lincoln weld pac 125 welder? - JeepForum.com
post #1 of 9 Old 02-07-2011, 05:37 PM Thread Starter
Brown6041
anyone ever used this. Is it worth getting to do small projects, tabs stuff like that.
Brown6041 is offline
post #2 of 9 Old 02-07-2011, 06:34 PM
Kettles
I have a Lincoln 140C, and its fine for up to 1/4" for 1/4" you need do do some prep for proper penetration (bevel and preheat). A 125 wire feed would be lower than I would want. I don't know how much money your looking at spending, but a new 140 is in the ~500 range, and used 140's and some 180's (lincoln, hobart and miller) can be found on craigslist most places for 300 or less, often with a cart, tank and wire.
So unless the 125 is a steal I would shoot for atleast a 140. And a good used welder should last a long time and be fine, so long as there was nothing wrong with it.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #3 of 9 Old 02-08-2011, 07:29 AM
leaf777
I owned a 125 I got a home depot for 420. I welded a cj / yj warn front bumper to my tj, worked well. Later returned it to get a larger model. Got a 140 (has gas regulator) from ebay for 420 shipped. Not a pro tool, but works well for garage stuff, I plan on making some rock rails and custom bumpers soon.
leaf777 is offline
post #4 of 9 Old 02-08-2011, 08:41 AM
'92 vegas YJ
i too have a 140 and sometimes wish i went bigger.
you say you only want to do small tabs but once you start fabbing you're going to want to do more. i often work with 3/16" and 1/4". a 125 just wont cut it
-chris
'92 vegas YJ is offline
post #5 of 9 Old 02-14-2011, 01:10 PM
glenn-91YJ
glenn-91YJ's Avatar
I agree with the other posters...with a Jeep you'll outgrow the 125 quickly. I just bit the bullet and bought a 180...and glad I did. It might hurt a little initially but it'll hurt more once you sell the smaller unit, lose money and have to now buy what you really wanted in the first place. I fabed a plow frame using 3/8" and had no problems what so ever! It's already paid for itself.
glenn-91YJ is offline
post #6 of 9 Old 02-14-2011, 08:28 PM
1222
RIP John
1222's Avatar
Here’s another vote for a larger amp welder. If you start fabricating you will eventually wish you had a more powerful welder.
(2011-2016)
1222 is offline
post #7 of 9 Old 02-15-2011, 04:35 PM
JOExFROMxNY
I started with the Weld-Pak 100 in the late '80s and last year I finally moved up to a Millermatic 211. the old Weld-Pak lasted me great all these years, but the MM211 really is much better. it has a real sizzle when burning wire, nice solid crackle and great penetration. (that's what she said)
JOExFROMxNY is offline
post #8 of 9 Old 02-15-2011, 06:41 PM
cummins5552
Save your money and buy a bigger machine,small welders are a waste of money
cummins5552 is offline
post #9 of 9 Old 02-17-2011, 04:16 PM
thatnameisinuse
What Glenn said , I have a 180 as well and it will weld anything I throw at it
thatnameisinuse is offline
Lincoln pro mig 135 vs weld pak 180hd GrantTJ Fabrication Shop 2 07-24-2009 05:04 AM
Lincoln 140 Welder or Millermatic 180 canajien Fabrication Shop 15 07-24-2008 10:32 AM
Lincoln 180c welder FLATFENDER54 Fabrication Shop 4 06-12-2007 03:20 PM
Lincoln 220 Stick Welder StokedXJ11 Fabrication Shop 6 08-02-2006 11:34 AM
lincoln weld pack jeeptj00boy Fabrication Shop 5 03-14-2006 09:59 PM
