#91 | |
Geaux Tigers!!!
Did some prep work in the garage today. Starting the rear tomorrow it looks like....
Tommy
2001 Wrangler Sport - 4.5" homemade long arm lift, 1" body lift, 4.56s, 35" MTR Kevlars, 15x8 Pro Comp alloys, D30/Lock Right/alloys, D44/Detroit My Jeep Build Journal Long Arm Suspension Build |
#92 |
Another question for the front.
Is there a clearance issue with mounting the lower arms directly under the frame? I notice with your set-up and claytons kit the Lowers are mounted inside the frame slightly. I just though it might be stronger and easier to mount them directly underneith. |
#93 |
Geaux Tigers!!!
The reason it's mounted there is to keep the rubber bushing from binding. The mounting location is perpendicular to the bolt that holds the bushing in. I could've used a Johnny Joint there instead, but I really don't think it would've gained me much. As it is right now, there's plenty of clearance even under full compression.
Tommy
#94 |
any progress from this weekend?
'95 YJ |
#95 |
Awesome build, I've been checking it daily to see your progress.
I just bought 4-6" RK springs a Long Arm 3-link for the rear of my jeep, I was considering just making the front long arms to save a little money. I might use your topic as a guide.
À tout le monde, À tout mes amis, Je vous aime, Je dois partir. These are the last words I'll ever speak and they'll set me free. Officially driving the Jason Ellis Bandwagon |
#96 |
Geaux Tigers!!!
Today I finally started on the rear long arm build. All I did was minor stuff, really. I cut off the lower front mounts, removed the skid plate and marked it for cutting, mocked up the new lower arms, and took some measurements for the wheelbase and pinion angle. Lots more will be happening over the next week or so. Here's a couple pics...
![]() ![]() Needs to finish grinding... ![]() Tommy
#97 |
This thread is a HUGE help in building my LA's...the round tube you used for the bushing end of your lowers- what was the spec on them- o.d., thickness, & width? I'm debating about ardering these through Rubicon Express as an alternate...
http://www.rubiconexpress.com/Products.aspx?Cn=169&Pn=1960&XnPath=169&Vid=A7B8E6 5663582 |
#98 |
Geaux Tigers!!!
I ordered them through Rubicon Express.
Tommy
#99 |
Geaux Tigers!!!
Did some work tonight finally. Been a long week unrelated to the Jeep. Got the panhard mount off the frame and axle, as well as got the upper arm mounts off the axle. God bless the plasma torch.
Obvioulsy, I haven't finished the grinding, but that's time consuming so it'll have to wait 'til after next weekend's event.![]() ![]() ![]()
#100 | |
#101 |
Geaux Tigers!!!
Oh, I just checked that link. No, those are NOT the RE bushings/sleeves I bought. I'm using what are essentially OEM bushings at the lower axle end and the RE sleeves for them.
Tommy
#102 |
How did you find the proper length of the arms coming form the axels to the frame? I want to do the same thing but I'm not sure what length the arms are suppose to be while keeping the correct geometry. I also don’t know what the pumpkin angle is suppose to be.
#103 |
Geaux Tigers!!!
Pumpkin angle should just be whatever it takes to get your caster right (front) or your pinion angle correct (rear). You just have to build the suspension around that. I'd just gotten my Jeep aligned before I started the front build so I took some caster angle measurements and just made sure I kept the axle at that angle while I fabbed.
There is no "correct" length for the arms. I just built the fronts as long as I could without hitting the skid plate, but the rear requires the skid plate be shortened since it goes so far rearward. I think my lower fronts are about 2" or so longer than my lower rears. Tommy
#104 |
Geaux Tigers!!!
LOTS of progress this weekend and I'm exhausted. Things went pretty slowly, but I began really making some progress today....until I realized I had an issue with the hardware on the front mount of the upper arms. I couldn't get the bolt out as it would hit the t-case. So I had to move the mount rearward and also shorten the upper arms. I still have several things tacked into place until final assembly. Anyway, here's some pics....
Driver side front bracket: ![]() All links installed, brackets tacked into place, suspension at full bump: ![]() ![]() Should I decide to use the upper mounting holes (and plan to jump my Jeep!) I'll need to relocate the e-brake cable mount: ![]() Passenger side approaching full droop: ![]() Driver side fully stuffed: ![]() Truss removed for final welding: ![]() Front brackets removed for final welding: ![]() Oh yeah, the rear axle is nearly as far back as it can safely go. I've got not quite a 1/4" between the diff cover and the gas tank under compression. I can extend it a bit more if I want to push it. I'm going to sleep.... ![]() Tommy
#105 |
VERY NICE!! I wanna take on a project like this soon but the only thing stopping me is my Jeep is my DD and my only vehicle.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
