mig wire binding up AFTER drive roller? - Page 2 - JeepForum.com
post #16 of 18 Old 10-08-2013, 06:43 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Might want to make sure the cable/liner are fully seated in the machine too. I've tripped on the cable before and pulled it out a bit. The larger "gap" quickly caused the wire to bunch up.
For roller tension.. a general rule of thumb is, you should be able to pull the trigger and shoot the wire into a piece of wood.. and the rollers should slip instead of bunching up the wire.
Liners are cheap enough that I replace them about every 6 months.. or if I start having any type of irregular feeding. Although they make liners of different diameters, I've never had any problems shooting .023-.025" wire thru a .035" liner. I just make sure I use the properly sized tip.
BESRK is offline
post #17 of 18 Old 10-08-2013, 09:59 AM Thread Starter
danielbuck
1946 CJ2
do you just grab the liner with some needle noes pliers and pull it out?
danielbuck is offline
post #18 of 18 Old 10-08-2013, 10:35 AM
1222
RIP John
1222's Avatar
There should be some very small allen screws on either end that need to be loosened first, at least thatís how mine is setup.
1222 is offline
