Mounting Tabs for D rings? - JeepForum.com
post #1 of 10 Old 05-19-2004, 09:59 AM Thread Starter
Birdlaw
Birdlaw's Avatar
2014 JK Wrangler
I am building a set of bumpers. Garden variety out of 3/16th rectangular tubing.
Where on the bumper would you mount tabs for d rings as far as strength is concerned?
I am going to mount them through the bumper(cut slot and weld from both sides), but should I mount them as close to the frame tie-ins as possible, or would further out be OK?
Any other suggestions appreciated.....
Thanks,
J
98 Sport- 4.0 5 Speed
Garmin GPS
Black Labrador Retriever as Spotter
Black Jeep Club Member #46
CERTAIN DEATH JEEP CLUB MEMBER # 16
Dumb A Jeep Club Member # 6
Birdlaw is offline
post #2 of 10 Old 05-19-2004, 12:41 PM
dzp
dzp's Avatar
Closer to the frame mounts the better.
What material are you planning on using?
Tyler, Texas
97 TJ, Red, 33" MTR's, Locked F/R, D30/Ford8.8, JKS Disco's, DT3000's, tinted Sailcloth top, 8k Ramsey, Custom bumpers/armor, Ramps 890 on 25degree ramp.
dzp is offline
post #3 of 10 Old 05-19-2004, 02:11 PM Thread Starter
Birdlaw
Birdlaw's Avatar
2014 JK Wrangler
2x4 rectangular tubing. 3/16 wall.
I already have the bumper cut and the corners cut (not very original, but I like the look).
I am welding a 1/4" plate along the top of the bumper to use as a mounting plate. I will cut 1/4" tabs to use for the bottom mounting tabs.I am thinking about 1.5" wide and long enough to give me about a 1/2 all aroung the bolt hole. That is for the front.
The rear is the same deal except that the mounting brackets are sections of the 2x4 stock welded to the bumper and bolted into the crossmember with a 1/4" frame tie-in bracket that I have yet to make. The tire carrier hinge is a 1" trailer spindle with trailer bearings inside a 2" pipe section. a 1x3 rectangular tube will be coped and welded to the outside of the pipe with the bearings. The tire carrier will be 1.5" square tubing braced with angled supports and a triangular brace out is 1/4" plate if needed. I still don't have a latch yet, but I remember a thread on latches. I am also welding a reciever tube into the bumper with 1/4" angled braces behind the bumper.
I can't weld too well yet, but I am improving. Plus I only have about $120 in it so far and I am having a blast doing it.
Suggestions?
Garmin GPS
Birdlaw is offline
post #4 of 10 Old 05-20-2004, 07:13 AM
dzp
dzp's Avatar
Sounds good. Be paitent and the welding skill will come.
I use 3/4" x 2" flat bar for the clevis tab. Hole is 7/8" for the shackle.
Do a search for the differences btwn D rings and Shackles. D rings are solid, where Shackles have the removable bolt.
Tyler, Texas
dzp is offline
post #5 of 10 Old 05-21-2004, 07:39 AM Thread Starter
Birdlaw
Birdlaw's Avatar
2014 JK Wrangler
ooops....how about a d-shackle?
Thanks Zach!
Garmin GPS
Birdlaw is offline
post #6 of 10 Old 05-21-2004, 08:11 AM
dzp
dzp's Avatar
NP
Good luck on your build. Be sure to post some pics when you are done.
Tyler, Texas
dzp is offline
post #7 of 10 Old 06-02-2004, 07:08 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
I'm with DZP, keep the Shackle mounts as close to the Frame mounting points as possible, in fact I was thinking about mounting mine inside the rails.
I know, that if you cut through the bumper and weld to the front and the rear of the shackle mount/bumper it will be stronger, but I don't think I can remember a shackle mount pulling off that was welded to just the front of the bumper.
If you want to carry on the idea of extra welding how about welding the inside of the mounts before putting on the end caps ?
Also to add to the D-Ring/Shackle thing, some off-road parks don't like the use of "D-Rings", why, who knows but just something I read SOMEWHERE !
Later,
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #8 of 10 Old 06-02-2004, 07:47 AM
dzp
dzp's Avatar
It is because some D-ring manuf use straps that are too small (like 1/4")
You definetly want to weld it on both sides of the bumper. If you dont, then you are really pulling using the thickness (3/16") of the bumper, not the tab. You will bend it and possibly make it fail and shear away. I personally have seen them bend the front part of the bumper out. Very scary to see. Its all about knowing where the stress points are and disributing the load as much as possible. You dont need to know the math and physics behind it, just weld it to both parts of the tube.
Tyler, Texas
dzp is offline
post #9 of 10 Old 06-02-2004, 07:58 AM Thread Starter
Birdlaw
Birdlaw's Avatar
2014 JK Wrangler
UPDATE...
I had the tabs made out of 1x2 inch steel bar with a hole punched in it by a machine shop. It would have taken me six months to drill and cut these. They did in ten minutes
I welded the tabs front and back. The biggest PITA was cutting the slots. Originally I planned on using a 1" bi-metal hole saw. It worked OK. However, when I got to the front bumper, I had already welded the mounting plate on and did not want to remove it so the driss press could not reach the back side. I used a regular drill bit, drilled pilot holes and connected them with a metal cutting blade in a hand-held jig saw. It was a little slow but made GREAT slots. A die grinder added the finishing adjustment.
I'll post pics once I can borrow a digital camera......
Garmin GPS
Birdlaw is offline
post #10 of 10 Old 06-08-2004, 09:44 AM
Blue XJ
Blue XJ's Avatar
1988 MJ Comanche
When I made my bumper, I extended the mounting brackets through the bumper and used those for the shackle mounts. Its 1/2" steel, just used that for the bumper mount and the shackle.
'88 MJ
Blue Jeep Club Member #72
| 4.6L Stroker | AW4 | 6.5" RK Long Arm Kit | 35" TruXus MT's | HP30, 4.56, ARB, Alloys, Lockouts | C8.25, 4.56, ARB, Alloy Shafts, Disk Brakes | Warn XD9000i | Interior Cage |
Blue XJ is offline
mounting plate and d-ring tabs mr_imposible Fabrication Shop 4 01-15-2010 12:27 PM
Question on mounting D Rings (recovery points) blp5172 General Jeep & Off-Road Equipment 0 11-11-2009 02:57 PM
Need mounting tabs for D-rings....... andromeda Fabrication Shop 8 05-11-2008 07:09 PM
New Idea for mounting Shackle Tabs Cerealdaemon Fabrication Shop 5 10-11-2006 01:26 AM
a good place to get spring pearches, shock mounting tabs, etc Brandon11130 Fabrication Shop 2 01-10-2006 09:54 AM
