I'll see your burning machine and raise you... - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > I'll see your burning machine and raise you...
Savvy TJ/LJ Half DoorsSavvy Aluminum Gas Tank SkidFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 06-02-2013, 03:25 PM   #1
BGClemson
BGClemson's Avatar
4 Mitsubishi 4000 watt lasers
I rebuild these for a living, just thought you guys would be interested in this stuff!
BGClemson is offline   Reply With Quote Quick reply to this message
Unread 06-02-2013, 04:51 PM   #2
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
What kind of price tag do those things come with?
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote Quick reply to this message
Unread 06-02-2013, 06:48 PM   #3
BGClemson
BGClemson's Avatar
The ones in the first and third bays will run you around 350k-375k. They are both about 6-7 years old. The one in the 2nd bay is 10-11 years old and you can get in that one for 300k or so. The new 4500 watt Mitsubishi's run around 600 grand or so.
They really are amazing pieces of equipment. I can cut 1/4 mild steel at 125 ipm holding tolerances of .003", and you wouldnt have to touch it (no deburring period). The two higher priced rebuilt machines will cut it at 120 ipm or so.
We rebuild Mitsubishi lasers only. We have a little 4x8 table, 2000 watt laser we are going to be starting pretty soon. Those are low end, right around 100 grand
Unread 06-04-2013, 05:03 PM   #4
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
That's pretty cool!
I don't feel too bad though. My plasma table will cut 1/4" at about 60ipm (at 60amps) and hold about .010" tolerance. Does require some cleanup though.
I'm pretty happy with it for the $17K pricetag.
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Unread 06-04-2013, 05:25 PM   #5
BGClemson
BGClemson's Avatar
That's pretty cool!
Absolutely! Its not like you can have one of these in your personal garage. We have a demo machine (a new one) in our showroom along w/ a 140 ton press brake, so I'll have some write ups in the near future. My first project is a steering box skid, made out of 1/4", maybe 5/16"
Unread 06-05-2013, 08:00 PM   #6
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I used my plasma table to "build" a 48" Pressbrake.. not sure of the exact tonnage but it'll brake 48" of 3/16" in a 1.5" die pretty easy.. and bent 36" of 1/4" in a 2" die. Those bends only required about 45tons of oomph. Haven't really gone beyond that yet.
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Unread 06-06-2013, 09:43 AM   #7
ginger-mech
1963 CJ5
When you say rebuild...is that pumps, seals, laser assemblies? Impressive machine.
Oh the things I could build with one of those...
ginger-mech is offline   Reply With Quote Quick reply to this message
Unread 06-06-2013, 07:09 PM   #8
BGClemson
BGClemson's Avatar
Cleaning, paint, fabricate (any damaged sheetmetal/panels is reverse engineered and made in house).
We do a full rebuild on the resonator, replace damaged electronics and drives on a case by case basis. All optics are replaced. We have about a 200 point checklist on these things. We offer a warranty on them as well, Mitsubishi is the only company in the US that will offer a warranty on used equipment.
And I do know the things that can be done with one
Unread 06-07-2013, 12:55 AM   #9
schitzangiggles
King of Macastan
schitzangiggles's Avatar
But can you put it on a shark, or angry sea bass?
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline   Reply With Quote Quick reply to this message
Unread 06-07-2013, 07:37 AM   #10
BGClemson
BGClemson's Avatar
I see no reason why not, the machine only weighs 12 tons or so, it would have to be one pissed off shark
Unread 06-07-2013, 11:54 AM   #11
schitzangiggles
King of Macastan
Definitely gonna need a bigger boat.
So can the lasers mill or just cut flat steel?
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
Unread 06-07-2013, 02:23 PM   #12
BGClemson
BGClemson's Avatar
These CO2 lasers are for cutting only. Like I posted above, they are expensive up front, but are great on consumables and cost of operation is much lower than your typical water jet or plasma/burning machine, or turret punch for that matter. Pluses for lasers are great accuracy and speed. Our machines are very reliable for thicknesses of one inch and lower. The cut when set up properly is dross free and there is little to no bevel in the parts. Just like anything else, you need to have the knowledge to set up and run one of these, but they are not difficult, even to program. You can etch as well, If you want to mill you need a mill.
Unread 06-07-2013, 02:28 PM   #13
BGClemson
BGClemson's Avatar
Just to give you an idea of how far we take these things, here is another machine, we just started it on Monday. It has been torn down and cleaned, ready to start building it back up and testing it out!
Unread 06-07-2013, 04:39 PM   #14
schitzangiggles
King of Macastan
Do they make a laser mill?
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
Unread 06-07-2013, 06:03 PM   #15
BGClemson
BGClemson's Avatar
I believe there is such a thing out there. The technology is fairly new, and I do not know a whole lot about it.
