Quantcast millermatic 180 vs Hobart handler 187 vs Lincoln SP 180 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > millermatic 180 vs Hobart handler 187 vs Lincoln SP 180
Old 11-26-2009, 09:25 PM   #1
rustymudder
1982 CJ7
I'm looking into getting a new welder, The miller is a bit more expensive than the lincoln and hobart
Is there any pros or cons to these welders? which do you prefer?
rustymudder is offline   Reply With Quote
Old 11-26-2009, 09:32 PM   #2
Unlimited04
Unlimited04's Avatar
they're all good quality and all will do the job.
its like asking Ford vs Chevy vs Dodge.
Unlimited04 is offline   Reply With Quote
Old 11-26-2009, 09:34 PM   #3
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I am a miller fan but have used all 3. No big differences to note. The hobart is cheaper but uses all miller replacement parts, just about.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 11-26-2009, 09:47 PM   #4
rustymudder
1982 CJ7
can these 180amp welders handle 1/4" steel? or is something with more power really needed. I know what the manufacturer's website says, but I'd like to hear from someone with one or something similar.
I have a little 115volt lincoln flux cored welder with a mig conversion on it, it can handle sheet metal, but cant do any thick stuff.
So I'm also considering getting a big stick welder for primarily the thick stuff and keep the little lincoln for the sheet metal. instead of getting a bigger mig.
Old 11-26-2009, 09:56 PM   #5
rustywrangler
I weld 1/4" with my 180 all the time.
Old 11-26-2009, 11:27 PM   #6
jsc7002
1989 MJ Comanche
I like Hobart, they are made in the USA! The others might be as well I dont know, plus my Hobart has been awesome!
1989 Jeep Comanche MJ:
2WD, 4.0L, BA-10, D30, D35, 4" IRO Front, SOA Rear, Winch Bumper, Trimmed Fenders/ Bed. Working on 2wd->4x4 Conversation.
My Build: http://www.jeepforum.com/forum/f22/my-slow-build-89-jeep-mj-off-road-hunting-rig-pic-heavy-1268973/
jsc7002 is offline   Reply With Quote
Old 11-26-2009, 11:45 PM   #7
lakailimited06
my hobart 210 has been great i love it so far...i went for hobart because of the price mainly..
99WJ 4.0
IRO 3", SYE, D30 aussie/8.8 aussie, 4.10s, 33's, skids/bumpers
lakailimited06 is offline   Reply With Quote
Old 11-27-2009, 12:40 AM   #8
timatoe
Jello Puddin'
timatoe's Avatar
I've got a Lincoln 175HD, it's basically the same as the 180. I was gonna get the Miller, but got a screaming deal on the Lincoln. I'd buy it again, it's been very dependable.
timatoe is offline   Reply With Quote
Old 11-27-2009, 12:40 AM   #9
MO2500
Fabramicator
MO2500's Avatar
i have the Hobart 187 and it's been an awesome machine it handles 1/4" just fine... i bought it as a factory reconditioned model (in reality brand new) for around 500 and it came with a new Miller m10 gun i would recommend it for the price and quality
My Build Thread
Useful links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is offline   Reply With Quote
Old 11-27-2009, 01:55 AM   #10
wes97
wes97's Avatar
mine came with a miller gun aslo. ive heard that miller actually makes hobart, but not sure if thats true or not
wes97 is offline   Reply With Quote
Old 11-27-2009, 04:34 AM   #11
rustywrangler
miller and hobart are not made in the same place but have the same parent company. They use alot of the same parts. Any miller dealer will repair a hobart. So yes, technically one makes the other by supplying the parts.
Old 11-29-2009, 06:55 PM   #12
Flingit1200s
Two of my local welder supply places have told me that Miller and Hobart have the same parent company but that the hobart has aluminum "windings" inside where the miller and lincoln have copper. Supposedly a machine with copper will last longer. I have a 135amp lincoln from home depot. It has a plastic wire feed except for the roller itself. The lincoln I saw at the welding supply place the other day has all metal for the feed roller area. I'm probably going with a Miller 211 next.
88' Wrangler, 4.2 .30 over with Weber 32/36, AX 15, sye, 4:10 gears, Ford 8.8 and Dana 30 with 4:10's out of a 2.5, 3.5" BDS springs with MORE 5/8" shackles, no trac or sway bars, 33x12.5r15's on 15x8 American Racing Baja's.
Flingit1200s is offline   Reply With Quote
Old 11-29-2009, 07:28 PM   #13
Canfourjeep
Differences
Illinois Tool Works owns both Miller and Hobart. Hobart is making under 250 amp machines to keep with government regulations. Hobart and Miller are almost identical and no one can tell the difference in how they weld . The welders bought at Lowe's and Home Depot are not the same as those bought at a welding supply repair shop that works on Miller can use Hobart parts on it. Also Lincoln has become a hobbyist company and now make commercial and hobby welders. If you bevel the metal a 125 will weld 3/8 in ch metal with no problems.
Canfourjeep is offline   Reply With Quote
Old 11-29-2009, 07:29 PM   #14
Roadymi
1982 CJ7
I believe this happens a lot at the big box stores. They coeirce the name brands to build them a cheaper unit that they can sell at a discounted price. Always make sure you are shopping apples for apples. Quality of materials in the drive mechanisms and windings would be what I would compare. Rate them by quality of materials than by price to see which is the better deal.
Another thing to keep in mind is how you plan to use the welder. If you are a week-end warrior that may flip it on once a month, your durability requirements are much different than if you are running a fab shop.
Roadymi is offline   Reply With Quote
Old 11-29-2009, 10:43 PM   #15
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
One fairly new great feature the current Miller 180 welder has is called Autoset and that automatic feature has certainly helped my welds. What it does is automatically set the wire speed and it does a damned fine job of doing so. All you need to do is set the voltage according to the thickness of the steel shown on the voltage knob and start welding... it takes care of the wire speed for you automatically. And as one who came off a Hobart without Autoset, my welds improved considerably once I got the Miller and learned to trust the Autoset feature. You can easily turn Autoset off & set the wire speed yourself but since the Autoset has worked so well for me, I have never done so. And at least the last time I looked, neither Hobart nor Lincoln have any form of automatic wirefeed speed set feature.
For that feature alone I'd pay a little extra for the Miller 180 Autoset. Not to mention the Miller name. And yes, it'll easily handle 1/4" and most 5/16".
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Glock Forum
