jeep YJ/TJ bikerack - JeepForum.com
post #1 of 1 Old 07-02-2004, 01:39 PM Thread Starter
Jeepfreak81
Jeepfreak81's Avatar
jeep YJ/TJ bikerack
I have had a couple PMs regarding my bike rack i use for my jeep.
here is all i did
i use a releasable zip tie on the rim to hold it to the hi-lift
the back tire of the bike rests on the hi-lift or on the tailgate if you dont have a hi-lift.
the fork bracket is held on with 4 hose clamps. I retighten them before every use, not the best way but i havnt had a chance to have my dad fab up a steel bracket so i can weld it to the roll bar. The hose clamps have worked fine, though probably are not the safest method, same with the fork location if you are in an accident, but i figure if its my time, then its my time...
hope this helps some of you guys out
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
need non-jeep advice from jeep-ers on mild lift for son's '83 bronco numchuck Tires & Wheels 4 06-05-2007 08:50 PM
