My custom rocker guards w/ tube steps are done!
| Truck-Lite's New LED Headlamp Series | CURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee! | Poison Spyder DeFenders™ - "Tubeless" Jeep Fende |
#1 | |
Well they are finally nearing completion. Primed them last night, putting on paint tonight. They are formed 3/16" plate with 1.5" .120 wall DOM tubes. The tubes are mounted at an upward angle of about 20 degrees, and the tubes are fully tig welded.
Watch for a full write-up on them on my site sunday or early next week. Here's a couple pics. ![]() Sexy tig welds! ![]() ![]() ![]() 2nd coat of primer: ![]() ![]() Sandwich plates. ![]() The final paint colour will be what I like to call "Nth Degree Grey". ![]()
(O|||||||O)
l_l*-----*l_l Raskull - Metallic Silver '03 Jeep TJ Sport (pic) http://myjeeptj.com <- Write-ups on mods/maintenance/trips and a video/image gallery Custom front bumper build Custom rockers build My build thread |
#2 |
Look good... That is a mean machine in the back ground.... 500 2 stoke..
That would make a bad *** supermoto... |
#3 | |
(O|||||||O)
#4 |
WEAK! Just kidding, those are seriously heavy duty. Put me on the list for some!
#5 |
Thats the 1st thing I saw too...It looks alot like mine, sitting in the corner on a stand that is...Nice work by the way, they look good...
1974 CJ5, 2004 RUBICON, AND THE WIFES 2006 GRAND CHEROKEE SRT8... |
#6 | |
It's my first set and I could likely half the time for the second set, but it would still not be worth it. total cost of them is: 5'x10' 3/16" plate from work - $200 DOM tubing incl. bending - $40 Hardware (fasteners) - $11 (bolt supply gives me a discount because of where I work) Paint - $35 26er of Baileys for my buddy who did the welding - $28 Granted there is still lots of steel left.. enough for front and rear bumpers, so the actual cost of the steel for this set was about $60-70. So, with that in consideration, the total cost is: $184 CDN. And I would guess about 30 hours labour.. $50/hour $1500. :P ![]() All the cutting, forming, drilling, tube notching, hole cutting, counter sinking, punching etc was done mostly with shop tools for free. ![]()
(O|||||||O)
#7 |
Great Job. I really want to get my shop finished so I can do some more Fab work.
~Joe~ 2009 Wrangler Unlimited X(my woman's ride) 2002 Wrangler Apex Edition(with lots of goodies) 1970 Jeepster Commando(a work In progress) |
#8 |
Ok, they are really done now. I got the stainless hardware I needed for the sides, and picked up some Clear Outdoor Acrylic caulking to seal them up. I talk about this more in the write-up here.
I made new sandwich plates for the insides because a couple didn't fit right. I also went ahead and made sandwich plates for the sides too, which is something I have never seen in an aftermarket set.. so NYAH-NYAH to all them! For the paint I did 3 coats of primer and 3 coats of paint. I learned a few things about paint this time around.. 1: 3 coats is "enough" but I would prefer 5 or more. The paint is still fairly thin, but I assume I will need to touch it up on the bottoms after using them offroad no matter what, so this is not a big deal. 1: Get a paint can trigger thingy.. Something you attach to the top of the can that adds a handle and trigger. My fingers hurt real bad after all that painting, and that would have made it much easier. Maybe it's just Tremclad.. but the nozzle is pretty stiff. 2: Painting inside gaps is hard. the paint is really thin on the part of the tubes that face the body because it was hard to get in there. If I was prepared better I could have hung the rockers so I would be able to spray better at that angle. 3: Glyptal is CRAZY stuff. It dries to an almost rubbery finish at first, and takes about 72 hours to dry completely to a hard-ish finish. When I coated the inside of the stand-offs with it it made a huge mess. I regret not preparing more (tape tape and more tape) for this step, but I am really glad I did because there's no better way to coat inside something like that. After I learned my lesson the 2nd rocker went a lot smoother than the 1st. 4: 12 hours from final coat to install is not *near* enough time. I knew the paint wouldn't be fully set yet, so I was careful.. but I still messed up the paint pretty bad in a few places. especially where the counter sunk bolts sit. I will need to remove the bolts, mask off and repaint those later. I can't remove the rockers from the jeep anymore because they are glued on with acrylic and I don't want to try to clean that up if I remove them. Next project I do the paint will sit for 48 hours+ before I touch it. Some other lessons learned: 1: Cut the holes in the stand-offs before welding them to the rockers. I could have just put them in a drill press.. once they were welded to the rockers, it was too much of a pain to drill them so I used a plasma torch. This worked ok because I found the right setting that would burn through the 1st layer, but not the 2nd... but it made a nasty mess inside. 2: While 1" seems like enough space between the tubes and rockers, it's very difficult to weld. It's great because I don't get the back of my leg dirty every time I hop out of the jeep, but it's very hard to weld properly. I'm very pleased with the results. Cows are less beefy. They look good, work great as a hi-lift point, and will perform great offroad. Here's a few more pictures. Old hardware (before I got the stainless outside bolts) ![]() ![]() ![]() Sandwich plates including the new side ones, and the new hardware ![]() ![]() ![]() Clear Acrylic to seal them ![]() All done! ![]() ![]()
(O|||||||O)
#9 |
i vote paint them black
For info on outdoor adventures in South Carolina check out OffroadSC.com |
#10 |
you wouldnt happen to have any drawings of them would you? how about pics of the underside?
if not what was the length and width of the pre-bent plate?
#11 |
The plate flat was 53 1/16" x 14 7/16".
Marking the bend lines from the tops, they would be 5 7/8" (60 degree bend) and 8 7/8" (30 degree bend). If I can manage to beat this laziness I could draw it up for you. No pics of the underside.. I'll go snap a couple, just a min. edit: Ok.. got some pics and a drawing for you. ![]() ![]() ![]() And the drawing (click here for a fullsize version). ![]()
(O|||||||O)
l_l*-----*l_l Raskull - Metallic Silver '03 Jeep TJ Sport (pic) http://myjeeptj.com <- Write-ups on mods/maintenance/trips and a video/image gallery Custom front bumper build Custom rockers build My build thread Last edited by raskull; 07-28-2008 at 07:36 PM.. |
#12 |
those are better looking than many production sliders, good work. But why the Nth degree gray?
-Morgan '00 Silverstone 2 Door XJ Utah Jeep Crew Member #119 My Webshots New Build Old Build |
#13 |
Those are Bad Azz....
Great work man! Thanks again for the write up! Oh and the template. I Saved that baby...
Lifes a Jeep! Wheel IT! |
#14 |
Damn, those are nice. Great build, and fab work!!
Stay out of the damn waterways and creeks!!! http://treadlightly.org Gubbament Cheese is the best! |
#15 | |
VERY nice. I wish I had skills like that!
Green Jeep Club Member #183 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
