Metal Selection for Rock Sliders - JeepForum.com
post #1 of 16 Old 07-02-2007, 09:15 AM Thread Starter
pendleton
OK, so I've been reading up on and looking at lots of pictures of rock sliders, and I'm pretty confident about fabricating this project. My question is in the selection of metal.
The end product is an angle that fits against the rocker panel. Is it better to buy sheet goods and have a machine shop break it to the 90 degree angle, or is it better to buy angle of the right size and eliminate the break work? From experience, I know that angle is not completely uniform in it's shape, meaning, the valley of the angle has a very slight radius, as does the two opposing ends of the angle. (Basically, the angle rounds off at the ends)
Will I get a better & tighter fit with a piece of sheet broke to 90 degrees? I don't want the end product to look questionable and not fit as well as it could?
My Jeep:
pendleton is offline
post #2 of 16 Old 07-02-2007, 10:11 AM
1 ton yj
1 ton yj's Avatar
A peice of sheet broke to 90* will still have the radius. The only way to get a sharp angle is to weld together two seperate peices at 90*
1 ton yj is offline
post #3 of 16 Old 07-02-2007, 10:34 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Get architectural angle. It differs from structural angle in that it doesn't have the radius on the inside.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #4 of 16 Old 07-02-2007, 12:45 PM
JJs99TJ
if your going to use angle.
Originally Posted by rnemovr
oman, what happened in the wreck? i see it bent your bumper, did you hit a camel?
JJs99TJ is offline
post #5 of 16 Old 07-03-2007, 10:40 AM
1 ton yj
1 ton yj's Avatar
You learn something new every day...
1 ton yj is offline
post #6 of 16 Old 07-03-2007, 12:11 PM
Island4x4
i used 3/16" plate and had it bent
1.25" sch80 tube for the rails
God is good to the Irish because nobody else is.
White Jeep Club Member # 1337
Island4x4 is offline
post #7 of 16 Old 07-03-2007, 06:31 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
No kidding.. I've never heard of that. Next time I'm down at my "steal" dealer, I'm gonna ask them about that stuff.. cool beans.
BESRK is offline
post #8 of 16 Old 07-03-2007, 09:25 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
i just used 5/16 x 6 x 6 angle iron......and .120 wall hrew for the steps.
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #9 of 16 Old 07-05-2007, 01:48 AM
Island4x4
martin
overkill...
post #10 of 16 Old 07-11-2007, 01:25 PM
Ares
Ares's Avatar
5/16 is pretty thick, but if you have it layin around....why not?
I just dug this up from search because im looking into getting angle aluminum for this and wondering if that will be strong enough. I was thinking 1/4" 6061 T6 would do the job and wanted your guys opinions. Would not be running side steps off them, just straight rocker guards.
Good to know about the arcitectural v. structural. However, could you not run a grinder on that inside edge maybe to cut down the radius a little?
- Cameron
Ares is offline
post #11 of 16 Old 07-11-2007, 05:28 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
The one thing I don't like about aluminum is that, it sticks to the rock.. doesn't slide like steel or plastic.
BESRK is offline
post #12 of 16 Old 07-12-2007, 09:35 AM
Ares
Ares's Avatar
I could see that since aluminum is very gooie. i was just looking for a quick and easy route since 4x4 angle 6061 1/4" is fairly inexpensive. I would like to do a 4x6 angle A36 hot roll, but I can only get it in 5/16 which seems a little excessive, and fairly heavy
- Cameron
Ares is offline
post #13 of 16 Old 07-12-2007, 01:03 PM
Island4x4
if you do it properly and run the rocker onto the subframe towards the bodymounts then the radius won't come near the bottom of the rocker panel. It sits around half an inch below it.
post #14 of 16 Old 07-13-2007, 10:07 AM Thread Starter
pendleton
Hmm, if I am understanding you correctly, then you are saying to hold the angle down a bit from the edge of the rocker panel before bolting to it.
This won't work, as you loose alot of strength by relying completely on the strength of the metal around the bolts to hold the weight of the jeep on impact. Preloading the rockers and creating a physical touching connection takes the weight and distributes it across the entire panel, and the bolts are only holding the rocker in place and preventing a moment force movement (rolling under the tub). If you read A to Z fabrications install instruction, it requires a preloading of the rocker guard.
My Jeep:
post #15 of 16 Old 07-24-2007, 01:48 PM
Exparrot
Exparrot's Avatar
Don't know how close you are to Seattle, but http://www.onlinemetals.com/ is based out of there. Should be able to find some decent hot rolled from there, and a machine shop should be able to do a brake for cheap.
I just did mine with 1/8" hot rolled (not a lot of rocks in Wisconsin), and the local machine shop did a 90 degree for me for free. Total for the metal was $47 and change.
EDIT: http://www.onlinemetals.com/merchant...owunits=inches
4x4 1/4" hot rolled is $9.15/foot. You need about 10 feet total. Ouch.
I got a Jeep, it's lifted and it's got crap bolted to it.
Color by Rattle-Can.
LO Jeep Club #111 [and not proud of it]
Red Jeep Club #MC399
Exparrot is offline
Rock Sliders ragsdale Fabrication Shop 20 01-02-2009 05:42 AM
Rock Sliders help fataltherabbit Fabrication Shop 4 12-27-2008 01:50 PM
best way to mount rock sliders toast11 Fabrication Shop 17 09-11-2008 07:23 AM
POR 15 on rock sliders? Bot General Jeep & Off-Road Equipment 2 04-09-2007 09:15 PM
Rock Sliders emx Fabrication Shop 3 06-03-2005 12:24 PM
