Looking for a good air hammer - JeepForum.com
post #1 of 5 Old 07-24-2010, 12:32 AM Thread Starter
Rio_Grande
I am looking for a good air hamer that can spend the day busting rivets quickly and not self destruct. Figuring it needs to be heavy duty with a long barrel.
Looking for recomendations. the little ones will not keep up. Any suggestions.
I love this crap!!
Rio_Grande is offline
post #2 of 5 Old 07-24-2010, 02:17 AM
Netpackrat
For when you are through with screwing around, there is the 9x aircraft rivet gun:
TAYLOR 9X Rivet Gun - .498 Shank
You'll need an adaptor to reduce the .498" shank down to the .401" that standard air hammers (including most other rivet guns) accept:
Rivet Gun Shaft Reducer
Be careful.
Netpackrat is offline
post #3 of 5 Old 07-24-2010, 07:58 AM
Area.3.Fiftyone
A guy that owns a trucking company next to my shop keeps asking me to fix his trailers that are riveted.
How do you do use one of those tools?
Do you just hold a dolly behind the rivet and hammer away?
Sorry for the hijack.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #4 of 5 Old 07-24-2010, 12:34 PM
Netpackrat
Basically, yeah. The dolly is referred to as a bucking bar, and there is a bit of skill involved. For large skins, you usually need two people, one to run the gun, and one to hold the bucking bar. This requires some practice, and usually more skill to hold the bucking bar than run the gun. There are bucking bars available in all different shapes and sizes, or you can make your own. You also need to have the right "set" (the part that goes where the chisel would on the gun) for the shape of rivet you are using. The 9X gun that I linked is way overkill for all but the largest rivets; we needed one in the shop the other day, but only to knock out a seized up bolt on a 737 thrust reverser. Aircraft riveting is more normally done using a 2-4x gun. I personally use a 3X recoilless gun from US Tool that is capable of setting up to 5/32" AD (hard) rivets, with bucking bars of my own construction. I've been seriously lusting after one of the new tungsten bars that are becoming popular.
Here is a basic tutorial; the first part of it covers bucked rivet installation:
Aircraft Construction, Riveted Joints
And here is the actual mil spec:
Rivet Application and Installation - Engineers Edge
Here is a picture of the bucking bars that I made. The leather cases are to prevent the polished surfaces from getting scratched; that may have been a bit excessive on my part:
http://www.bearhawkin.com/images/buckbars.jpg
post #5 of 5 Old 07-24-2010, 06:36 PM
wushaw
Rockin jeep
wushaw's Avatar
After you shoot a few rivets with tungenston your other bars will see more rust than bucking time. And your hands will love you for it. Also you do know the elevator weights are tungeston.
Op; a 9X rivet gun is a beast and hearing protection is your friend. Also what kind..size & composition.. aluminum, monel???of rivets are you using it on?
wushaw is offline
air hammer , rivet gun
Better Balance, Hammer-ons Vs Beads? rastaangel Tires & Wheels 3 03-15-2010 06:32 AM
Sledge hammer with explosvies fataltherabbit General Jeep & Off-Road Equipment 4 12-14-2008 05:56 PM
Air hammer/chisel with slow compressor? itasor Fabrication Shop 6 03-20-2008 03:24 PM
Home Made Slide Hammer or Something To Get The Job Done GreenJip Fabrication Shop 6 01-07-2008 07:08 PM
SHROCKWORKS ROCK HAMMER/1"bl mrbates General Jeep & Off-Road Equipment 7 07-20-2007 06:00 PM
