My Front Winch Bumper Build Thread - Page 3 - JeepForum.com
post #31 of 91 Old 03-23-2008, 10:58 PM Thread Starter
redhatman
redhatman's Avatar
Thanks for the tips guys, I plan on calling the local welding shop to ask them if they could run some beads for me for a low cost. I am taking a break from the garage right now. Today so far I did as much grinding as I could with the grinding wheels I had left, I got the winch holes lined up. 3 of 4 worked, so I only had to change 1 hole and that was ghetto measuring too lol.
I also got the drivers side 1/2 bolts through so far, and am working on the front tow point right now for the drivers side. Cutting all of this with the wheels sure is a pain, I wonder how much the welding shop would charge me for it oxy cut too....hmmm
Gotta make a trip to northern tool tommorrow for another grade 8 bolt, one of the threads was messed on one. update and pics either tonight or tomorrow sometime.
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline
post #32 of 91 Old 03-24-2008, 11:16 AM
aircruiser
aircruiser's Avatar
hey pat, those wheels should be stocked by today. saturday night when we were closing, recieving was bringing the hardware pallet down so they should be in.
aircruiser is offline
post #33 of 91 Old 03-24-2008, 01:42 PM Thread Starter
redhatman
redhatman's Avatar
Yeah, bought 10 more wheels but I am not going to cut the rest of that thing by myself.
I bit the bullet, talked to the guys at the lws and they said they could cut out the other side and run all beads over for $40 total. Dropped it off, will pick up in the morning. That way I dont have to screw with the angle grinder almost cutting off my nuts another 6 times....Plus it should be a nice clean plasma cut.
-Pat
post #34 of 91 Old 03-24-2008, 11:36 PM Thread Starter
redhatman
redhatman's Avatar
Here is where I got to last night, winch now lines up, 4 1/2" bolts are through both the winch plate and angle, and one side is cut out aswell as a funtional d-ring. Welding shop is in charge of running beads on the entire thing, and cutting out other side. The more feedback the better. Thanks for looking.
-Pat
post #35 of 91 Old 03-24-2008, 11:39 PM
RussoGuitar
1989 XJ Cherokee
are you gonna laminate some more plate onto those shackle mounts?
RussoGuitar is offline
post #36 of 91 Old 03-24-2008, 11:42 PM Thread Starter
redhatman
redhatman's Avatar
Laminate? I am not sure what you mean. I did not have any plans for re-inforcing them if thats what you are asking. My aftermarket tow points are 1/4" just like this so I figured this should be enough to tug the jeep if I cannot get to the front tow points, or if I need to use a hi-lift on the front end.
-Pat
post #37 of 91 Old 03-25-2008, 12:31 AM
aussie stu
i think you'll find that many aftermarket bars have recovery points up to an inch thick......id find 1/4" too thin for that purpose.
Black 98 TJ / 4.5" Coils / 1" BL + MML / 4.56 / 35's Silverstones MT-117 on 16 X 8's / D44 & ARB Airlocker / D30 & lockright / Rocklights / wind sheild IPF's / Custom WARN rear tyre carrier / extended brake lines / Custom Triangulated 4 link long arm / Front adj. panard (no rear) / rear storage draw system / OBA / AA SYE / Bestop duster, windjammer, bikini combo / Bushwackers flares / UHF / TBS / Wilderness Rack / 3" stainless steel snorkel / T-Max 9000 6HP winch
aussie stu is offline
post #38 of 91 Old 03-25-2008, 03:35 AM
ChrisYJ - Italy
I agree i wouldn't like to be pulled out with those recovery points. 1/4 it's perfectly beef for a bumper's surface, but imho not enough to stand the loads of a recovery. Better be safe than sorry, remember that a failure while recovering can get EXTREMELY dangerous
That said, you'r doing some good job, thumbs up for you!
ChrisYJ - Italy is offline
post #39 of 91 Old 03-25-2008, 08:45 AM Thread Starter
redhatman
redhatman's Avatar
So basically you are telling me that every single aftermarket ZJ bumper is unsafe.
Bumpers that I know of that use 1/4" are Kevins, CRB, Nates4x4, aswell as anyone that makes a custom one. I have NEVER seen one thicker than 1/4". Then you say, "No pat, i'm talking about tow points" The weakest link is where it will break, unless its all 1/2" it doesnt matter. Its like making a nice paper bumper, and using cardboard tow points. What will break?
-Pat
post #40 of 91 Old 03-25-2008, 09:59 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Man, I was loving that bumper up untill the d ring points. Go back and look at all of those aftermarket bumpers. The 1/4" stuff is used for the bumper itself BUT d ring mounts are usually 3/4"-1" THICK PLATE welded thru the bumper.
Not harping on you man, just stating that 1/4" plate is nowhere near enough material to pull with.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #41 of 91 Old 03-25-2008, 10:44 AM
mcneil
Just a quick hand calculation on your shackle mounts (assuming that's a 1" dia pin)
Check bearing area and stress: 1" dia pin x .25" thick = .25" bearing area
Assuming mild steel (conservative yield of 40,000 psi), that means a max load of 10,000 lbs before bearing failure (ie, shackle pulling through the hole).
That's a straight pull, pulling at an angle is going to reduce that by around half, so say 5,000 lbs.
Well, I wouldn't sling load off those, but they'll probably work for most recovery use.
mcneil is offline
post #42 of 91 Old 03-25-2008, 12:43 PM
aircruiser
aircruiser's Avatar
yeah i agree with everyone else, i aint pulling you out with those. i like my rear window glass un-shattered.
so whats the plan for the bumper now? still gonna cut up the stock one or what?
post #43 of 91 Old 03-25-2008, 01:14 PM Thread Starter
redhatman
redhatman's Avatar
Either way, I have front tow points. I am not going to cut these off, I might aswell just leave them on now. Both are cut, back from welding shop, just need to drill one more d-ring hole and then do the cosmetic stuff.
Everything else looks good though?
-Pat
post #44 of 91 Old 03-25-2008, 02:00 PM
USMCredneck
1979 CJ5
Looking good so far. I have to agree with everyone else about the shackle mounts. If you aint going to cut them off how about adding some steel and making them thicker?
79 CJ5. 258, T-18A, D20. 33s
08 Dodge Ram 3500 DRW DD/tow rig
USMCredneck is offline
post #45 of 91 Old 03-25-2008, 02:10 PM
97zjjeeper
97zjjeeper's Avatar
looking good man
Tater
BLACK 97 ZJ 4.0L-42re-242-DANA 30/35 (3.73)
MODS) 2in lift-30x9.5x15 BFG A/T-15x8 Pacer Wheels-K&N Intake-1in TB Spacer-40Series Flowmaster-Hi-Flow Cat-JKS Trackbar-Sliderz-BDS adj CA-BDS SS-Cobra19 ULTRA III-FireStick4FT-PA Horn-Hella500 DL-Roof Rack-TC Skid-Gastank Skid
97zjjeeper is offline
Front Bumper/Winch Plate Build! (pic heavy) MO2500 Fabrication Shop 110 02-27-2013 04:59 AM
ZJ Front Bumper Build Thread jonzj Fabrication Shop 52 12-07-2010 09:30 PM
Lowered (between the rails) winch bumper design/build YJhobby Fabrication Shop 15 02-13-2010 07:02 AM
ZJ Winch Bumper build PICS ezrider327 Fabrication Shop 10 12-23-2007 07:10 AM
New rear winch bumper build dr hook Fabrication Shop 16 04-09-2007 09:55 PM
