Quantcast Long Arm Build for a TJ - Page 14 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Long Arm Build for a TJ
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 09-07-2009, 09:55 PM   #196
gtospeeding
Does anyone have a pair of front upper control arms laying around after their long arm install?
Im doing an experiment and need a pair with good bushings
gtospeeding is offline   Reply With Quote
Old 09-07-2009, 10:25 PM   #197
06rubcion
jmop i would have done jj on both ends and not used bushings, they limit flex
06rubcion is offline   Reply With Quote
Old 09-08-2009, 08:22 AM   #198
Tommy R
Geaux Tigers!!!
Tommy R's Avatar
They also cost more and my shocks already get maxed out with the flex I've got. And in the front, you can't use JJs on both ends for reasons that have already been discussed here.
2001 Wrangler Sport - 4.5" homemade long arm lift, 1" body lift, 4.56s, 35" MTR Kevlars, 15x8 Pro Comp alloys, D30/Lock Right/alloys, D44/Detroit
My Jeep Build Journal
Long Arm Suspension Build
Tommy R is offline   Reply With Quote
Old 09-08-2009, 05:12 PM   #199
Jeepinty
Tommy, I got to see your jeep up close this weekend at Trees (I was the guy camped next to ya'll who borrowed the lighter). Anyways, I was impressed by the quality of the build using minimal tools and a basic knowledge of suspension geometry.
As far as the radius arms are concerned, a friend of mine ran a basically stock RE long arm kit on his TJ buggy for years and had a rediculous amount of flex running a D60 and 37 Krawlers HARD. I never saw him twist anything or shear a bolt. I would strengthen the stock passenger UCA mount if you keep running it though.
Awesome build, keep up the good work.
Jeepinty is offline   Reply With Quote
Old 09-08-2009, 05:28 PM   #200
Tommy R
Geaux Tigers!!!
Tommy R's Avatar
Thanks a lot! You should've introduced yourself. Always nice to put faces to (screen)names. What I'm thinking about doing now is build a true upper third link on the driver's side. Instead of the OEM bushing, I'll look to replace it with a Currie insert like in this kit:
Old 09-08-2009, 05:33 PM   #201
Jeepinty
Honestly I thought about it but figured you get that a lot. I have a hard enough time remembering names myself, lol. Anyways, I like the idea of a true 3 link front, should get rid of any binding that may be present. Interested to see the turn out.
Old 09-08-2009, 05:51 PM   #202
Tommy R
Geaux Tigers!!!
Tommy R's Avatar
I appreciate the consideration, but I'm always up for meeting folks. Next time come on by and have a beer with us.
Old 09-08-2009, 07:10 PM   #203
Jeepinty
I'll keep that in mind. One question about your radius arms though. I think you used the 2.5 inch JJ for the short radius arms but I'd have to look back. I think RE uses the smaller joint for the link end of the short radius arm. That is my reasoning behind building me some rear uppers (to adjust pinion angle until I can do the long arm build) and using the stock 2" size that can be reused as the radius arms later on.
Old 09-10-2009, 05:20 PM   #204
ET48
Is there any reason why you couldn't take the lower control arms all the way towards the center of the skid to make them even longer?
(Shown below) Utilize one mount per side for both front and rear lower control arms. Just an idea.....
ET48
1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs.
1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s.
ET48 is offline   Reply With Quote
Old 09-10-2009, 07:12 PM   #205
tweba99
I will help on answering this one......
When building long arms, it is all about the geometry/wheelbase and that is what determines the length of your arms. You have to also take into account that the longer the control arms, the more the chance that they will get bent while playing in the rocks.
1999 Jeep TJ on 1 tons (OLDER)
2003 Jeep Rubicon (OLD)
2008 Jeep Unlimited X (NEW)
tweba99 is offline   Reply With Quote
Old 09-10-2009, 08:23 PM   #206
ET48
I can see the geometry having an effect on the length of the arms, but my wheel base determines the length of the arms......that makes no sense.
Why then would you be able to run short arms and long arms?
ET48
Old 09-10-2009, 10:39 PM   #207
churchofjt
I'm no expert certainly, but I think I could see the wheelbase determining things like instant center and what-not. I think that if you messed with one dimension like the link length, it might throw off the squat. Am I way off track?
churchofjt is offline   Reply With Quote
Old 09-11-2009, 06:15 AM   #208
tweba99
Height, wheelbase and tire size have to do with the length of the arms which all determine where your instant center is. Go over to pirate4x4.com and you can learn ALOT about building suspensions, how they work and it will probably answer any and all questions that you have.
You are correct.
Old 09-11-2009, 11:13 AM   #209
ET48
Sounds like a good plan.....
ET48
Old 10-23-2009, 12:34 PM   #210
sebastian22
Go Kings Go!
sebastian22's Avatar
Great thread! Does anyone know where I can find bushing sleeves?
Edit: Found it! Post 97 and 98 if anyone else has the same question. Rubicon Express part # RM12600. My bad for not reading everything.
sebastian22 is online now   Reply With Quote
Glock Forum
