Looking @ Compressors - How many CFM? - Page 2 - JeepForum.com
post #16 of 19 Old 11-20-2008, 08:24 PM
corvetteguy
Originally Posted by SuperWade2 View Post
replaced every wall socket in the house when we moved it and zapped the crap out of myself becuase I was too lazy to figure out which breakers I needed to pull... You would think it would have only taken one zap... I'm a slow learner I guess.
at this point im not sure any of us can be much help......
to answer your question....yes....the ac unit would run off of 220
HOWEVER the problem you would have it by some small chance the ac unit and compressor should kick on at exactly the same time....then you would have a small problem.
corvetteguy is offline
post #17 of 19 Old 11-20-2008, 08:27 PM Thread Starter
SuperWade2
More Money than Brains
SuperWade2's Avatar
I'm pretty sure I could mitigate that with a little planning... we only run the AC maybe 2 Weeks a year and that days I'd be very unlikely to be working in the garage... I guess I'll call my electrical guy tomorrow...
Thanks for everyones help!
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #18 of 19 Old 11-20-2008, 08:32 PM
timatoe
timatoe's Avatar
How much $$$ am I looking at to have someone come in and run 220 or add a 20-25 amp breaker?
That shouldn't be too bad. I'd do it for you for a 12 pack if you weren't 4+ Hrs. away. It's really not hard at all, you can get a How To type book from Home Depot or Lowes or the library and be able to handle that small of a job.
timatoe is offline
post #19 of 19 Old 11-23-2008, 07:13 PM
Fastbeeatch
x2 on the easy part, if you have empty spot in the panel then it's really easy. Run a 10ga 3wire into the panel hook the white and black wires to the 2 posts on the breaker then hook up the ground wire to the grounding bar. On the other end of the wire use whatever plug that is rated for the compressor, or in most case it will wire directly into the compressor motor.
95 4L Auto D300 TC
103" Wheelbase
D60 Front 14 Bolt Rear 4.10 Gears
H1 Wheels 36" GoodYear OZ Tires
Fastbeeatch is offline
Air compressors. BobA Fabrication Shop 24 11-27-2008 05:57 PM
portable air compressors VT_Jeeper General Jeep & Off-Road Equipment 3 07-10-2007 11:53 PM
School me on Air compressors 1984CJ Fabrication Shop 25 06-01-2007 07:25 PM
cheap air compressors turkish6 General Jeep & Off-Road Equipment 13 03-21-2007 08:28 PM
OBA or Air Compressors?? R. Potts General Jeep & Off-Road Equipment 24 12-03-2006 04:01 PM
