Jeep Tj New front bumper/crossmember??? - JeepForum.com
post #1 of 6 Old 03-09-2011, 01:30 PM Thread Starter
anderson5290
Im wanting to build a bumper/crossmember for the front of my 06 jeep tj its at the dealer with an opda failure thats why i have drawn picture of what i have an idea of.
So, im thinking of cutting the stock front crossmember off, grinding it down and adding either a 4x4 or 4x3 of 3/16 square stock it will replace the stock crossmember and also double as a bumper. Also i will cap the frame ends off in the front so it looks nice and clean.
tell me what you think
anderson5290 is offline
post #2 of 6 Old 03-09-2011, 02:16 PM Thread Starter
anderson5290
anyone?
post #3 of 6 Old 03-13-2011, 10:20 PM
leaf777
Doesn't look like your antirock will have any protection. I vote leave the crossmember alone and make a bumper, IMO.
leaf777 is offline
post #4 of 6 Old 03-14-2011, 08:01 AM
MO2500
Interesting idea. I'v been entertaining the idea to do something similar but am trying to think of a way to work around my Anti-rock. Are you planning to leave the ends of the tube crossmember in the frame and just basically replace the section in the middle with a rectangular tube?
Also I'm 3hrs away from my Jeep or else I'd take a look but IIRC the crossmember up front is the only structural part forward of the engine I think? you'll need to brace the frame or weld something in temporarily before cutting out the tube or the frame rails might shift. I could be wrong, like I said, I don't remember for sure how far back the next structural piece is on the frame.
Instagram: @omsmike
MO2500 is offline
post #5 of 6 Old 03-14-2011, 11:13 AM Thread Starter
anderson5290
thats exactly what i was thinking i will just remove the crossmember between the frame and leave the ends so the anti rock will be the same and i will weld a support like you said so it doesnt move at all and then just replace the center and have it flush with the frame.
post #6 of 6 Old 03-14-2011, 11:53 AM
MO2500
If you are upto the task I say go for it. It would be something different. Like anything that is custom you might run into some problems but with a little ingenuity I think it can be done. I might eventually do something similar on mine.
You'll also need to adress the body mount that is part of that crossmember. I think you could pretty easily re-use the mount that's there just repositioned on the 4x3 or whatever you plan to use.
Instagram: @omsmike
MO2500 is offline
Does anybody have design plans for an XJ front bumper or rear bumper RescuedJK Fabrication Shop 1 03-15-2010 04:58 PM
TJ rear bumper/ rear crossmember ideas JeepRocks86 Fabrication Shop 5 07-05-2009 07:50 PM
Front crossmember/bumper build... criticism? flatlander757 Fabrication Shop 6 05-18-2009 09:35 PM
My First Jeep Fab - Front Bumper Bikertrash Fabrication Shop 14 10-01-2006 03:45 PM
94 ZJ homemade rocker guards, front bumper, rear bumper? haywood Fabrication Shop 1 12-17-2004 03:11 PM
