Looking @ Compressors - How many CFM? - JeepForum.com
post #1 of 19 Old 11-18-2008, 08:08 PM Thread Starter
SuperWade2
More Money than Brains
SuperWade2's Avatar
I'm looking to upgrade the low end Harbor Freight Pancake 5 Gal compressor that I have with something that is actually good for something other than blowing up tires...
I'm not looking to do crazy stuff, but at least run the air ratchet, hammer, grinder, cutter, etc...
I only have 110 in the garage and looking for 25-30ish gallons (I think)... Would prefer something that doesn't rattle the cement under my feet
How much CFM's should I be looking at? I see many of the "lower priced" models arround 5-6cfm's
I can't spend $1000, but looking for suggestions....
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #2 of 19 Old 11-18-2008, 11:28 PM Thread Starter
SuperWade2
SuperWade2's Avatar
after looking though quite a few sites, it looks like if I want 60 Gal, I'm going to have to go 220/240v in the garage...if I stick with 110, I'll probably have to stay in the 25-30 gal range and something in the 5-6cfm range, something like this one for $400 at Home Depot...
http://www.homedepot.com/webapp/wcs/...5X-_-100063473
Not sure, but might be able to get a deal on this one...
http://sfbay.craigslist.org/scz/tls/918322431.html
27 gallons
7.7 CFM @ 40 PSI
6.0 CFM @ 90 PSI
6 peak HP motor
2017 WK2 Overland
post #3 of 19 Old 11-19-2008, 01:16 AM
timatoe
timatoe's Avatar
Look at the tools you're wanting to run and what CFM they take to operate, that'll give you a much better idea of what you need. I've got a Craftsman 5hp 60gal unit and it works great for impacts and stuff, but it cycles a lot with sanders, cutters, etc. that run more constant.
timatoe is online now
post #4 of 19 Old 11-19-2008, 05:53 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
For price, size etc, that first HD one is a good buy. Belt driven so it will be quiet. I have it's little brother. it is loud, oilless, and has a peak of 5.5. works ok with most but the grinder,cutter,sander makes her cycle. You should be ok for the home shop setup with that unit.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #5 of 19 Old 11-19-2008, 08:27 AM
conrasm
conrasm's Avatar
Lowes has a 30 gal upright that is belt driven with 2 piston pump for around $400. It's a Kobalt model. 6.2 cfm at 40 psi and 5.3 at 90 psi. It's a 110 model. I was looking at this one.
https://www.kobalttools.com/ (you'll have to click around to find it since their site doesn't give direct links to products).
I think the one HD has is a single piston pump. I looked at that one also. The belt driven are much quieter than the vibrating ones.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #6 of 19 Old 11-19-2008, 08:47 AM
rustywrangler
Good choice.
FYI, the Husky and Cobalt are almost identical. They come from the same manufacturer, Cambell-Hausfield. Both 2 piston pumps.
post #7 of 19 Old 11-19-2008, 11:06 AM
Happy Joe
Many air tools use a substantial amount of air especially the cheaper air tools (I have one sander that uses more than 16 cfm). If you want to use air tools get a substantial compressor or you will spend all of your time waiting for it to build pressure...
I use a little 2 horse 110v compressor for tires.
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway.
Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road.
Happy Joe is offline
post #8 of 19 Old 11-20-2008, 07:08 PM
Smtty58
Check the low end 220 models, some of them will let you re-wire the motor for 110. My 5HP 33 gal. Craftsman is like that, 9CFM if I remember. Just check what amps they draw on 110, you may need a 20 or 25 amp breaker.
90 YJ, 4.2, AX-15
86 K1500, 305, 700R4
Smtty58 is offline
post #9 of 19 Old 11-20-2008, 07:19 PM Thread Starter
SuperWade2
SuperWade2's Avatar
My crappy one blows the only 15 Amp Circuit in my Garage...
How much $$$ am I looking at to have someone come in and run 220 or add a 20-25 amp breaker?
2017 WK2 Overland
post #10 of 19 Old 11-20-2008, 07:38 PM
corvetteguy
Where is your fuse panel in location to where the compressor will be?
corvetteguy is offline
post #11 of 19 Old 11-20-2008, 07:48 PM Thread Starter
SuperWade2
SuperWade2's Avatar
In the Hallway entering from the Inside Garage Door (maybe 4' from Door to panel) into the House (also where the Washer Dryer are)
Current Compressor (and 15amp outlet) maybe 8-10 ft from the door along the back wall..
So maybe 12-15 feet total along 2 walls (90 Degree)
Wade
2017 WK2 Overland
post #12 of 19 Old 11-20-2008, 07:52 PM
corvetteguy
i would install a 220/230 breaker...then exit bottom of panel and right below panel install an external outlet...like for the dryer.
then, use some SJ cord...like used for welder extension cords and run from outlet out to compressor when needed. thats really a short distance.
when not used, just unplug cord...would be cheapest/easiest/fastest wasy to get 220 to garage.
do you have any wiring experience?
if panel and compressor share same wall, but different side...that would be SUPER easy to wire in a 220 outlet in garage
post #13 of 19 Old 11-20-2008, 07:56 PM
corvetteguy
OR....get some SJ cable long enough to reach compressor and wire on a plug that matches dryer outlet.......
unlug dryer....plug up compressor and swap when finished.....very easy
post #14 of 19 Old 11-20-2008, 08:14 PM
timatoe
timatoe's Avatar
That shouldn't be too bad. I'd do it for you for a 12 pack if you weren't 4+ Hrs. away. It's really not hard at all, you can get a How To type book from Home Depot or Lowes or the library and be able to handle that small of a job.
post #15 of 19 Old 11-20-2008, 08:20 PM Thread Starter
SuperWade2
SuperWade2's Avatar
Do big AC Units (full sized House Compressor) use 220/240? I just realized that I had AC installed in 2007 and they had to run conduit thru the garage and through the back wall to power this AC unit. It's running to my main outside breaker box out side my Garage adn there is a junction box inside the Garage before it goes outside. Could that be tapped into... It's probably no more than 8 feet from where my current power (and could be closer to where a bigger compressor could live.
BTW, I'm a complete wiring idiot when it comes to home stuff... replaced every wall socket in the house when we moved it and zapped the crap out of myself becuase I was too lazy to figure out which breakers I needed to pull... You would think it would have only taken one zap... I'm a slow learner I guess.
2017 WK2 Overland
Air compressors. BobA Fabrication Shop 24 11-27-2008 05:57 PM
portable air compressors VT_Jeeper General Jeep & Off-Road Equipment 3 07-10-2007 11:53 PM
School me on Air compressors 1984CJ Fabrication Shop 25 06-01-2007 07:25 PM
cheap air compressors turkish6 General Jeep & Off-Road Equipment 13 03-21-2007 08:28 PM
OBA or Air Compressors?? R. Potts General Jeep & Off-Road Equipment 24 12-03-2006 04:01 PM
