My front bumper build - Page 3 - JeepForum.com
post #31 of 48 Old 09-26-2008, 08:54 PM Thread Starter
raskull
raskull's Avatar
Originally Posted by BlueTorch View Post
saw this over on Pirate.... nice bumper. Keep up the good work.
Dan
Thanks again! :P
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #32 of 48 Old 09-26-2008, 09:00 PM
YJSXJ
1993 XJ Cherokee
yea man, real nice
YJSXJ is offline
post #33 of 48 Old 09-26-2008, 10:40 PM
flatlander757
I REALLY like that front bumper
Can I see some pics from the back side of it to see how the shackle mounts are situated inside the bumper "shell?"
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #34 of 48 Old 09-27-2008, 03:04 AM
fratis
fratis's Avatar
-like this.
i like very little i see from home builders, don't like most catalog stuff. theres no quadratec "accessories" on my jeep. im a minimalist. but this i like very much. great work. i know how hard and time consuming this is to do at home.
-leave it be and skip the hoops. just a personal opinion. those are lame unless on the most hardcore wheeling machines where the stinger is long enough to be functional and the hood hoop is tall enough to do what its supposed to do.
fratis is offline
post #35 of 48 Old 09-27-2008, 09:12 AM
Speed911
How much would you build me one for? haha Looks great!
-Dane
Speed911 is offline
post #36 of 48 Old 09-27-2008, 09:25 AM Thread Starter
raskull
raskull's Avatar
Originally Posted by fratis View Post
-like this.
Well, my rig is only on 31's and I completely agree with you. A grill hoop and stinger don't look good on smaller rigs.
However I plan on going to at least 37's so the grill hoop and stinger will get built. It's going to be all function, not a huge boner bar on the front. Here's an idea of what I'm getting done.
The guy that built that rig will be doing my grill hoop and stinger and I plan on getting it pretty much exactly the same as his.
I'll send you a PM.
(O|||||||O)
l_l*-----*l_l
raskull is offline
post #37 of 48 Old 09-28-2008, 11:38 AM
flatlander757
Currently Jeepless.
post #38 of 48 Old 09-29-2008, 07:38 PM Thread Starter
raskull
raskull's Avatar
They are not inside at all. They are surface welded directly in front of the frame ends. Inside there are 1/4 doubler plates welded in, effectively making the tabs welded to a 7/16" plate.
Here are a few pictures of it mounted.
Don't mind the ****ty broken winch or the cables hanging.
(O|||||||O)
l_l*-----*l_l
raskull is offline
post #39 of 48 Old 10-02-2008, 12:34 PM
drerict
1983 CJ7
looks good
drerict is offline
post #40 of 48 Old 10-02-2008, 12:44 PM
Island4x4
looking good man. nice smooth edges
God is good to the Irish because nobody else is.
White Jeep Club Member # 1337
Island4x4 is offline
post #41 of 48 Old 10-02-2008, 02:52 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I like it. Like I said, I'm going to use some of your ideas eventually when I make a new one for mine in a month or so. 1/4" top, 3/16 front and bottom, D ring spots with the reinforced back like you did (good Idea). But i'm going to leave the sides open for my antirock.
what I think would be really cool, and a very clean install would be to cut the front cross member out and lower the winch into there, but I don't want to cut the crossmember out so i'm not going to do that.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #42 of 48 Old 10-06-2008, 12:59 AM
jboy416
Wrangler
jboy416's Avatar
looks good. rokmem make a bumper just like that. the mercenary GT
jboy416 is offline
post #43 of 48 Old 10-09-2008, 09:00 AM Thread Starter
raskull
raskull's Avatar
Yeah I had plans of doing a recessed winch plate, but I didn't want to raise the height of the sides to achieve that, so I just made it flat. If you keep the middle at normal height, and raise the sides to make it look like a recessed winch plate, you would get better tire clearance. But I really doubt I will be able to hit a bumper with my tires when the bumper is only 38" inches wide anyway.
(O|||||||O)
l_l*-----*l_l
raskull is offline
post #44 of 48 Old 06-02-2010, 10:54 PM
bliberty_21
Originally Posted by raskull View Post
Redesigned from the ground up. Let me know what you think..
Of course the stepped looking corners on the sides would be filled with weld and ground smooth.
The little hook at the top of the stinger is for your winch cable when not in use.
This drawn up in some sort of CAD program i assume. Can i get the dimensions for it or no? I was thinking of building my own but having a hard time starting to project. Thanks
bliberty_21 is offline
post #45 of 48 Old 06-03-2010, 07:20 AM
cgmrdc
1988 MJ Comanche
its on his website, scroll down to the bottom of the home page and you will see the write up. then click the link to the gallery
cgmrdc is offline
My Front Bumper Build timmytimm3 Fabrication Shop 7 05-22-2009 06:50 AM
Front Bumper build.. Dmax5er Fabrication Shop 45 11-04-2008 09:51 PM
Need Help, First front Bumper Build. Tkahne88 Fabrication Shop 12 09-08-2008 10:36 PM
Another front bumper build. DogHouse Fabrication Shop 10 06-04-2008 07:37 AM
Front Bumper Build Matt in TN Fabrication Shop 9 01-20-2007 01:17 PM
