Long Arm Build for a TJ - Page 19 - JeepForum.com
 1Likes
post #271 of 307 Old 01-31-2012, 04:58 PM
Jeepinty
I planned on hitting K2 the first weekend in March but my wheeling buddy couldn't get off work. Been trying to get to Moab for years but something always comes up, maybe next year. I am trying for Trees in late March and whatever else I can make after that. Hot Springs, Clayton, K2, Hidden Falls are all on my list depending on my schedule of course.
Jeepinty is offline
post #272 of 307 Old 02-15-2012, 08:08 PM
yjwrongler
where did you buy your link ends, bushings and square weld in bungs ?
yjwrongler is offline
post #273 of 307 Old 02-22-2012, 06:31 AM
Jeepinty
Not sure where he got his from but you can buy the link ends and bushings from just about anywhere, clayton Offroad, KORE, poly performance are the ones I would recommend. The square tube bungs can be bought from Clayton or Ballistic Fab if you want to take a chance that their "restructuring" did any good at making their service not suck. You can even make your own with the right size nut and a little grinding although the actual ones made for joints are better IMO.
Edit: by making your own I mean like this dude did, although please don't use these frame brackets
http://www.jeepforum.com/forum/f37/t...build-1027918/
Jeepinty is offline
post #274 of 307 Old 02-22-2012, 07:01 AM Thread Starter
Tommy R
Tommy R's Avatar
Yep. And pretty much all of that stuff is already listed here in this thread 'cause it's been asked before.
2001 Wrangler homemade long arm, 99" WB, ARBs, alloys, 4.88s, 35" MTRs
Tommy R is offline
post #275 of 307 Old 02-22-2012, 07:40 PM
yjwrongler
I've been looking through threads for the past week on making my own long arm kit and I've come to the point where I just look at the pictures to see if it looks like it's worth reading about, pictures first, words later....... and this thread has a lot of pictures lol
post #276 of 307 Old 02-22-2012, 09:00 PM Thread Starter
Tommy R
Tommy R's Avatar
No worries! There's a ton of info. in here for sure, but because I still get loads of e-mails and PMs about it, I simply can't take all the time to sift through to find all the specific answers.
But if you do have any questions that haven't been answered in the thread, by all means post it!
Tommy R is offline
post #277 of 307 Old 02-23-2012, 10:14 AM
yjwrongler
will do
post #278 of 307 Old 03-11-2012, 10:55 PM
97flexy
I saw your post about the company that sells those sweet square tube inserts, but the link doesn't work do you know if any one else sells those tube inserts I really don't want to make my own.
Check out my LCG build
http://www.wranglerforum.com/f118/my-low-budget-dd-lcg-build-142567.html#post2079244
97flexy is offline
post #279 of 307 Old 03-11-2012, 11:20 PM Thread Starter
Tommy R
Tommy R's Avatar
The company is (was?) 4WD Factory. Not sure if they went under or what, but I've heard other companies like Blue Torch or Ballsitic are now making them. I'd check with them first.
Tommy R is offline
post #280 of 307 Old 03-11-2012, 11:25 PM
Jeepinty
Clayton also carries them, ballistic fab had really nice onesat one time but they are going through a restructuring which I hope works because their service before was beyond horrid.
Jeepinty is offline
post #281 of 307 Old 03-12-2012, 08:13 AM
97flexy
yeah I've found other tube inserts like AtoZfab.com has them too, but if its was possible I like to idea of the square insert into the square tube.
97flexy is offline
post #282 of 307 Old 03-12-2012, 04:42 PM
wushaw
Rockin jeep
wushaw's Avatar
There isn't any issue with the round peg in a square hole with the liquid wrench, you will still be welding it completely around it.
There is also no wiggling around of the tube insert in the square hole.
wushaw is offline
post #283 of 307 Old 03-18-2012, 10:41 AM
97flexy
thanks, I'm going to go with square lower tubes and Ballistic joints, I'm just try'n to decide if I want to go with 1/4" wall or 1/8" wall. Either wall thickness I go with I was thinking of welding a solid sq rod inside my lower arm. Has anyone done this for added strength? For example: If i use a lower arm that is 1-1/2" SQ {A} x 1.260" ID {B} x .120" Wall and I weld in a 1.25" solid rod into the center of the sq tube with ends at each end, wouldn't that be stronger than 1/4" tube?
97flexy is offline
post #284 of 307 Old 03-18-2012, 03:02 PM
wushaw
Rockin jeep
wushaw's Avatar
Yes if you were to weld it the entire length or stitch weld, it would resist bending a whole lot....I do not have numbers or anything but anytime you glue, weld or rivet two pieces or metal together they become extremely stiff.
wushaw is offline
post #285 of 307 Old 03-18-2012, 04:46 PM
97flexy
okay I might just go with 1/8th wall I was thinking of plug welding the inner sq stock to the outter tube... maybe 2 plug welds per side totalling 8 plug welds per link not including the ends. My buddy said he'd weld it up for super cheap as 1/4" wall and 1.5" solid stock... I'l have to ask him if it'll be cheaper to weld 1/8" and 1.25" stock, if not I may just go with 1/4" tube.
97flexy is offline
35" tire build - FULL TRACTION lift - long arm. What one to get Sparty TJ Wrangler Technical Forum 3 03-13-2011 12:04 PM
When are long arms too long Vacant Stare Tires & Wheels 4 12-04-2007 06:08 AM
Driving around the trails in 4 Low. How long is too long? televisionary General Jeep & Off-Road Equipment 28 03-10-2007 08:04 PM
R.E. 4.5 Long Arm vs Rockkrawler Long Arm? budzilla Tires & Wheels 15 02-23-2005 04:20 PM
