#136 | |
well, i have been thinkin about buying a press....I guess I'll either do that or see if a shop will do it on the cheap...Thanks again
For info on outdoor adventures in South Carolina check out OffroadSC.com |
#137 | |
#138 |
Geaux Tigers!!!
Sure enough. The progress is in my "Tommy's Build Journal" thread....
And thanks!!Tommy
2001 Wrangler Sport - 4.5" homemade long arm lift, 1" body lift, 4.56s, 35" MTR Kevlars, 15x8 Pro Comp alloys, D30/Lock Right/alloys, D44/Detroit My Jeep Build Journal Long Arm Suspension Build |
#139 |
what was the total cost here in just materials?
1997 Wrangler 2.5L 5spd Suspension specs: RE 3.5, 1.25 JKS BL Old Man Emu shocks Teraflex adjustable front trac bar JKS Disco's Axle specs: Dana 30- Superior 4.88's Detriot tru-trac locker Dana 35- Superior 4.88's Riding on: 33x12.50 BFG A/T Black Cragar soft 8's
#140 |
Geaux Tigers!!!
$slick, check out post #115 in this thread. Maybe add some bucks for misc. hardware, etc.
I should also point out that I had a change of heart regarding the radius arm setup up front. It seemed to be working well, but in my build thread on pirate it was pointed out how much stress is applied to the linkage hardware as the suspension articulates to its outer limits. I gave it a bit more thought and it was clear that when a radius arm setup articulates it tries to twist the axle like a torsion bar. This can cause bind, but also apparently has been known to snap Grade 8 hardware. Granted, I've got some rubber bushings in my setup so maybe it wouldn't be that big a deal, but I decided to try a modified three link. I basically just removed the upper from the passenger side radius arm and left the driver side radius arm intact. On the trail this past weekend it actually seemed to flex easier than before. Not by a lot, but for the first time I was able to fully compress my shocks front and rear simultaneously when I took this poseur shot. Now I need longer bumpstops. ![]() I haven't driven it on the street yet. I'd like to get some longer hardware for the front upper and double nut it and Locktite it, too. I don't want that thing coming loose. I'll also make sure all the others are torqued and Locktited. But so far I'm not seeing any real reason not to leave it as-is. Of course, if anyone has a differing viewpoint, I'm always willing listen. BTW, this thing still climbs like mad and performs FANTASTIC on the rocks! Couldn't be happier! Tommy
2001 Wrangler Sport - 4.5" homemade long arm lift, 1" body lift, 4.56s, 35" MTR Kevlars, 15x8 Pro Comp alloys, D30/Lock Right/alloys, D44/Detroit My Jeep Build Journal Long Arm Suspension Build Last edited by Tommy R; 10-28-2008 at 06:21 PM.. |
#141 |
Nice to hear how it's working for you. I've really enjoyed your build-up. Great work
#142 |
what do you mean when you say radius arm?
#143 |
Instead of an upper and lower control arm on each side of the Jeep connecting to the axle, the lower control arm is shaped like a y (instead of // ), where the shorter arm is connected to the lower control arm and then to the axle. Instead of 4 separate control arms, its basically 2, mounting to 4 points on the axle. Scroll through his pics and you can probably find an example.
Look at some of the pictures of the front of the Jeep on this page: http://www.jeepforum.com/forum/f37/long-arm-build-tj-532320/index5.html |
#144 |
do you have the upper 3 link bar on the passenger side or drivers side?
#145 |
Geaux Tigers!!!
I removed the upper from the passenger side.
#146 |
#147 |
Geaux Tigers!!!
No pics, but there's really not much to see.
I haven't driven it on the street yet, but it peformed exceptionally well on the trails this past weekend.Tommy
#148 |
#149 |
Geaux Tigers!!!
No, I just used the casted mount on the diff.
#150 |
amazing build, ive started mine on my XJ because of this!!!
-nick
JustExpectEveryProblem 96' XJ: 6.5 RC lift, 35 MTRs,4.88s, 30/8.8 locked, tons of homebrew, blah blah blah... A-TOWN 4X4 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
