 Old 07-07-2008, 10:43 AM Thread Starter
redhatman
redhatman's Avatar
I welded the entire thing myself, except where the winch plate meets the brackets which I guess is where it matters the most, and pretty much the only welding besides the d-ring tabs and the light mounts along with the face. I brought it to a place in savage called custom welding, they ran two big beads for $40 and cut out one of the other d-ring tabs.
I got the balls to cut it from spending my ENTIRE spring break day to night on this thing...it had to be done. lol I will maybe finish it off and complete the bumper but not soon. The next thing on my list is probably jumping to 5.5" and 33' tires.
Going to work now, so ill talk to ya later.
-Pat
post #81 of 91 Old 11-03-2009, 12:51 PM
shawnsZJ
1994 ZJ
How is it??
I was wondering how the winch/recovery mount has worked so far. Any problems? Have you used the winch much and how is that winch at pullin your ZJ? I have a 94 ZJ 5.2l and I'm looking at different designs of mounts to make mine from. Any info is great.
Peace Out,
Shawn
shawnsZJ is offline
post #82 of 91 Old 11-03-2009, 09:47 PM Thread Starter
redhatman
redhatman's Avatar
Hey shawn, its been working out flawlessly. Pulled out a few various cars from the ditch, pulled a dakota on 33's on dry pavement and made all 4 tires slide, same with an s10. I have pulled myself out of various situations, as well as a WJ on 35's. Also lots of shrubs for neighbors and small trees. Its working great
-Pat
post #83 of 91 Old 11-04-2009, 12:25 AM
aircruiser
aircruiser's Avatar
yo PLQ your actual offroading winch use moment!
there ya go bud!
aircruiser is offline
post #84 of 91 Old 11-05-2009, 02:12 AM
nightmarezj
im local in mn too! im actually planning on copying your design and making it work.. how did you have to modify the stock bumper to make it fit in the end? is it 2 separate pieces or was there still connecting material in the middle..?
nightmarezj is offline
post #85 of 91 Old 11-05-2009, 04:25 PM Thread Starter
redhatman
redhatman's Avatar
I just cut out the part of the factory bumper to clear it.... Stock bumper is still one piece, connected at the bottom still.
-Pat
post #86 of 91 Old 01-26-2010, 02:34 PM
96liftedzj
nice build man...i wanted to get one of the warn or iceland winch mounts for the front but everyone is saying they are no good...i have access to mig/tig and heli-arc welding equip and can get anything cut/fabbed/welded for free minus steel and hardware. What did the steel run you? Any modifications you would make to ur design if you had to do it again?? I have the kevins rad support too...
96liftedzj is offline
post #87 of 91 Old 02-01-2010, 11:53 PM
eworx
very cool.
eworx is offline
post #88 of 91 Old 02-02-2010, 11:26 AM Thread Starter
redhatman
redhatman's Avatar
Tota cost - winch was right under $100. With all grade 8 bolts, 1.4 steel plate for mounts, and the whole winch mount itself.
If I had to change something, honestly I would not unless I knew I was building a bumper off it later. I have been running this ever since I built it and have no problems with it. I have pulled out a couple cherokees, WJ's, cars from ditches, trucks across pavement. Works like a charm. If I knew I wanted to build a bumper off it later I would have made it a bit taller, to help build the bumper into it.
-Pat
post #89 of 91 Old 05-05-2010, 12:05 AM
Dukota
Just got done with my own winch mount build based upon your plans and it turned out great. Thanks for sharing your build with us.
Whoever dies with the most toys, wins.
Dukota is offline
post #90 of 91 Old 05-05-2010, 08:05 AM Thread Starter
redhatman
redhatman's Avatar
No problem, glad to hear. Now post some pictures!
-Pat
Front Bumper/Winch Plate Build! (pic heavy) MO2500 Fabrication Shop 110 02-27-2013 04:59 AM
ZJ Front Bumper Build Thread jonzj Fabrication Shop 52 12-07-2010 09:30 PM
Lowered (between the rails) winch bumper design/build YJhobby Fabrication Shop 15 02-13-2010 07:02 AM
ZJ Winch Bumper build PICS ezrider327 Fabrication Shop 10 12-23-2007 07:10 AM
New rear winch bumper build dr hook Fabrication Shop 16 04-09-2007 09:55 PM
