latch for swing out - JeepForum.com
post #1 of 5 Old 10-16-2009, 05:28 AM Thread Starter
damian H
latch for swing out
I need some ideas for a latch on tire swing out.Something that is tried and true,with no rattles.
damian H is offline
post #2 of 5 Old 10-16-2009, 08:18 AM
jkl
Here's how I did mine. Sorry for the crappy cell pics, I'm at work.
Welded a washer and rod to a bolt
Welded a nut to the backside of the tab
No rattles and stays tight
'13 10th Anniversary Unlimited Rubi
...now parting out
jkl is offline
post #3 of 5 Old 10-16-2009, 10:10 AM
timatoe
timatoe's Avatar
Have you read through this thread???? http://www.jeepforum.com/forum/f37/r...-along-101332/ Tons of great info in there.
This is the one I got.... DE STA CO 341-R Pull Action Clamp with Threaded U-Bolt - SmallParts.com
The one above is also a proven method, it's quite similar to the ones A to Z fab uses.
timatoe is offline
post #5 of 5 Old 10-17-2009, 03:49 PM
ej's tj
ej's tj's Avatar
no rattles until I backed into a tree
take a look in my gallery, I built my carrier so it would open with the tailgate. I used two links with heim joints to a simple bracket bolted on the tailgate where the stock carrier used to be. it works very well, I had no rattles until I backed into a tree pretty hard and tweaked the tail gate a little. The rattle is almost not even noticeable. I think I need to just flex the tail gate back straight and life will be quiet again....... All in all I am very happy with the design, it easily supports my tire and my 200 pounds with no problems.... what I like best is that there is not another latch that has to be opened just to get into the back of my Jeep......
2005 Unlimited Rubicon bright red, wet okole, 2 1/2" (more like 3"+) HD OME 1 1/4" JKS BL, JKS Discos, 1" JKS MML,28575R16 BFG MTs, Custom HD rear bumper, 2 year old Akita,
9500 lb. milemarker winch, kilby gas tank skid, home made rear bumper and tire carrier, lite dot taillights, more to come!!!!!!
Integrity is a rare find!
ej's tj is offline
Swing Out Hinge & Latch MikNov General Jeep & Off-Road Equipment 1 04-29-2009 03:24 PM
Swing away bearing and Latch 00jeepsahara Fabrication Shop 5 07-08-2008 03:07 PM
swing away latch assemblies mag162 General Jeep & Off-Road Equipment 2 11-08-2007 01:32 PM
T-Handle Swing Arm Latch Info Needed Overdrive Fabrication Shop 5 04-24-2007 12:41 PM
Swing Out Finished! Birdlaw Fabrication Shop 10 07-17-2004 09:06 PM
