Long Arm Build for a TJ - Page 17 - JeepForum.com
 1Likes
post #241 of 307 Old 07-06-2010, 03:20 PM
johnny9
hey thanks a lot..i guess what im trying to ask is in this pic of the core bracket
Universal 4 Link Bracket Kit
this bracket sets the rear lower on the inside a lil bit and a slight angle..seems like its a good ldea but im up and down about it lol..and if i put my brackets on a mount that wraps the frame i could even lift them up a extra inch for better clearance..i think a lot of kits put them up higher also for a smooth transision to the belly pan..
i only have a 4 inch lift and guess im just worried the arms will hit the frame with the brackets "almost"in line like yours..
i probally worry to much,haha
i do good work but always doubt myself"old habits"..thankfully some of us just need to see others work to get that lil push we sometimes need..
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
post #242 of 307 Old 07-06-2010, 06:52 PM
johnny9
ok maybe this makes more sense..this is high clearanced looking to me,but on the inside a lil and angled a lil..
this is what i was gonna do but dont want to mess up..every nice bracket set i see for high dollar are just like this..i can do this easy if its better than just under the frame..
i still have 2-3 weeks before i get this done on the front..in my mind it seems the front would be fine like this also..more clearance.
opinions please
http://www.polyperformance.com/shop/...6-01-D-200.jpg
build-
johnny9 is offline
post #243 of 307 Old 07-06-2010, 07:36 PM Thread Starter
Tommy R
Tommy R's Avatar
I understand now what you're after. I don't see any reason it wouldn't physically work, but you'll need joints at the axle end, not just bushings. What would concern me more is that your forward mounts for both the uppers and lowers will be higher and your geometry (particularly anti-squat) could get thrown off. Personally, I would go the conservative route that's proven unless you plug ALL the numbers into a calculator beforehand. It might work out great, but I wouldn't chance it without running the numbers.
In all honesty, though, that second pic doesn't look much more high clearance than my setup. Maybe an inch or so? I could work, just not sure if it's worth the hassle when it's so easy to mount the brackets directly under the axle.
2001 Wrangler homemade long arm, 99" WB, ARBs, alloys, 4.88s, 35" MTRs
Tommy R is offline
post #244 of 307 Old 07-06-2010, 08:02 PM
johnny9
thanks..that inch was what i wanted..i will go under the frame im sure..i was just wanting the most clearance i could get and not waste my hard work on the belly up i made..oh well,i got 3/8 plate for the rest of the mounts,i could always just drag it thru the rock like we all do anyway lol..sorry to keep asking so much but your the one that did push me into this
thanks for being a pusher for sure..im tired of the back pain on s arms..
build-
johnny9 is offline
post #245 of 307 Old 07-06-2010, 09:33 PM Thread Starter
Tommy R
Tommy R's Avatar
LOL, no problem, man. Keep the questions coming.
Tommy R is offline
post #246 of 307 Old 07-08-2010, 09:08 AM
jpony645
Tommy, do you know on the lower control arm brackets if they are perpendicular to the axle or if they are angled slightly? I've bent the crap out of mine and am going to replace them but need to find out if they're angled before I order new brackets.
jpony645 is offline
post #247 of 307 Old 07-08-2010, 10:37 AM Thread Starter
Tommy R
Tommy R's Avatar
Are you referring to the front or rear? I assume the chassis side brackets? I guess it doesn't really matter, actually. The control arms (front and rear) are inline with the original axle brackets. So they are basically inline with the original control arms, if that makes sense.
Tommy R is offline
post #248 of 307 Old 07-08-2010, 01:49 PM
johnny9
im curious too about what he said but dont think it matters due to all the room there will be for the joint to move around.
this is a couple pics after mocking it up on the frame inline w/the frame and square to the axle,,after removing it all you can see the angle of the joint and tube being off a lil where i took the pic..
i think i will stay like this since when the axle drops down the joint will be shooting back to the inside of the bracket the oppisite of the angle in the pic"at least it sounds good to me hopefully,haha
[IMG][/IMG]
if it wasnt for your inspiration tommy,like many others,i wouldnt have jumped into this..even tho ive been a fabricator for 25 yrs..thanks again you pusher
build-
johnny9 is offline
post #249 of 307 Old 07-08-2010, 02:24 PM
jpony645
I was actually asking about the brackets on the axle side but I found my answer. They're 5 degrees offset. I bent the crap out of mine and wanted to go ahead and order some HD ones but needed the offset before I could.
jpony645 is offline
post #250 of 307 Old 08-12-2010, 07:41 AM
johnny9
thanks for the info and this thread tommy my front has been done for a week now and seems to be doing fine..im gonna weld the axle tubes today just in case something wants to move lol..now ive got to get the d.shaft made a lil longer..i did exactly what you did and wish i would have made them a inch longer lol..live and learn the hard way right,haha
build-
johnny9 is offline
post #251 of 307 Old 08-12-2010, 07:53 AM Thread Starter
Tommy R
Tommy R's Avatar
Congrats!! It's a good feeling, isn't it? You can always cut/sleeve/extend your arms to get a little more length if need be.
Tommy R is offline
post #252 of 307 Old 08-12-2010, 08:35 AM
johnny9
thanks,a good guy here on the forum gave me the idea to use them on the rear and make new fronts
have a great weekend
build-
johnny9 is offline
post #253 of 307 Old 08-12-2010, 08:41 AM Thread Starter
Tommy R
Tommy R's Avatar
LOL! Sounds like that dude's a genius. I'd listen to him! So have you decided when you're going to tackle the rear end?
Tommy R is offline
post #254 of 307 Old 08-12-2010, 08:44 AM
johnny9
its so frickin hot hear in fla i was soaked at 6 am this morning lol..im gonna wait till some cooler wheather gets hear to triangulate the rear i think..
makeing axle skids and welding the tubes in a few minutes.
i need a desk job in some a/c lol,getting old aint for sissys,haha
build-
johnny9 is offline
post #255 of 307 Old 08-12-2010, 10:11 AM Thread Starter
Tommy R
Tommy R's Avatar
Dude, I hear ya! Texas isn't exactly "cool" this time of year. If you document the skid plate builds, post up the link.
Tommy R is offline
35" tire build - FULL TRACTION lift - long arm. What one to get Sparty TJ Wrangler Technical Forum 3 03-13-2011 12:04 PM
When are long arms too long Vacant Stare Tires & Wheels 4 12-04-2007 06:08 AM
Driving around the trails in 4 Low. How long is too long? televisionary General Jeep & Off-Road Equipment 28 03-10-2007 08:04 PM
R.E. 4.5 Long Arm vs Rockkrawler Long Arm? budzilla Tires & Wheels 15 02-23-2005 04:20 PM
