Low Profile TJ Front Bumper - Rokmen inspired - Page 3 - JeepForum.com
post #31 of 47 Old 08-03-2012, 03:35 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
A stinger will take a pretty good licken when connected to a grill hoop like that.
If you're really worried, raise the mounting point of the brace at the stinger.. and lower it at the grill hoop. That will increase the effectiveness of the brace.
BESRK is offline
post #32 of 47 Old 08-03-2012, 04:12 PM
danielbuck
1946 CJ2
I was thinking the same thing. That would be less likely to bend the grill hoop, if it connects lower down on the grill hoop and higher up on the stinger. The photo above looks like it's done opposite of what it should be for the best strength?
I also thing it would just look better that way too.
danielbuck is offline
post #33 of 47 Old 08-07-2012, 09:51 PM Thread Starter
TXST8tj
TXST8tj's Avatar
I like the idea. I will definitely keep that in mind when I get to that point.
Bolted it on so I can finally get the bottom mocked up (without worrying about it shifting). Got the passenger side swaybar mount bolts drilled. Need to do the driver's side. They are there, so I might as well tie the bumper into them.
Going wheeling on Saturday. Hope to have it done by then.
Patrick
TXST8tj is offline
post #34 of 47 Old 08-11-2012, 05:27 AM
fratis
fratis's Avatar
im surprised you didnt clean up that rust before bending and welding.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #35 of 47 Old 08-30-2012, 08:59 AM Thread Starter
TXST8tj
TXST8tj's Avatar
If I had asked, they would've blasted it first; however, at the start, I gave them basic dimensions, turned around and it was already bent. They have been 'heliarc' welding it, and said they have been cleaning just the area that is receiving the weld.
I trust their work, but I do see where there would be question there.
The bumper structure is done. I need to do some cleanup on a couple spots and have it sandblasted. I am working on the fairlead mount as we speak. Once I am done cutting it out and tacking it on, my welder will do the final welding on it....then I'll have it blasted and painted.
I also have one little trim piece to add at the back of the bumper. It will make more sense through pictures.
I still plan to add a winch hoop and grille hoop (tubes sourced from www.jeeptubes.com), but those can wait for a little bit. I am ready to get this mounted up and the winch back on.
The underside is admitedly unattractive. I was going for as much coverage on the underside as is practical, although I might trim an inch or two off of the bottom plate to save a little weight.
Patrick
TXST8tj is offline
post #36 of 47 Old 09-04-2012, 10:17 PM Thread Starter
TXST8tj
TXST8tj's Avatar
I trimmed a couple inches off the bottom of the bumper. There is still a good amount of coverage on the underside, but not over the top like I think it was before. I need to drill the two bolt holes on the bottom....need to get a new drill bit though; snapped it in half being dumb on the top side.
I started cutting out the fairlead mount. I'm not sure I'm happy with it, but I still have some work left.
The outer edges (outside the outermost vertical lines) will get bent back a bit. They will act as bracing. I still might add a couple small gussets on the backside if needed.
I also took a flap disc to the edges to smooth everything over. I wanted a one-piece look. Still have some more work there. Haven't had much time to work on the bumper the last week.
Patrick
TXST8tj is offline
post #37 of 47 Old 09-06-2012, 09:57 PM Thread Starter
TXST8tj
TXST8tj's Avatar
Got some work done on the fairlead mount this evening.
I cut a recess into the outer sides of the mount, just enough to still keep it connected, but enough to allow me to bend the ends in a bit.
I also cut a section out of those edges to allow the fairlead to sit a little lower. I think I might lower it a bit more.
Clearance between the winch and mount
Patrick
TXST8tj is offline
post #38 of 47 Old 09-06-2012, 10:07 PM Thread Starter
TXST8tj
TXST8tj's Avatar
I started cutting the piece for the back 'cover'. Ran out of cutting discs. I was really hoping to get those pieces cut and tacked on to bring it in for final welding. Oh well, all signs point to this part of the project being done next week.
Patrick
TXST8tj is offline
post #39 of 47 Old 09-08-2012, 07:03 PM
PeejPilot
very cool build
PeejPilot is offline
post #40 of 47 Old 09-15-2012, 11:06 AM Thread Starter
TXST8tj
TXST8tj's Avatar
^^ Thanks!
Construction is all done. Got a coat of primer on it. Mounted it up to head out to my local Jeep club meet. Hope to get it painted this weekend. Still considering powdercoat, but definitely not until the tube work is added.
Patrick
TXST8tj is offline
post #41 of 47 Old 09-16-2012, 10:08 PM Thread Starter
TXST8tj
TXST8tj's Avatar
Slapped some paint on it and got the winch mounted and everything mounted up.
I am seriously considering having it powdercoated after adding the tubes. It looked a lot better in primer...haha.
Patrick
TXST8tj is offline
post #42 of 47 Old 09-17-2012, 09:40 AM
danielbuck
1946 CJ2
nice!
post #43 of 47 Old 09-19-2012, 11:13 AM Thread Starter
TXST8tj
TXST8tj's Avatar
^^ Thanks! I am pretty happy with the way it has turned out. There are a couple things I would do differently if I decieded to make another one. However, the size and basic effect are exactly what I have been wanting.
A couple outside/daylight pics:
Patrick
TXST8tj is offline
post #44 of 47 Old 04-29-2013, 12:09 PM
matt93
This is such an awesome design. I'm having my high schools welding shop build me one similar to it. do you think you could tell me what measurements you used? in terms of length from the front of the bumper to the grill, the width of the overall, etc? much appreciated
"don't wash it. it looks better dirty"
Siena Pearl Owners Member 57
matt93 is offline
post #45 of 47 Old 05-22-2013, 11:34 AM Thread Starter
TXST8tj
TXST8tj's Avatar
Thanks! It has proven to be a SOLID bumper. I really enjoy its slim nature. I am anxious to get the Genright trail tubes on there to finish it off.
I don't have any measurements off hand, but I can get some if you are still working on the project.
I finally got around to cutting the sides out to make room/clearance for a Currie Antirock.
Here is a zoomed in picture from a couple weeks ago.
Patrick
TXST8tj is offline
My rear bumper/tire carrier build inspired by (BESRK) yellow04tj Fabrication Shop 6 04-17-2012 07:42 PM
Low Profile, Vertically Mounted Winch, Bumper Build hoovail Fabrication Shop 26 12-03-2011 08:41 PM
ROKMEN DIY FAB - Front & Rear Bumper !!! 338WinMag Fabrication Shop 18 03-19-2010 06:45 PM
Has anyone used the Rokmen diy bumper kits? NMLJ Fabrication Shop 7 11-12-2008 09:32 AM
Hanson Rear Bumper with Rokmen Merc Front??? ADay73 General Jeep & Off-Road Equipment 5 12-26-2007 01:46 PM
