Metal Shavings + Magnets - JeepForum.com
post #1 of 15 Old 11-22-2010, 09:35 PM Thread Starter
Jason
Do you guys have any voodoo or magic tricks to get the metal shavings off of magnets? I try to "wipe" them off, but that only works marginally. TIA.
Jason is offline
post #2 of 15 Old 11-22-2010, 09:46 PM
Newb1995jeepgc
1994 ZJ
Get a stronger Magnet hahah
1995 Jeep ZJ Limited V8- 213k- sold
2000 Jeep WJ I6- 185xxx-sold
1994 Jeep ZJ Limited Red I6- 210k
Newb1995jeepgc is offline
post #3 of 15 Old 11-22-2010, 09:49 PM Thread Starter
Jason
You know, I hate to admit it, but I've tried removing the shavings from one magnet with another magnet. But then that leaves me with the problem of removing the shavings from THAT magnet
Jason is offline
post #4 of 15 Old 11-22-2010, 10:36 PM
5-90
5-90's Avatar
1988 XJ Cherokee
I've always avoided the problem entirely by putting the magnet is a small baggie, or putting a plastic cover overtop the magnet in a drain plug.
Magnet looks "fuzzy," pull the cover and the metal comes off (turn the cover inside-out as you remove it to contain the metal.)
One trick that has worked fairly well for me is to wipe down with a coffee filter - the paper is rough enough that it will catch most of the stuff, and you can just toss it afterwards. Put the magnet in a baggie/cover after it's clean, so you don't have to do it again.
If you have it, scrap bits of velvet or velveteen can also trap a lot of fine metal bits.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #5 of 15 Old 11-22-2010, 11:33 PM
Krochus
In our shops we use a lot of magnets For tape measures and string lines and if you drop one it'll look like a punk chia pet when you pick it up due to years and years worth of grinding and blasting leavings everywhere, I always use a quick blast of compressed air to set things right.
Knocks the stuff right off
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #6 of 15 Old 11-22-2010, 11:35 PM
badmatt
1990 XJ Cherokee
shop air, Just not around measuring tools.
badmatt is offline
post #7 of 15 Old 11-23-2010, 06:06 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Yep.. I use air too. Make sure to wear eye protection when blowing shavings off the magnets.
BESRK is offline
post #8 of 15 Old 11-23-2010, 11:39 AM
Eaglekeeper
Yep. x4 on the air blast and face shield.
86 CJ7, 258 Engine, T-177, Dana 300.
A ton more pics here.
Eaglekeeper is offline
post #9 of 15 Old 11-23-2010, 04:37 PM
Igiveup
Another vote for the air blast. I used to give a squirt of oxygen out of the cutting torch out in the field where compressed air wasn't available.
Igiveup is offline
post #10 of 15 Old 11-23-2010, 05:36 PM
Krochus
Also works for headaches too
Krochus is offline
post #11 of 15 Old 11-23-2010, 09:58 PM
GREASEMONKEY
Air, or sandwich baggies in the field.
Friendship is like peeing on yourself: everyone can see it, but only you get the warm feeling that it brings.
GREASEMONKEY is offline
post #12 of 15 Old 11-29-2010, 07:53 PM
trxridr
they make those magnets that also have aluminum in between the magnet and the surface so you pull the magnet away and they drop the shavings
1999 wrangler, 4.0l five speed, 4 inch procomp lift, 1,25 body lift, 1 inch mml, d30 front, ford 8.8 rear with 4.10's, 35 inch km2's
"When in doubt, Hammer out"
trxridr is offline
post #13 of 15 Old 12-18-2010, 09:49 AM
KnacK
I use shop air on my setup magnets. I also have a few strong magnets on my horizontal band saw that I keep in a ziplock. When its time to clean up, use the magnet in the baggie then go to the trash can and toss the baggie.
Works great.
Chris
'88 YJ Laredo, Hardtop
Red
4.2L Auto 190k miles
3" Body Lift, Rancho Shocks, 31" Wranglers
Sagging springs
Bald tires
Blown tranny
Dead 4.2
Empty wallet
KnacK is offline
post #14 of 15 Old 12-18-2010, 10:38 AM
Bigbob
Bigbob's Avatar
I have a couple of the bovine stomach magnets still around. These were magnets used in cattle stomachs to collect small metal pieces to keep them from going through the digestive system.
They look like this:
They are about 3" long. Great for shop table clean up.
Those small zip lock bags or sandwich bags are great.
Drop a magnet in the baggie and "sweep" the area then just turn the bag inside out. Blowing off the shavings just moves the shavings from point a to point b.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #15 of 15 Old 12-18-2010, 12:13 PM
shadowulf
small altoid tins work good to keep the magnets clean. Tape it closed and run it over the filings to pick them up. Duct tape or electrical tape does a good job at cleaning of the filings.
shadowulf is offline
subs and metal cable, will it mess up the magnets in the subs wakeboarder 21 Audio, CB & Ham Radios, GPS, & Electrical 8 07-12-2010 05:22 AM
brackets, tubing or metal insert fill gap b/t bumper and metal so lamps dont shake osd Fabrication Shop 4 06-13-2010 02:40 PM
Rust due to metal on metal beeper General Jeep & Off-Road Equipment 5 04-15-2009 11:24 AM
License Plate Magnets bgoman General Jeep & Off-Road Equipment 7 03-19-2009 12:36 PM
Oil filter magnets?? Jeepman11 Engines & Drivetrain 5 11-21-2007 10:14 PM
