Laser Cutter File Types - JeepForum.com
post #1 of 3 Old 08-12-2009, 08:57 PM Thread Starter
Douglas S.
I can get plate cut for free on a laser cutter here in town. What I want to make is this (replace "***" with "ass"). I just need to get them into a format that the cutter can use. What is the easiest way for me to do this?
Thanks
1991 Land Cruiser HDJ81
Douglas S. is offline
post #2 of 3 Old 08-12-2009, 10:16 PM
sparkeep
Your shop with the lasercutter probably needs a DXF file. It is a vector format in actual size (1:1). It is easy to make with a CAD program, however the drawings on that site are missing some dimensions. Where is that rectangular hole located from the side? Also, I would only lasercut the bottom plate (10" x 28.25") from sheet. The sides would be easier/stronger to cut from 1.5" flatbar.
The image on that site is not to scale and the dimensions shown don't quite agree with each other. But here is a CAD file and DXF to get you started. You can view both with the free viewer on the Solidworks site.
www.naturespocket.com/temp/skidplate.zip
2005 Impact Orange Rubicon
6 speed standard 4.0L I6 engine
Mechanical Engineer behind the wheel
Toronto, ON, Canada
sparkeep is offline
post #3 of 3 Old 08-13-2009, 05:55 PM Thread Starter
Douglas S.
Thanks!
I regards to the rectangular hole, I think I'll just plasma it out once the actual skid is assembled. It is only used to access the drain plug.
looking for laser/plasma cutting service - southern california OldSkull Fabrication Shop 3 10-27-2009 11:38 PM
Plasma Cutter Help Stan99 Fabrication Shop 19 09-09-2008 08:35 PM
Laser cutting my own shackles Brandon_YJ Fabrication Shop 20 03-16-2008 07:56 PM
laser cut shock tabs iking87 Fabrication Shop 8 08-01-2007 03:58 PM
