modifying my tire carrier bumper - JeepForum.com
post #1 of 9 Old 10-30-2008, 07:25 AM Thread Starter
XJ_Austria
1994 XJ Cherokee
I am planning to modify my TJM swing away tire carrier bumper. I don't like the current setup, also it is not legal here cause the tire carrier hinge covers the rear fog lamp and backup light. I just want make sure some items before I start. What carrier hinge is better. I originally planned to use this one:
http://www.atozfabrication.com/catal...ekit-p-34.html
And modify it to be able to attach it with a C-shape hinge receiver which I want weld to the bumper. Similar to this:
But then I found this:
Another nice idea I find. But is it same good as the other one with the massive hinge?
Another question is, what are the measurements of the massive hinge. Is the dome tube 4" x 2,5" or what? Measurements are nowhere mentioned unfortunately.
Thanks in advance for your inputs.
94 Cherokee 4,0 HO 192 hp
6" RE Superflex, 33x10,5 on 7x15 Dotz Dakar 5mm offset,
TJM rear steel bumper, ConFerr 6" heavy duty Roof Rack, narrowed, 4x6 feet with 8 Hella ligths
JKS Quick-Disconnects, rear sway bar deleted
XJ_Austria is offline
post #2 of 9 Old 10-30-2008, 07:30 AM
dcorn
The first one looks a lot beefier.
2014 Jeep Grand Cherokee Summit
dcorn is offline
post #3 of 9 Old 10-31-2008, 06:38 AM Thread Starter
XJ_Austria
1994 XJ Cherokee
Had some ideas and made two rough drafts.
First one is conventional swing out carrier style and I would have to modify my bumper completely to make it fit. Bumper is a TJM RB8 steel with spare tire receiver on both sides. So it is basically strong enough for my project. Of corse I will add material to make it more solid.
I forgot to mention what material I'd use on the first drawing.
# swing out hinge kit - strong version
# C-shaped hinge holder 5-6mm U-metal
# swing out is 60x50x3mm widened at the end for a TJ tailgate latch
# vertical support is 60x50x3mm and the tilted supports are both 50x50x3mm
# stoppers, supports and strike pin on the bumper
Second one is a little different from what is standard style.
# rubber bump stops are either on the carrier or on the hatch
# strike pin is on the hatch, mini bear claw latch in the carrier, operated by a YJ tailgate latch
# swing out hinge kit - strong version.
# slide support for vertical force and end stop on the bumper
# support for minor vertical force on the hatch mounted to the licence plate holes.
What do you think. First draft will work for sure, but will the second idea work too?
post #4 of 9 Old 10-31-2008, 08:17 AM
frankkl
I want to make a tire carrier more or less in the same style you want. The look I would like to go for the ARB. Clean and the possibility of 2 swing out. I prefer your first drawing.
frankkl is offline
post #5 of 9 Old 11-06-2008, 09:02 PM
ddeadserious
I don't know if you were baring your first drawing off this, but it looks very similar to the 25-sold AEV XJ rear bumper, here's a shot of one from EricsXJ:
1998 White ZJ Laredo: 5.2/242 // d30/d44a // BB // MX6's // Black Steelies // 30x9.50x15 BFG A/T's // FM50 // JCR T-Case Skid // Leather and stuff
ddeadserious is offline
post #6 of 9 Old 11-07-2008, 07:15 PM
wannabexj
The tire carrier hinge from the first picture is suppose to be much stronger than the rest, you can buy it already put together from rockstomper.com for $45 plus shipping.
Firefighters Jeep Club
wannabexj is offline
post #7 of 9 Old 11-11-2008, 10:25 AM
travail
Nice set up
travail is offline
post #8 of 9 Old 11-18-2008, 02:05 PM Thread Starter
XJ_Austria
1994 XJ Cherokee
Yes yesss! Once I saw a picture from this XJ with that bumper and that inspired me. I have another draft which comes a little closer to EricsXJ carrier. Do you have more pictures from that bumper??? I think I want do that style. I very much like it!!
post #9 of 9 Old 11-04-2015, 08:47 AM
ferdigan
looking to buy
Im looking to buy the same tire carrier. Anyone selling one??
ferdigan is offline
Advice for modifying my new to me (used) bumper and tire carrier. stangman68inftc Fabrication Shop 2 09-22-2008 09:12 PM
Smittybilt Bumper with or without tire carrier RockinWrangler General Jeep & Off-Road Equipment 2 07-30-2008 11:22 PM
building rear bumper with tire carrier... need suggestions for 40" tire Big-n-Broke-YJ Fabrication Shop 10 10-04-2006 03:34 PM
LOD Bumper Tire Carrier DestructoJr General Jeep & Off-Road Equipment 1 05-13-2005 03:12 PM
Bumper an Tire Carrier JIM79CJ7 Fabrication Shop 24 01-24-2003 01:40 AM
