My front bumper build - Page 2 - JeepForum.com
post #16 of 48 Old 05-13-2008, 06:55 PM
Jebussaves0
What CAD program is that, AutoCAD? I'm more proffecient with Autodesk Inventor myself but don't like the way it models and draws tubing.
Jebussaves0 is offline
post #17 of 48 Old 05-21-2008, 07:02 PM
Brads_nky_yj
wow definatly nice work man, this is something I plan on doing myself. How long is the bumper from end to end? I know you said 3 inches past the frame on each side, but how long in total?
93 YJ - SOLD
Brads_nky_yj is offline
post #18 of 48 Old 05-22-2008, 08:52 PM
XJRidinHigh
Why not just use Viz or 3dStudioMax? I havent tried using Inventor, but I may because I have a project to do of my choice and a bumper would be a nice idea. Idk if I should use Viz or Inventor
Anyways, nice bumper, Im hoping I can make one with the help of a friend (Im not skilled in the field of welding and crafting with metal)
'95 XJ-Hunter Green
3.5" RE Superflex with OME shocks, 31" (movin up to 32")Mud Country on Soft 8's
'00 WJ-Tan
Cocked and Loaded (DD)
XJRidinHigh is offline
post #19 of 48 Old 05-24-2008, 08:23 AM
QUINNMOTORSPORT
very nice work cant wait to see it done some great ideas there well thought out. my fab guys building a few for mine i will take some picks when done also and post. and love the cad work!!!
QUINNMOTORSPORT is offline
post #20 of 48 Old 07-17-2008, 06:03 PM Thread Starter
raskull
raskull's Avatar
It's google sketchup. Free and easy to use (after a few video tutorials).
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #21 of 48 Old 07-19-2008, 04:05 PM
nic99007
so how did it turn out???
inquiring minds want to know??
nic99007 is offline
post #22 of 48 Old 07-19-2008, 05:01 PM Thread Starter
raskull
raskull's Avatar
Hehe to be honest I haven't started yet. I just finished the rockers this week so I will be starting right away.
(O|||||||O)
l_l*-----*l_l
raskull is offline
post #23 of 48 Old 07-30-2008, 09:51 PM Thread Starter
raskull
raskull's Avatar
Just a quick update to this. I did up some exploded drawings of it this week, The full thing can be seen here: http://myjeeptj.com/pics/2008.07.28_...mper_final.jpg
I also made a .100" aluminum template at work for the top plate. I took off my bumper, winch, lights and sway bar, and the whole thing fits like a dream. The eight bolts in the top plate all bolt directly to the frame. 4 to the stock tow hook locations, and the back 4 to the sway bar bolts.
The four smaller holes in the middle are for a winch mount.
edit: I know it looks a little bit like a jumbled mess, but once you zoom in on the drawing some more in google sketchup it's all legible.
(O|||||||O)
l_l*-----*l_l
raskull is offline
post #24 of 48 Old 09-13-2008, 10:52 PM
YJSXJ
1993 XJ Cherokee
been a while. .................................................. ....
YJSXJ is offline
post #25 of 48 Old 09-20-2008, 03:33 AM Thread Starter
raskull
raskull's Avatar
Yup... but.....
Just finished off the front bumper for the heep today.
I just need to get the tube work done when I can make a trip down to Sylvan Lake to visit Brink_.
I cut the plate out, and drilled holes in all the corners of the cut-outs. I then connected the "dots" with a zip disc on a grinder, then made it look nice with a die-grinder. Big pain in the ***, but it's worth it for the pretty holes.
I had it all tacked together for a test fit.
Ok, fits good! Took it off to weld it, and put it on the jeep again to use a bumper until I work on it again.
Made the clevis tabs out of 1" thick QT100 plate, drilled 1" holes in them and welded them on, and welded up the whole bumper. I then spent a bunch of time cleaning up all the welds and spatter.
All done now but the paint and the 4 holes for the winch mount. The top plate that the winch mounts to is 1/4", the fairlead mount and formed bottom is all 3/16". There are also 1/4" doubler plates inside, opposite to where the clevis mounts are welded on for extra assurance.
The winch plate is not removable obviously, which means you have to remove the bumper to get the winch off. This is by design so it doesn't get stolen.
You can see the full gallery of images here: http://myjeeptj.com/wpg2?g2_itemId=13496
Let me know what you think, it's my first crack at a bumper, but I do work as a press brake operator so I know this stuff pretty well. The design is similar to the one from SniperFab, but it's designed from scratch by yours truly. I got a ticketed welder in the shop to do the welding for me.
(O|||||||O)
l_l*-----*l_l
raskull is offline
post #26 of 48 Old 09-21-2008, 11:04 AM
YJSXJ
1993 XJ Cherokee
i say pretty nice. even on all the welding and stuff, nice clean up
YJSXJ is offline
post #27 of 48 Old 09-21-2008, 01:29 PM Thread Starter
raskull
raskull's Avatar
Quick little write-up on the bumper is up on the site.
http://myjeeptj.com/2008/09/20/custom-front-bumper
(O|||||||O)
l_l*-----*l_l
raskull is offline
post #28 of 48 Old 09-21-2008, 01:34 PM
Lostj
Lostj's Avatar
what do you use to smooth the welds?
00'TJ
74'CJ5 For Sale
Lostj is offline
post #29 of 48 Old 09-21-2008, 02:02 PM Thread Starter
raskull
raskull's Avatar
A 5" grinder. Grind first, then I used a 60 grit flap disc on the grinder.
(O|||||||O)
l_l*-----*l_l
raskull is offline
post #30 of 48 Old 09-26-2008, 10:36 AM
BlueTorch
saw this over on Pirate.... nice bumper. Keep up the good work.
Dan
Blue Torch FabWorks, Inc.
205-521-7333 OR 866-RCK-CRWL
Check out our Facebook fan page!
[SIGPIC][/SIGPIC]
BlueTorch is offline
My Front Bumper Build timmytimm3 Fabrication Shop 7 05-22-2009 06:50 AM
Front Bumper build.. Dmax5er Fabrication Shop 45 11-04-2008 09:51 PM
Need Help, First front Bumper Build. Tkahne88 Fabrication Shop 12 09-08-2008 10:36 PM
Another front bumper build. DogHouse Fabrication Shop 10 06-04-2008 07:37 AM
Front Bumper Build Matt in TN Fabrication Shop 9 01-20-2007 01:17 PM
