Looking to buy a 220v welder - JeepForum.com
post #1 of 14 Old 07-06-2013, 08:20 AM Thread Starter
79CJ7dude
1979 CJ7
So I'm looking to upgrade my 110v welder to a 220v, and was wondering which is better between the Hobart handler 190 and the lincoln 180? Thanks
79CJ7dude is offline
post #2 of 14 Old 07-06-2013, 08:42 AM
rambo3489
I just go the hobart and the thing is amazing. Puts awesome beads down, easy to use, and seems quality. From what I read it is marginally better than the 180. Don't think you can go wrong with either.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #3 of 14 Old 07-06-2013, 10:18 AM
thantos858
1974 CJ5
Both are good welders so you cant go wrong with either. I personally prefer the Hobart handler. A lot of it is going to come down to personal preference on this subject.
thantos858 is offline
post #4 of 14 Old 07-06-2013, 12:34 PM Thread Starter
79CJ7dude
1979 CJ7
Do you think the hobart is worth the extra money? Cause I know with it you can also run a spool gun for aluminum which with the Lincoln I don't know if you can.
post #5 of 14 Old 07-07-2013, 01:33 PM
NalinMFG
I would go with the Hobart over the Lincoln...says the Miller guy.
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #6 of 14 Old 07-07-2013, 01:40 PM Thread Starter
79CJ7dude
1979 CJ7
Also do you think it's worth getting the spool gun with it? It cost like $100 more and I would occasionally be welding aluminum.
post #7 of 14 Old 07-07-2013, 01:51 PM
NalinMFG
You're asking us if you need a welder that does aluminum if you need to weld aluminum?
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #8 of 14 Old 07-07-2013, 04:15 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've owned a Lincoln Promig 175 and currently own a Hobart Ironman 230.
I think it's a tossup. I suppose I'd go with the Hobart since that's what I currently have. However, my Hobart hasn't been without it's issues. The bearing that supports the drive motor's shaft walked out of its bore and slide down the shaft.. causing erratic feeding. I surprised to find that the bearing is a light press fit on the shaft, with nothing (snapring, springwasher..etc) to hold it in place. I tapped the bearing back in place and stacked some washers between it and the drive wheel to make sure the bearing stays in place.. no issues since.
Other than that, my Hobart has held up well to about 100lbs of wire a month or so.
For $100, I'd get the spool gun.. especially if you're gonna mess with aluminum.
BESRK is offline
post #9 of 14 Old 07-07-2013, 07:26 PM Thread Starter
79CJ7dude
1979 CJ7
No I was just asking if the spool gun was worth the extra $
post #10 of 14 Old 07-07-2013, 07:42 PM Thread Starter
79CJ7dude
1979 CJ7
Will it weld floor pans, or are those to thin to weld with this machine?
post #11 of 14 Old 07-07-2013, 08:41 PM
Ironworker709
Ironworker709's Avatar
You can buy spool guns for aluminum for both machines.
Yes you can weld light sheetlmetal..just switch in some .024 wire and put the correct feed wheel on it for that size wire,you'll need to purchase a gas bottle for the MIG if you start welding light sheetmetal,fluxcore will just burn it up
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #12 of 14 Old 07-07-2013, 09:12 PM
rambo3489
Amazon had a package deal when I got my Hobart. +100 for the spoolrunner. SOO I splurged.
<a href="
THE YJ MY WAY</a>
post #13 of 14 Old 07-07-2013, 10:07 PM Thread Starter
79CJ7dude
1979 CJ7
Well I just ordered one from amazon with the spool gun included for $820.
post #14 of 14 Old 07-09-2013, 12:32 PM
rambo3489
Ha. Good choice my friend. Get some gas. The thing is awesome. Totally worth the sticker shock.
<a href="
THE YJ MY WAY</a>
