Makeing a oversize tire carrier - JeepForum.com
post #1 of 4 Old 06-22-2014, 09:47 PM Thread Starter
1990yjoffroad
Anyone fabricate a oversized tire bracket need some ideas and photos. Thanks,nick.
1990yjoffroad is offline
post #2 of 4 Old 07-05-2014, 01:27 PM
SamzJeep
used 3/8" plate for mounts (put mounts on the inside of the tub also), 2X2 .120 square tubing, brass bushings for hinges, #8 bolts/nuts/washers and pins, gussets where needed. Cost under 100 bucks. The tire mount is extremely sturdy too and I can fit any tire size without any worries. I hope this helps. Good luck.
SUPPORT OUR TROOPS
SamzJeep is offline
post #3 of 4 Old 07-08-2014, 08:33 PM
churchofjt
You might find a few ideas in the stickied thread: http://www.jeepforum.com/forum/f37/r...-along-101332/
churchofjt is offline
post #4 of 4 Old 07-09-2014, 01:24 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
My buddy uses a spare front hub and spindle to mount the rear spare. = spare trail parts. Tired of rear carriers that only open one direction, we made mine open left or right, depending on the need. Trying to figure how to post directly from this ipad...JF does not like the size and
Edit. Found this that sort of shows it. Can get more later from photobucket
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
