Long Arm Build for a TJ - Page 16 - JeepForum.com
 1Likes
post #226 of 307 Old 03-23-2010, 01:09 PM
cmcfab
Awesome Thanks for the response Tommy. I would have thought the rear would drop more without the bar. Maybe the front still wasn't high enough for it to completely droop unless the shocks were limited. Whats length shocks are you running? I will most likely relocat the shock mounts for optimum travel using a 12-14" travel shock, depending on test measurments. Unfortunatly there isn't much room in the rear to run the shock in a forward postions which would give you more travel out of a smaller length shock.
Thanks for the pics.
cmcfab is offline
post #227 of 307 Old 03-23-2010, 02:09 PM Thread Starter
Tommy R
Tommy R's Avatar
I think the shocks were/are the limiting factor in my suspension travel. They are off-the-shelf Rancho shocks for a 4.5" lifted TJ. Not sure what the overall lengths are. I'm also planning on modifying the shock mounts eventually, but haven't really felt the need yet since the suspension works so well as-is.
2001 Wrangler homemade long arm, 99" WB, ARBs, alloys, 4.88s, 35" MTRs
Tommy R is offline
post #228 of 307 Old 03-23-2010, 06:21 PM
cmcfab
I usually fab adjustable mounts for limit straps so to stop the shock from extending about .5in before full extension. This way the shock won't bust, especially when using higher end shocks. The limit straps will stretch after time and when wet but not much. A 1/2 threaded bar inside a welded piece of DOM tubing to the frame with a tab welded to the threaded bar will allow you to adjust the limit strap.
Thanks for the info Tommy. Hopefully i will be starting a front end build soon.
cmcfab is offline
post #229 of 307 Old 03-23-2010, 09:10 PM Thread Starter
Tommy R
Tommy R's Avatar
Yeah, I'm always intended on getting limiting straps, but just haven't made it a priority. Fortunately, I think these things have a lifetime warranty...
Tommy R is offline
post #230 of 307 Old 03-26-2010, 04:08 PM
cmcfab
Hey Tommy, Are you running the stock axles D30/d35? It looks like you do some HD off roading. How are your stock axles holding up if your still using them?
cmcfab is offline
post #231 of 307 Old 03-28-2010, 04:25 PM Thread Starter
Tommy R
Tommy R's Avatar
No D35 for me. The axle specs are in my sig: D30 front with a Lock Right and alloys and a factory D44 rear with a Detroit.
Just got home from the Jeep Jamboree in Llano, TX. Will be posting a full write-up in my build journal later on. The suspension came through with flying colors again. Very, very pleased with it!
Tommy R is offline
post #232 of 307 Old 03-28-2010, 04:57 PM
cmcfab
Sweet, so it sounds like the stock axles hold up pretty good when you have a good suspension to go along with. Do you use the car as a DD or tow it when off roading?
Alloysin the D30, are you talking about your axles? Chromoly?
cmcfab is offline
post #233 of 307 Old 03-29-2010, 07:22 AM Thread Starter
Tommy R
Tommy R's Avatar
I think a well set up suspension will only help you by not requiring the use of the skinny pedal to get up stuff. I'm always paranoid about breaking so I take it pretty easy on my equipment. I always try crawling first, then I'll try bumping, but I know when to call it quits and try another route. Ultimately, I think that's why my axles (mainly the front) have lasted as long as they have. I only recently went to alloys just a couple trips ago. Even Moab was on stock axles.
And yes, I'm running chromoly axles in the D30, but not in the D44.
Tommy R is offline
post #234 of 307 Old 04-10-2010, 03:55 PM
johnny9
i like the way you talk,haha... after reading this thread for almost a yr now im gonna go ahead a do my front radius arms in the next few months and use this thread as a refrence on your brakets and lots of other things..thanks tommy
i was gonna do a double triangulated 4 link rear but after seeing many regular 4 links with the uppers trussed and triangulated that seem to work great i think this is what i will do.
question...with just the rear upper triangulated can i still do away with the rear track bar and not feel any rear steer,thanks for the great thread.
JACK OF ALL TRADES,,,MASTER OF NONE
fla cracker head born and bred
build-
johnny9 is offline
post #235 of 307 Old 06-12-2010, 08:48 PM
Jeepinty
Hey Tommy, still planning on hanging a 60 and 14b under there? I am waiting to do my long arm until I do the tons.
