lesson on starting a good weld - JeepForum.com
post #1 of 11 Old 05-05-2006, 09:05 AM Thread Starter
blake989
I bought an off-brand wire welder (I use flux coated 0.03) a few years ago for small projects. I've finally got decent with using it and recently I've really got into fabbing my own stuff for the heep. One area where I'm really lacking some skill is starting the bead. The first 1/4" to 1/2" of weld, well my dog could do a better job! After that, I can get a decent puddle going and all is well. I don't mind grinding and cleaning it up, but you can tell that the first part of the weld has been doctored, and the rest looks normal. Is there an old indian trick to setting up that could help me, or am I just going to have let my dog start the weld for me?
The YJ is no longer my DD. I have sacrificed all future retirement plans for jeep parts. I'm depending on social security!
blake989 is offline
post #2 of 11 Old 05-05-2006, 09:39 AM
fourwheelhigh
fourwheelhigh's Avatar
Im guessing that you just put the nozzle where you are going to start the weld and start welding. What you are sopposed to do is is start welding about an inch into where the weld is going to go, strike the arc and move back to the begining and continue the weld over where you struck the arc. What you could also do is tack on a startup tab. Its a small tab about an inch or 2 long where you start the weld and run the weld onto your project, you would have to cut the tab off afterwards of course, this method helps quite a bit with stick welding.
1979 CJ-7 Renegade, Yellow, 304 V8, mostly stock. 1998 Cherokee XJ, stock.
Yaesu 7800R 2M/70CM, KJ4AEN
fourwheelhigh is offline
post #3 of 11 Old 05-05-2006, 09:40 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
FCAW is a point and shoot deal. You don't long arc wire.
Post some pictures of one of the welds in question. What brand wire are you running, and what is the flux composition? From the sound of things, I suspect that your stickout is really inconsistent. I'd have to take a look at one of the welds though. Pay attention to your stickout. Try to keep it in the 1/4"-3/8" range.
Learn to read your puddle and adjust accordingly. Consider a class or two.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #4 of 11 Old 05-05-2006, 09:52 AM Thread Starter
blake989
thanks fellas, yeah I've just been pointing and pulling the trigger for the past couple of years. I quit buying/threw away the cheap wire after reading a bunch of stuff on this forum, now I purchase the higher end stuff that tractor supply carries, whatever brand that may be, I think its about $35 for 100'. The local welding supply closes before I get off work, so I've never shopped there.
When you say "stick out", are you referring to the length of wire sticking out of the nozzle when I start the weld. If so, 1/4" to 3/8" is about half of what I've been doing. So what do you do, do you just have some dikes ready and cut any excess off before you start the weld, or do you just slap some scrap to burn off the excess?
I'm not a big picture man, but there is another guy in another thread wanting some pictures of some stuff, so I'll try to pull together some pics this weekend. I've got some thick skin, so when you see my welds, feel free to rip me!! They can be entertaining. To this point, I've tried to keep my welds safe by over doing it, grinding bevels to weld where normally a fillet would be fine, stuff like that.
blake989 is offline
post #5 of 11 Old 05-05-2006, 10:00 AM
Matt Gertsch
www.lp.org
Always clip the ball off of the end. That is part of your problem. That ball is a lump of slag. Ever notice how the gun pushes back on you when you try to start the weld? Stickout is the length of wire between the contact tip and the metal. Kick your voltage up about 3 or 4 volts and run a tighter stickout. You'll get a better volt/amp curve going. You welds will improve greatly, in both quality and apperance.
post #6 of 11 Old 05-05-2006, 10:06 AM Thread Starter
blake989
Exactly! Yeah, it pushes back when I start, I never understood why until now, that clump of slag (ball) must be preventing the arc? When I start, the wire doesn't arc, so before it does it pushes about a 1/2" like you say, then it arcs all of sudden and the excess wire that came out just dissentigrates and frizzles off, then I could weld. Excellent, I will follow your advice wise one! Thanks.
blake989 is offline
post #7 of 11 Old 05-05-2006, 11:21 AM
Mudinyeri
Mudinyeri's Avatar
I'm guessing your welds probably have a bunch of whiskers on them too. Yes, you're right, keep a pair of dikes handy (lesbians won't work, they must be full-on dikes) and clip the wire to the appropriate stickout length, making sure to get rid of the little ball of slag on the end of the wire.
Great minds discuss ideas; Average minds discuss events; Small minds discuss people.
Eleanor Roosevelt
Mudinyeri is offline
post #8 of 11 Old 05-05-2006, 09:30 PM
hoytheld
and...push the mig gun from start of weld to the end...don't pull.....
JH CUSTOMS MACHINE WORKS AND FABRICATION
Lathe and Mill Machine Work
Tig, Arc, and Mig Welding
Aluminum, Steel, Stainless, Titanium
hoytheld is offline
post #9 of 11 Old 05-06-2006, 03:03 PM
michael k
Flux core wire pull/grag slightly. for gas, push....Idealy.
2003 T4R
michael k is offline
post #10 of 11 Old 05-07-2006, 11:11 AM
bryans98tj
Also at the beginning of your weld, pause for a second, this way you are heating up the area and not having such a cold start point on your bead.
98 TJ-bought-not built
كافر - Infidel
bryans98tj is offline
post #11 of 11 Old 05-07-2006, 05:45 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
i agree, i've always been more comfortable pulling whenever possible with flux. but that's me, lol
as for the stick out, get a pair of pliers with the wire cutters built in and keep them handy. i find that using the width of the pliers as a guide makes for a uniform length each time and cutting the end off after each bead keeps the gun from pushing back on you as was mentioned.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
Looking for anyone in UP State NY that can weld good Heavysausage Fabrication Shop 0 06-03-2008 02:02 PM
learned a good lesson over the weekend iwishihad1 General Jeep & Off-Road Equipment 30 05-18-2007 09:38 AM
Stick weld or MIG weld? theboxman71 Fabrication Shop 39 10-05-2006 06:46 PM
Which Tire & Lift combo good for starting out Gratefulparrot Tires & Wheels 7 01-18-2006 06:24 AM
A lesson in acceleration chow Engines & Drivetrain 18 12-28-2005 11:17 AM
