-   Fabrication Shop (http://www.jeepforum.com/forum/f37/)
-   -   My first fab work on my TJ (http://www.jeepforum.com/forum/f37/my-first-fab-work-my-tj-440542/)
Dragon158 07-21-2007 07:37 PM
I bought a wilderness roof rack for a good price from the sale section here. It needed paint and a good cleaning. I had no instructions, so I searched the web and found a site where a guy did an install and showed the original instructions. Then I realized the instructions said I had to drill 6 holes in the body. I really didn't want to do that, so I made this. Pretty simple, just figured I'd share... In the future when I build my rear bumper I'll make a bolt on receiver, which will end up looking a lot better.
http://i33.photobucket.com/albums/d5...n/100_1149.jpg
http://i33.photobucket.com/albums/d5...n/100_1150.jpg
http://i33.photobucket.com/albums/d5...n/100_1151.jpg
http://i33.photobucket.com/albums/d5...n/100_1153.jpg
Kornik 07-21-2007 07:50 PM
click free...
BESRK 07-22-2007 06:15 PM
Nice.. how much weight do those things hold?
Dragon158 07-23-2007 10:55 AM
Not sure, but the thing is pretty damn sturdy. I'll check the instructions and see if they have a load limit. The thing complete weighs close to 100 lbs., so it seems it will hold a decent amount.
Burbo 07-23-2007 12:54 PM
Is there room to drop the soft top with it on there?
TJ-Marine PA 07-23-2007 01:35 PM
I'm guessing no.
Dragon158 07-23-2007 10:50 PM
The uprights are mounted tightly, to drop the top I need to remove 2 of the 4 bolts. (There are 4 bolts holding the red section on, 1 over each upright.) The rack came with props to hold the upper section, so I can lower the top. It takes an extra few minutes to do and isn't too bad to do alone. I may modify it later with hinges or something, kind make it lie the Dave rack thing...
Dragon158 07-24-2007 09:41 AM
Ok, posting a little more info for user M60-E4, he pm'ed me asking for some more pics and measurements. I also found a link to a step by step install.
Step by step instructions @ 4x4 Icon
Scans of actual instructions for rack
This is how the rack will lift if you drill through the body, the instructions state that you need to drill 3 3/8" holes on each side, 6 all together.
http://www.4x4wire.com/reviews/warack/dcp00950.jpg
I fabricate my own mounting bracket to avoid drilling through the body. So in order for me to lower the top I need to remove the 2 front bolts, like in this picture below.
http://www.4x4wire.com/reviews/warack/dcp00952.jpg
With the way I mounted it, I am able to adjust the height. M60-E4 asked what the height in the rear was, for me to clear the top at the center bow I am about 50 & 1/2" from the top of the factory bumper. I would assume it would be around the same height if you did the drill and the install as per the instructions. The height in the front is around 4", give or take a little. The rack isn't exactly level, the *** of my Rubicon sits higher, so I adjusted the rear so it's at around the same pitch as the rig. I wasn't able to find a load rating, but I feel it would be more then what I'll be putting up there. The rack feels very strong, and I've only mounted the rear with 1 bolt per side. I plan on adding an additional bolt per side when I fab my new rear bumper and tire swing. Here are some more pics, if someone could click free them for me, that would be great.
http://i33.photobucket.com/albums/d5...n/100_1176.jpg
http://i33.photobucket.com/albums/d5...n/100_1172.jpg
http://i33.photobucket.com/albums/d5...n/100_1171.jpg
http://i33.photobucket.com/albums/d5...n/100_1170.jpg
http://i33.photobucket.com/albums/d5...n/100_1169.jpg
http://i33.photobucket.com/albums/d5...n/100_1168.jpg
http://i33.photobucket.com/albums/d5...n/100_1166.jpg
http://i33.photobucket.com/albums/d5...n/100_1165.jpg
Dragon158 07-24-2007 09:42 AM
http://i33.photobucket.com/albums/d5...n/100_1144.jpg
http://i33.photobucket.com/albums/d5...n/100_1164.jpg
http://i33.photobucket.com/albums/d5...n/100_1167.jpg
These are the brackets that you'll use if you drill through the body. The large hole goes through the body mount.
http://i33.photobucket.com/albums/d5...n/100_1178.jpg
http://i33.photobucket.com/albums/d5...n/100_1177.jpg
This last one is a pic of what I was working on yesterday while taking the picture at work. ;)
http://i33.photobucket.com/albums/d5...n/100_1160.jpg
Any questions, feel free to ask. I'll post again when I build the rear bumper and rack receiver, sometime in the next few months.
Kornik 07-24-2007 09:45 AM
click free... :-)
Kornik 07-24-2007 09:47 AM
and again :-)
BESRK 07-24-2007 10:31 AM
Now you need to rig up some linear actuators so that you can undo a couple latches, push some buttons and fold it down... zzzzztt.. :D
Dragon158 07-24-2007 03:48 PM
I was actually thinking of rigging some hood struts up, but it would probably look ghetto.
The time now is 05:27 PM.
