Lincoln weldpak 100 vs. 140... - JeepForum.com
post #1 of 3 Old 10-10-2009, 11:04 AM Thread Starter
jeepva10
Hey fabricators,
I have the opportunity to get a weldpak 100 for $200 brand new never used. I will be doing body repair work, possible axle swap, exhaust, a cage, etc. Nothing too major. Should I jump on it (it has a possible gas conversion for it) or should I try to get a bigger 120 volt? I don't have access to 220v so that is out!
Just want some advice from people who have had them and what they have done.
I have read and researched a ton with the search feature but never got an answer comparing two 120 volt units...
Thanks!
Chris
jeepva10 is offline
post #2 of 3 Old 10-10-2009, 11:22 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
get the biggest you can for 120v. 140amps. You'll need a 120v plug and extension cord that can handle it too (20-30amps), otherwise you'll trip the fuse in seconds at full amperage. The 120v/140A is about at the limit with 3/16" in single pass, but can do 1/4" if you know what you're doing and how to bevel.
Most around here won't recommend 120v'ers for roll cage work, even tho most use 1/8" wall tube. For my cage I traded a friend some work & beer to have him weld it with 220v.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 3 Old 10-10-2009, 11:46 AM Thread Starter
jeepva10
I will look for that then! I know I will keep it for a long time so I guess stepping up wouldn't hurt. I do know few people that could weld 220v for me so that is definitely an option...
Here is the link to the welder I was looking at if anyone wants it! - It is in va
Lincoln Electric Weld Pak 100HD Wire Feed Welder
jeepva10 is offline
lincoln 200 yea_mitch Fabrication Shop 0 03-12-2009 06:46 PM
Lincoln 225 Macnasty Fabrication Shop 3 05-06-2008 07:50 AM
Lincoln 175 hd JpnFirefighter Fabrication Shop 7 05-17-2007 07:59 PM
Lincoln 225/125 stevenaa Fabrication Shop 14 02-22-2006 10:53 AM
Getting to it with my 110 Lincoln Blthomas Fabrication Shop 12 01-22-2006 10:13 PM
