Long Arm Build for a TJ - Page 18 - JeepForum.com
 1Likes
post #256 of 307 Old 08-12-2010, 10:31 AM
johnny9
they will be in my punisher build thread in 4-5 hrs
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
post #257 of 307 Old 04-13-2011, 12:36 PM
jpony645
I just wanted to add something I found today for anyone looking to do this project. I bought the 1.5" square tube inserts from Ballistic Fab ($17/each at the time but they've gone up) because they were the only ones I could find for square tube. Also could never find any for the 1"id tube. Well today i'm looking around and Clayton has some. I can't remember if I searched them specifically the first time or not but today I found the inserts. They aren't exactly the same as the Ballistic ones but since Clayton is the mainstay for square tube long arms I figure these will work just fine.
$8.00/each for the 1" and $10/each for the 1.5"
http://claytonoffroad.com/product_in...s_id/263{23}94
jpony645 is offline
post #258 of 307 Old 08-22-2011, 02:10 PM
cotoole
what was the effect of stretching your wheelbase out? is there any effect on your driveshafts with the longer base?
99 wrangler sport, 32x11.5 MT/Rs, CB, FIPK, Home-made sliders/rocker guards, Black mountain Hardtop (get a GR8Top), and an UGLY bumper.
cotoole is offline
post #259 of 307 Old 08-31-2011, 01:55 AM
GIJOE1914
BEST BUILD THREAD THUS FAR.....I was talking about LA's today and said I refuse to pay 2k for a LA kit and came across this. Thank you sir! YOU ARE A GENTLEMAN AND A SCHOLAR! I shall get on this TOMORROW with parts!
GIJOE1914 is offline
post #260 of 307 Old 08-31-2011, 09:11 AM Thread Starter
Tommy R
Tommy R's Avatar
It helps with approach/departure angles. I stretched the wheelbase so little it wasn't an issue. In reality, the wheelbase it only about 1.5" longer than stock...if that. However, I may put some shorter springs on in the future and that will stretch the wheelbase a bit more.
Thanks a lot! Happy to help!
2001 Wrangler homemade long arm, 99" WB, ARBs, alloys, 4.88s, 35" MTRs
Tommy R is offline
post #261 of 307 Old 10-18-2011, 10:59 PM
thisguyhasadd2
with the jj and oem bushings and link stock how much did you end up spending to do the front and rear. can you estimate costs if you got any scrap for free?
thisguyhasadd2 is offline
post #262 of 307 Old 10-19-2011, 07:03 AM Thread Starter
Tommy R
Tommy R's Avatar
I covered this in post #75.
Tommy R is offline
post #263 of 307 Old 01-08-2012, 08:46 AM
tmaker
Originally Posted by Tommy R View Post
It definitely rides better than with the short arms. No comparison. But I'm running both radius arms up front now for two reasons. 1) I didn't see any improvement in offroad performance with just one and 2) I felt more comfortable with two uppers in place in case any bolts accidentally backed out or sheared. But otherwise, the single radius arm setup worked fine. If/when I re-do the front axle I'll build a single upper link and sell these radius arms.
Ideally, I'd run JJ's at the axle and chassis ends, but it's too much money and I don't know if it's necessary. It flexes more than my shocks can handle as it is.
Tommy
I am doing this build now and am planning on running both upper arm for the front radius arms but I plan to mill the passenger side arm hole to a slot so it can move some but still hold in the event that a bolt breaks on the driver side. I plan to drill the bolt for a key so the bolt can be ran just snugged. When flexed it will be able to move some an help the binding.
tmaker is offline
post #264 of 307 Old 01-31-2012, 09:20 AM
jpony645
Does it make any difference whether you run the rubber joint on the frame or axle end of the arm?
jpony645 is offline
post #265 of 307 Old 01-31-2012, 09:38 AM Thread Starter
Tommy R
Tommy R's Avatar
Yes, it does matter. Well, assuming you're talking about the front radius arms. The axle needs to be allowed to "twist" during articulation, which means there needs to be rubber above and below the axle housing. If you run only one radius arm, you can run solid joints throughout with no rubber.
Tommy R is offline
post #266 of 307 Old 01-31-2012, 09:58 AM
jpony645
I went back and looked at your pictures and also those from Clayton and see the rubber bushing on the axle side in both now. For some reason I had it in my head that having the joint on the axle would let it "twist" more but I see now that wouldn't work so well with the rubber bushings still in the upper mounts.
jpony645 is offline
post #267 of 307 Old 01-31-2012, 11:31 AM
Jeepinty
Wow this thread is still going. This and Tweebas build convinced me to build my own long arm stretch. Thanks
Jeepinty is offline
post #268 of 307 Old 01-31-2012, 11:35 AM Thread Starter
Tommy R
Tommy R's Avatar
LOL, yeah, it's been hanging in there for quite a while now. I guess that's a good thing! Glad we were able to convince you to do your project!
Tommy R is offline
post #269 of 307 Old 01-31-2012, 11:57 AM
Jeepinty
You going to wheel Trees this year? The March run will probably be the shakedown for mine.
Jeepinty is offline
post #270 of 307 Old 01-31-2012, 11:58 AM Thread Starter
Tommy R
Tommy R's Avatar
Maybe! I'm heading to Katemcy 2 on the weekend of 2/18. Not sure what my plans are otherwise....though I hope to make it to Moab again if I can swing it.
Tommy R is offline
35" tire build - FULL TRACTION lift - long arm. What one to get Sparty TJ Wrangler Technical Forum 3 03-13-2011 12:04 PM
When are long arms too long Vacant Stare Tires & Wheels 4 12-04-2007 06:08 AM
Driving around the trails in 4 Low. How long is too long? televisionary General Jeep & Off-Road Equipment 28 03-10-2007 08:04 PM
R.E. 4.5 Long Arm vs Rockkrawler Long Arm? budzilla Tires & Wheels 15 02-23-2005 04:20 PM
