Miller bobcat welder idles, but to arc - Page 2 - JeepForum.com
post #16 of 28 Old 07-08-2010, 08:11 PM
bryanm
1978 CJ5
If you don't have the manual like me you can download it and other Miller welding equipment at this link(it is free) just click the link:
Miller - Owners Manuals
bryanm is offline
post #17 of 28 Old 07-08-2010, 09:12 PM
bryanm
1978 CJ5
I downloaded the manual
No weld output no power output ---- Check
Check fuses F1 and F2, and replace if open (see Section 8-4 or 9-6).
Check plug PLG6 connection
bryanm is offline
post #18 of 28 Old 07-09-2010, 08:53 AM
Ironworker709
Ironworker709's Avatar
Originally Posted by bryanm View Post
The jumper cables or battery supply current to energize the field in the welder if the field is not energized no arc --the small Lincoln (G9) welders work this way I believe the Millers do also. Usually there is a separate wire it hooks to the battery along with the battery cables. I said leave the cables on the get the current to energize the field normally the battery takes care of it most large machines do not require this but the smaller machines do. You can get them to start but if you don't leave the 12 volt current connected you will not be able to weld. Did you check the adjustment switches (the big dials) sometimes they stick and do not make contact this will yield the results you describe.
You can PM me and I will give my cell number maybe talk you through if the resistor does not fix the problem I have one of the machines you are working on at the shop but I never use it.
mccollum.bryan@gmail.com
Now that Bryan mentions this,i do remember a few years ago while i was using my Lincoln Ranger 225 for a power source for my old Lincoln Pro Mig 135 and the battery was dying,i was barely getting any kind of power to the MIG machine,so i shut it off to investigate,when i tried to start it found out the battery had actualy ended it's life cycle and wouldn't hold a charge.
I got a new battery and everything went back to normal...soo...it could be a possibility you're battery is not holding a charge once you jump start it but not getting enough current to energize the field as Ryan mentioned...this makes sence to me since it did happen to mine.
Put a good battery in it and see what happens,hopefully this might be it.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #19 of 28 Old 07-09-2010, 08:56 AM Thread Starter
g4x4xgeoff
Excellent point! The battery is on the older side. After I replace that busted fuse, I'll hook my jeeps battery into it and see what happens (if it picks up a load, I'll replace the actual battery with a correct replacement)
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #20 of 28 Old 07-09-2010, 09:05 AM
bryanm
1978 CJ5
g4x4xgeoff
Did you look at post #17
Also check the Course and Process dials the rheostat (potentiometer) if they are not making contact the machine will act the way you are describing. All Miller (Lincoln) welders with analog adjusters are bad about this. Had it happen to the Bobcat at the shop and a couple of the MIG welders took off the cover expecting something was burnt only to find the range adjuster open.
I also left you a link for the manual in post #16 you don't have to download it to view. It has the schematics and you can print only the parts you need.
Bryan McCollum
AWS Welder
AWS Weld Inspector
bryanm is offline
post #21 of 28 Old 07-09-2010, 09:23 AM Thread Starter
g4x4xgeoff
bryanm,
I did, took a screen shot of it, and noted it. I'm going to rip into the welder once I get out of work today. I've also got the manual. I really appreciate you taking the initiative to find the Troubleshoot errors.
post #22 of 28 Old 07-09-2010, 10:02 AM
bryanm
1978 CJ5
I will be out of town the next few days till next Friday.
bryanm is offline
post #23 of 28 Old 07-09-2010, 08:07 PM
jason m
Nothing but the facts
jason m's Avatar
Originally Posted by yea_mitch View Post
its possible the exciter is cooked or the brushes are arcing out on the genorator
This would be my guess, the exciter.
My Linclon 250 did somthing like your talking about a few weeks ago while Hard facing a bucket. I had a slight spark at low idle but it would not jump up to the higher speed.
I was pushing the machine but nothing has stopped it before and with only 65 hours on the unit I cant explian why. I have another bucket coming up and I'm a tad bit concerned, but hey its only money
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is online now
post #24 of 28 Old 07-09-2010, 08:28 PM
dodger889
Something I have seen work on old generators or welders is to do a quick power jump across the power leads ( output connection )with a battery.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #25 of 28 Old 07-09-2010, 09:32 PM Thread Starter
g4x4xgeoff
I'll try doing a power jump.
I spent about two hours today going through every wire and fuse, relay, and resistor, and still can't figure the thing out.
post #26 of 28 Old 07-10-2010, 01:39 PM
bryanm
1978 CJ5
Have you checked the course, process, and rheostat (potentiometer)
Jumping the lead terminals is not a good idea with this type machine -- it use to work on some of the Lincoln SA machines
bryanm is offline
post #27 of 28 Old 07-10-2010, 01:45 PM Thread Starter
g4x4xgeoff
Bryanm, I have not,
to be honest with you, I wouldn't even know where to begin on how to check one to see if it was working properly.
post #28 of 28 Old 07-10-2010, 02:20 PM
bryanm
1978 CJ5
There is a spring that actuates a contact bar on both the course and process selectors some times they stick you can run the through all positions sometimes and un-stick them other times you must work the contact from inside the machine --you can check the fine adjustment by disconnecting the wires (remember where they hooked up) and check with an ohm meter to see if they are open they should have continuity on all three terminals One to the others.
with the process and the range selectors it is just like them being set between settings it leads to and open circuit in turn no arc allot of times it is something very simple and it makes you feel stupid when you find it. Been there done that best of luck with the troubleshoot
bryanm is offline
miller bobcat welder , welder repair , welder , no arc , idle , miller welder
miller 212. ksheffer08 Fabrication Shop 2 10-23-2009 04:10 PM
Miller 140, 180 or 211 frankkl Fabrication Shop 6 03-16-2009 08:07 PM
Miller 135/175 Welder With M-10 Gun ntaousakis Fabrication Shop 1 03-05-2009 09:39 PM
Miller Dynasty 300: To buy a used welder? kbazurpe Fabrication Shop 18 03-12-2008 10:04 PM
Miller 130? sjd78 Fabrication Shop 5 03-23-2007 07:48 AM