Jeepinty is offline
post #236 of 307 Old 06-14-2010, 07:19 AM Thread Starter
Tommy R
Tommy R's Avatar
Johnny,
I don't think running a track bar in the rear with a semi-triangulated 4-link would be a good idea. I think it would bind. I'd opt for a semi-triangulated 4-link or a parallel 4 link with a track bar. But you see which way I went. Yes, I do still get a little visible rear steer since it's not fully triangulated, but it's never been noticeable off road. And it's definitely never been an issue on the street due to it's limited travel on pavement.
I'd just triangulate the uppers and call it done. Also, keep in mind triangulating the lowers may interfere with the driveshaft or require a very low mounting point. Unless you're running really tall tires, this could seriously impact (pun intended!) your ground clearance. As a frame of reference, it's been two full years of wheelin' on my setup and there's still nothing I would change.
Good luck!
I don't think so. For a few reasons... I think I may only want to go as big as 37s and a nicely built D44 front/rear would likely survive forever in my Jeep since I'm not a "skinny pedal wheeler". Don't get me wrong, I'd love a pair of tons under there, but I think a set of 44's will get me where I want to be and with more ground clearance. I would source a Ford front D44 from a '70s model. For the rear I would either step up to a 9" or maybe just build up my stock 44. Not sure yet.
But for now, I'll just leave it as is. Not sure if I mentioned it here yet, but I recently picked up a new money pit. I'm about to build my dream car and it's going to be "calling dibs" on all my extra money and time over the next year or two. No, I don't plan to sell the Jeep, but Jeep mods will be kept on the "cheap & easy" until the car is built.
Here's what I picked up. It's a '30 Ford Model A that I'm building into a vintage style hot rod.
No, it's not getting 35" tires! We were just being goofy mocking it up.
Tommy R is offline
post #237 of 307 Old 06-14-2010, 09:51 AM
johnny9
thanks tommy,,ive learned this since lol..but hey,we all learn from somewhere or someone..thanks for your thread,,i had a great weekend also,with my short arms.have a great week bro,johnny9
[IMG][/IMG]
build-
johnny9 is offline
post #238 of 307 Old 07-03-2010, 06:06 PM
johnny9
back for another question..it looks like your frame mounts are "almost" inline with the frame?
i was looking under mine today mocking up brackets and it seems they will have to be off set to the inside to clear the frame under full stuff..
i see some brackets they sell are like this.just wondering if your arms hit the frame when stuffed,and are they inline with the frame kinda or offset....thanks
build-
johnny9 is offline
post #239 of 307 Old 07-05-2010, 03:56 PM
twister4fun
I've just completed my front long arm based on what Tommy has done. My brackets offset the arm mount a little inboard. I have a build thread going with exact measurements for everything if you're interested. A couple draw backs if you don't offset is tire interference at full lock, and bushing bind. Just my experiance
http://www.jeepforum.com/forum/f9/ri...thread-908929/
twister4fun is offline
post #240 of 307 Old 07-06-2010, 08:34 AM Thread Starter
Tommy R
Tommy R's Avatar
Do you mean up front? Here's my left front arm looking back from the front axle.
And another shot.
So basically, I likely did the same thing you did. I put the bushing in the axle end mount and swung the arm up 'til I saw where it would hit the frame. I would've preferred it to be centered, but it's no biggie. For the most part, it's flush on the outside which looks better.
FYI, the rear was pretty much the same, i.e. flush on the outside and inset to the inside of the frame rail.
No issues under full stuff. Here's a pic when I threw it on an RTI ramp to check for clearances. It may look close 'til you realize just how much farther my tire would need to travel upward in order to get the control arm to hit the frame!
FYI, my shocks are my bump and droop limiters. If I ever get back to playing with the suspension on this thing I'll sell my Rancho RS9000's and make some custom mounts to house longer shocks.
Any more questions, feel free to ask. I'll help any way I can....
Tommy
Tommy R is offline
35" tire build - FULL TRACTION lift - long arm. What one to get Sparty TJ Wrangler Technical Forum 3 03-13-2011 12:04 PM
When are long arms too long Vacant Stare Tires & Wheels 4 12-04-2007 06:08 AM
Driving around the trails in 4 Low. How long is too long? televisionary General Jeep & Off-Road Equipment 28 03-10-2007 08:04 PM
R.E. 4.5 Long Arm vs Rockkrawler Long Arm? budzilla Tires & Wheels 15 02-23-2005 04:20 PM
