My flat skid build - JeepForum.com
post #1 of 72 Old 09-16-2008, 10:17 AM Thread Starter
PBR
PBR's Avatar
My flat skid build
I have a 2000 Wrangler and im in the process of building a flat skid I have all the materials to start but being at school really limits my time. Ill try and do a write up ASAP.
Heres a pic of the tabs I made for the bushings.
PBR is offline
post #2 of 72 Old 09-16-2008, 10:45 AM
LittleBee
good luck
LittleBee is offline
post #3 of 72 Old 09-16-2008, 11:43 AM
Bigbob
Bigbob's Avatar
Are you planning on using the bushings on the frame side as in the outside?
I always worry about that. To me a proper mounted power plant is triangulated as in 3 points of contact. As the frame twists with a 4 point mount something has got to give. The power-plant also twists in the frame. As you apply torque to the drive line the engine and trans "rocks" in the cradle. Just my 2 cents worth.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #4 of 72 Old 09-16-2008, 11:58 AM Thread Starter
PBR
PBR's Avatar
Im going to mount the bushings inside the frame rails and going to run a piece a tube across to each one to mount my trans to. Im going to get rid of the trans mount since I have both those poly bushings. I talked to the guys on pirate and blue torch fab and they say it should work great if I have poly motor mounts, which I do.
PBR is offline
post #5 of 72 Old 09-16-2008, 08:30 PM
Scotch740
Scotch740's Avatar
Nice, look forward to this as I have been considering something similar.
What are you doing for the lines down the driver side, have you already relocated them?
Whats the cross memeber's location going to be in relation to the bottom of the frame rails? Also is it going to be one continuous tube or are you going to have it meet a plate in the middle?
And I know how it is being at school without tools, I miss my welder
What are you using to plate it? Should look for some aluminum and oil impregnated UHMW.
Scotch740 is offline
post #6 of 72 Old 09-17-2008, 06:40 PM Thread Starter
PBR
PBR's Avatar
Yeah i have to do something with the lines running down the drivers side frame rail. But hopefully ill be lucky and not have to do much to them. I hoping to just run the tube strait across and not have to bend it with a plate holding the trans.
I got 3/8" hot rolled now since I got it for free. But if I can get some 1/4" aluminum plate for free Ill deffently be replacing it with that!!
PBR is offline
post #7 of 72 Old 09-20-2008, 07:47 PM Thread Starter
PBR
PBR's Avatar
UPDATE:
Well today just for fun I unbolted the four bolts holding the mount to the stock skid and jacked is up to see how much clearence I would have and to look at my driveshaft angle. Also While doing this i noticed I can still use my tranny mount. The only thing im worried about is my driveshaft length.
PBR is offline
post #8 of 72 Old 09-23-2008, 02:15 PM Thread Starter
PBR
PBR's Avatar
heres a pic of the skid sheared up. 5/16" plate
PBR is offline
post #9 of 72 Old 09-26-2008, 08:57 PM
raskull
raskull's Avatar
Wow that's a heavy skid. I guess it's weight down low so that's good.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (
<- Write-ups on mods/maintenance/trips and a video/image gallery
raskull is offline
post #10 of 72 Old 09-26-2008, 10:08 PM Thread Starter
PBR
PBR's Avatar
yeah its VERY heavy!
PBR is offline
post #11 of 72 Old 09-26-2008, 10:56 PM
dennis690
I made a cross member almost the same as you are doing. When I installed a Klune V I used the Klune mount as the main attach point. So far it's worked great.
I used the old mounting locations for the skid just made the skid longer. I had to cut a slot for the front drive shaft (not in this picture) It's 1/4" plate.
92 YJ on 35s
dennis690 is offline
post #12 of 72 Old 09-26-2008, 11:00 PM Thread Starter
PBR
PBR's Avatar
whoa very nice! I like the crossmember set up of having the bushing soild mounted and just the bar unboltable. hows that work for ya. why didnt you make the bar and bushings unboltable?
To me the way you did it seems sooo much easier than the way i was thinking of doing it! I will be thinking this over hopfully ill have my mind made up by the time it comes to weld it all up.
Another thing is i hope i dont have to make any exhaut modifications!!
PBR is offline
post #13 of 72 Old 09-27-2008, 02:55 AM
fratis
fratis's Avatar
can you please explain this a bit further im not quite following with reference to the picture previously supplied. triangulated 3 point vrs. 4 point. are you including the motor mounts in this? not trying to be combative at all just trying to follow your suggestion more thoroughly.
fratis is offline
post #14 of 72 Old 09-27-2008, 09:09 AM
dennis690
I actually got the idea from JP Magazine's "Project Hot Dog". Mine is different but similar. The reason I didn't make the mounts unboltable is there isn't a clearance problem with them welded in place and it was easy to do that way. I would expect for you to need some minor exhaust mods to clear the crossmember when you raise it.
92 YJ on 35s
post #15 of 72 Old 09-28-2008, 03:47 PM
Dean-
looks nice and clean... well done
99' WJ Limited- 4' IRO Lift, 32' BFG's on Moabs....
Dean- is offline
Bracing flat TC skid Scotch740 Fabrication Shop 16 10-09-2009 06:07 AM
Flat TC skid Kerndone Fabrication Shop 79 10-08-2009 07:22 PM
Gas Tank Skid/Flat Belly Skid Stan99 Fabrication Shop 18 01-23-2009 11:06 PM
How to flat skid? PBR Fabrication Shop 5 07-07-2008 07:21 PM
Flat Pan Skid Plate...FOR TJs Viet15philong Fabrication Shop 11 10-12-2005 05:35 AM
