Quantcast Long Arm Build for a TJ - Page 4 - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Long Arm Build for a TJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 03-18-2008, 10:58 PM   #46
Tommy R
Geaux Tigers!!!
Tommy R's Avatar
Made some progress tonight. So I decided to make new front lowers because the originals weren't providing enough thread engagement with the elongated front wheelbase. Here's the new arms installed at the same length the original ones were set at. I estimate the wheelbase now to be approximately 1.5" longer than it was.
I'll use the original front lowers for the rear lowers. That'll be in a couple weeks.
I also welded the brackets to the frame rails. Not entirely, because I want a second person around to hold the exhaust out of the way while I weld inside the rails, but it's coming along nicely. I started with tight welds and made 2-3 passes so far:
The second issue I've come across is this... The sway bar and bracket contact the drag link ball joint when turning to full lock. I tried using a sleeve of tubing to raise the pin out of the way and it worked, but it just revealed the ball joint/bracket issues. I'll hack the OEM bracket and make something that'll provide more clearance.
Believe it or not, the bolt head doesn't contact the ball joint, but it's way too close. But, the axle is lacking some caster at the moment so when leaned back it may be a non-issue:
Tommy
2001 Wrangler Sport - 4.5" homemade long arm lift, 1" body lift, 4.56s, 35" MTR Kevlars, 15x8 Pro Comp alloys, D30/Lock Right/alloys, D44/Detroit
My Jeep Build Journal
Long Arm Suspension Build
Tommy R is offline   Reply With Quote
Old 03-19-2008, 07:42 AM   #47
geauxturbo
You can grind that bolt head down a little.. I did. We don't live in the rust belt and if you can't get it off, you can always grind it the rest of the way off.
Dude, your junk is lookin' HAWT. Good work man.
Louisiana 4X4
'97 TJ Sport Black, 3.5" RE, PSC Trail Cage, Ford F150/Explorer Hybrid 8.8 Aussie locked, Lockright in the XJ HP 30, 4.88 gears, Borla Headers, No Muffler, 35x12.5 R15 Baja MTZs, Currie TrackBar. Homebuilt Longarm 4 link, AA HD SYE, TW CV DS, Warn tire carrier, Jeeperman front bumper, Warn X8000i with Amsteel Blue rope with a safety thimble, CO2
GeauxLook@myJeep
geauxturbo is offline   Reply With Quote
Old 03-19-2008, 07:53 AM   #48
Tommy R
Geaux Tigers!!!
Tommy R's Avatar
Not sure how I feel about a guy telling me my junk is hot, but I'm flattered just the same.
Yeah, I'll grind that bolt head, if necessary. The big(ger) concern is the ball joint clearance, but it shouldn't be a big deal.
Thanks for compliments, Lance! And thanks for letting me check out your rig when I was in town. Let me know when you get up to Austin!
Tommy
Old 03-19-2008, 10:54 AM   #49
WingnuTJ
Great write up!
Just a concern that was mentioned before.... Where you arm attaches to the frame I see a Zerk fitting just begg'n to get ripped off. Just my opinion! That would bother me and just incase
"I'm We Todd did"
Either way love the write up, like I mentinoed before! keep up the pic's and posts!
Lifes a Jeep! Wheel IT!
WingnuTJ is offline   Reply With Quote
Old 03-19-2008, 12:33 PM   #50
1 ton yj
JJ's are greaseable through the bolt as well.
1 ton yj is online now   Reply With Quote
Old 03-19-2008, 03:36 PM   #51
Tommy R
Geaux Tigers!!!
Tommy R's Avatar
Oh, thanks for the comment, but before I do final installation I'll rotate the joints 1/2 a revolution to get the zerks up top.
Tommy
Old 03-19-2008, 07:00 PM   #52
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
you can also get flush grease fittings.
go to www.mcmaster.com and type in " Flush-Style Grease Fittings"
I'm going to go with those eventually. I think i've broken around 4 or 5 grease fittings off so far with my clayton system.
for example
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is offline   Reply With Quote
Old 03-19-2008, 10:25 PM   #53
Tommy R
Geaux Tigers!!!
Tommy R's Avatar
Dangit. I would've had all the welding done tonight, but I ran through the spool of wire before I finished. Ugh! Anyway, so tonight I made the upper arms, finished welding the brackets to the frame, and got everything tacked together. Here's some pics....
And removed ready for final welding:
Tomorrow I finish welding and start painting and clearance the ball joint/sway bar bracket. Friday I reassemble. Saturday I take it to get aligned. I can't wait!
Tommy
Old 03-19-2008, 10:47 PM   #54
Airborne4X4
1979 CJ7
Nice work. Keep it up. Too many threads started around here and then forgotten, so keep us informed about this build. You're making me itchy for a long arm build of my own.
Chrome can get you home, you can signal the search aircraft with it!
Airborne4X4 is offline   Reply With Quote
Old 03-19-2008, 10:51 PM   #55
Tommy R
Geaux Tigers!!!
Tommy R's Avatar
Thanks! It's been fun, but tiring and a lot of work since I only have maybe 3/4 of the tools I'd like and my garage is way too small.....but whose isn't, right?
Tommy
Old 03-20-2008, 09:48 AM   #56
tweba99
Are you planning on butt welded those nuts to the tube for your uppers?
1999 Jeep TJ on 1 tons (OLDER)
2003 Jeep Rubicon (OLD)
2008 Jeep Unlimited X (NEW)
tweba99 is offline   Reply With Quote
Old 03-20-2008, 10:03 AM   #57
Tommy R
Geaux Tigers!!!
Tommy R's Avatar
Yup, just butt welded. A sleeve like I used for the lowers would've been nice, but wasn't available. At least the uppers aren't subjected to the same stresses and loads as the bottoms so I'm confident it'll hold up fine.
Tommy
Old 03-20-2008, 11:54 AM   #58
tweba99
Tommy
I am sure it will hold up fine since Geauxturbo's is but I would say that the uppers are under just as much stress, if not more than the lowers, just not impact loads.
They do make round inserts in the size you would need for the uppers. I used round inserts on all of my arms since square inserts were not available. I am running a different suspension setup than you front and rear and I am running 2"x.25" tubing for my uppers and lowers so I could use the same inserts on everything.
Old 03-20-2008, 10:54 PM   #59
Tommy R
Geaux Tigers!!!
Tommy R's Avatar
Well, the uppers will be under compression and tension, but not subjected to the bending forces the lowers will see when I'm resting on rocks and such. I would've liked inserts, nonetheless, but I couldn't find any in the size I was using. I made a ton of progress tonight, but smugmug appears to be down right now so I can't access the pics I just uploaded and post them here yet. Yeesh!
Tommy
Old 03-20-2008, 11:38 PM   #60
Tommy R
Geaux Tigers!!!
Tommy R's Avatar
Got the arms all welded up tonight and primed and applied a quick coat of satin black. It could use a better paint job, but I don't really care about that right now.
Tomorrow after work I hope to get things wrapped up.
Tommy
Glock Forum
