MJ Commanche projects - JeepForum.com
post #1 of 59 Old 03-23-2014, 03:14 PM Thread Starter
1989comanche
1989 MJ Comanche
Figured I would start a thread for my stuff here is I am not messing up everyone else's
1989 Comanche
Mostly stock except homemade custom bumpers
1989comanche is offline
post #2 of 59 Old 03-23-2014, 03:19 PM Thread Starter
1989comanche
1989 MJ Comanche
Start with the front bumper. Made out of 2X6 1/4 wall rectangle tubing.
1989 Comanche
post #3 of 59 Old 03-23-2014, 03:25 PM Thread Starter
1989comanche
1989 MJ Comanche
Started with about 5' of tube. Add a bunch of big clamps.
1989 Comanche
post #4 of 59 Old 03-23-2014, 03:27 PM Thread Starter
1989comanche
1989 MJ Comanche
Add a lot of heat, big rosebud and lots of force.
1989 Comanche
post #5 of 59 Old 03-23-2014, 03:28 PM Thread Starter
1989comanche
1989 MJ Comanche
You end up with this.
All bent.
1989 Comanche
post #6 of 59 Old 03-23-2014, 03:31 PM Thread Starter
1989comanche
1989 MJ Comanche
Then you end up with this.
Test fit.
Lookin good enough for me.
1989 Comanche
post #7 of 59 Old 03-23-2014, 03:33 PM Thread Starter
1989comanche
1989 MJ Comanche
Then need to add receiver and shackle mounts.
Figuring out spacing and layout.
Cut out some holes.
1989 Comanche
post #8 of 59 Old 03-23-2014, 03:42 PM Thread Starter
1989comanche
1989 MJ Comanche
Some twisting, measuring and figgering.
1989 Comanche
post #9 of 59 Old 03-23-2014, 03:46 PM Thread Starter
1989comanche
1989 MJ Comanche
Get it all straight and level
Weld it up
1989 Comanche
post #10 of 59 Old 03-23-2014, 03:48 PM Thread Starter
1989comanche
1989 MJ Comanche
Welded front and back
1989 Comanche
post #11 of 59 Old 03-23-2014, 03:55 PM Thread Starter
1989comanche
1989 MJ Comanche
Next tack and weld the shackle mounts.
1989 Comanche
post #12 of 59 Old 03-23-2014, 03:58 PM Thread Starter
1989comanche
1989 MJ Comanche
Test fit
1989 Comanche
post #13 of 59 Old 03-23-2014, 04:07 PM Thread Starter
1989comanche
1989 MJ Comanche
Bracket time
First the pattern
Then put it on steel
1989 Comanche
post #14 of 59 Old 03-23-2014, 04:23 PM Thread Starter
1989comanche
1989 MJ Comanche
Where one of the brackets needs to end up. Plus you can see where the vaccum ball ended being relocated.
1989 Comanche
post #15 of 59 Old 03-23-2014, 04:28 PM Thread Starter
1989comanche
1989 MJ Comanche
Brackets to weld on bumper.
1989 Comanche
