MJ Commanche projects - Page 4 - JeepForum.com
post #46 of 59 Old 08-05-2014, 11:28 PM Thread Starter
1989comanche
1989 MJ Comanche
The next project wiring for the lights.
Find a good place for a string of relays
1989 Comanche
Mostly stock except homemade custom bumpers
1989comanche is offline
post #47 of 59 Old 08-05-2014, 11:40 PM Thread Starter
1989comanche
1989 MJ Comanche
Next making this big mess o wires do what you want it to
1989 Comanche
post #48 of 59 Old 08-05-2014, 11:48 PM Thread Starter
1989comanche
1989 MJ Comanche
First organize the mess. A few zip ties and some shrink tube.
Shrink tube all the relay ground wires together and route to grounding screw.
1989 Comanche
post #49 of 59 Old 08-05-2014, 11:54 PM Thread Starter
1989comanche
1989 MJ Comanche
All tucked back in and coolant bottle shelf reinstalled.
Put all back together till I have time for the next step. Powering up the relays and getting switch signals from dash to the relays
Looks like it's about time to clean up the engine compartment too.
1989 Comanche
post #50 of 59 Old 08-06-2014, 12:02 AM
rajivkhandelwal
Junior Member
1989 Comanche
rajivkhandelwal is offline
post #51 of 59 Old 08-14-2014, 11:54 PM Thread Starter
1989comanche
1989 MJ Comanche
Next steps incoming power to feed the relays.
Make bracket to rack up all the fuses. 1 per relay so a total of 6.
This should work well
1989 Comanche
post #52 of 59 Old 08-14-2014, 11:58 PM Thread Starter
1989comanche
1989 MJ Comanche
Fuse bracket done everything fits, built a stop to keep them all contained.
1989 Comanche
post #53 of 59 Old 08-15-2014, 12:08 AM Thread Starter
1989comanche
1989 MJ Comanche
Painted and mounted.
Another view
Also have power stud mounted and started to hook up fuses.
1989 Comanche
post #54 of 59 Old 08-15-2014, 12:16 AM Thread Starter
1989comanche
1989 MJ Comanche
Also started to mount the switches.
1989 Comanche
post #55 of 59 Old 09-01-2014, 05:35 PM Thread Starter
1989comanche
1989 MJ Comanche
Finishing up lights
Finishing up wiring
Hooking the switches to the relays
Dressing up the sharp edges
1989 Comanche
post #56 of 59 Old 09-01-2014, 05:49 PM Thread Starter
1989comanche
1989 MJ Comanche
Switch hooked up in dash panel
Weld up a few tabs and bolt it down
1989 Comanche
post #57 of 59 Old 09-02-2014, 01:52 AM
88AKChief
1988 MJ Comanche
I love the clean stock look of this truck! Good Job on the builds!
88AKChief is offline
post #58 of 59 Old 09-06-2014, 04:43 PM Thread Starter
1989comanche
1989 MJ Comanche
Done
1989 Comanche
post #59 of 59 Old 01-18-2015, 09:56 PM Thread Starter
1989comanche
1989 MJ Comanche
Installed a set of new Bilstein shocks this week but have not had time to give them a good test. They do feel better ride though.
1989 Comanche
